    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-11-2012, 02:28 PM   #1396
Energyzer's Avatar
Originally Posted by Cpt.America View Post
8.5? I think 8.5 guys typically run a 22 or 23, somebody correct me if im wrong..
The esc usually gets directly soldered to the motor. A to A, B to B, and C to C. And last but not least, the sensor wire is just plugged in. The ESC gets plugged into the receiver, just like your servo. Once up and running, you need to learn how to calibrate your ESC/radio. Each manufacturer has their own steps for calibration.
Thanks man! I bought in 2 diff shops (car from one and the rest of the parts from another). About the pinion: i asked the guy from the shop to give me whatever he thinks it's best for our tracks here (astro) and for that motor, and he gave me that one...
What about the 2 wires that go into the battery? Don't they need to get some kind of connector at the end of each wire?!
Energyzer is offline   Reply With Quote
Old 10-11-2012, 02:47 PM   #1397
toast.'s Avatar
Solder the connector which your batteries use.
Popular connectors are deans and 4mm bulllet connector.
Deans:
Bullet:
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 10-11-2012, 03:05 PM   #1398
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
yep! + to +, and - to -. You can use any plug that matches on both sides. Personally speaking, your two best choices are either deans plugs, or bullet connectors (both pictured above). If the battery you bought has a deans plug already on it, solder your ESC up with deans plugs. If your battery is bullet plugs, solder the male bullets to your ESC wires. Bullets are better in my opinion, but there is a MUCH greater chance of plugging your battery in backwards, which will usually fry your ESC in an instant (sometimes even with the on/off switch set to off). I personally wire the lengths of my ESC wires so that i CANT plug it in backwards.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-11-2012, 03:24 PM   #1399
toast.'s Avatar
" I personally wire the lengths of my ESC wires so that i CANT plug it in backwards."
That is some good advice, going to have to redo my wires. Wish there was a way to better label batteries opposed to a little + and -
Old 10-11-2012, 03:29 PM   #1400
CanyonCarverR1's Avatar
I highly suggested you let a more experienced electric racer look at your wiring before you flip the switch
CanyonCarverR1 is offline   Reply With Quote
Old 10-11-2012, 03:31 PM   #1401
Trader Rating: 22 (100%+)
get a red paint marker or red nail Polish and mark the positive side...
noproblems209 is offline   Reply With Quote
Old 10-11-2012, 03:38 PM   #1402
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
I would as well. Don't plug in the battery till you have everything checked.
With the right motivation(fav. beverage, etc), you might be able to get an experienced electric racer to do the wiring for you and show how you how it is done as they do it.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 10-11-2012, 03:42 PM   #1403
fullsyzz's Avatar
Trader Rating: 102 (100%+)
Is the stock rear toe-in angle on the RB6 3 deg? And, is the only way to adjust rear to by changing rear hubs?
fullsyzz is offline   Reply With Quote
Old 10-11-2012, 03:49 PM   #1404
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Yes.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 10-11-2012, 03:55 PM   #1405
fullsyzz's Avatar
Word.
Old 10-11-2012, 04:39 PM   #1406
TCR
Default No Slipper
Jason,
Your set-up states you are not running a slipper and 64 pitch gears. I was just wondering how is this achieved and who's gears are you running?
Also not sure how the calculation on 64 pitch gears is but isn't
88/33 * 2.6 = 6.9333 FDR?
Your set up looks fast, I'd like to try this when my RB6 comes
Cheers,
Originally Posted by Jason.Dias View Post
Does that tire combo work on your RB5 down there?
I made some more adjustments tonight and went even faster!
Started the night with the setup I posted:
http://mobile.liverc.com/results/?d=...K_BUGGY_NT.xml
Then for round 2 I made some adjustments to get the rear end to be a little more locked in after a 180 coming on power. I lowered the rear shock mount to the furthest inside hole. This helped and I went faster.
Then for the main I felt it was a little to stiff with the shocks down so I went to a softer spring in the rear, switched to gold rear springs, car was amazing for the mains. I was clicking off 19 second laps like it was nothing.
http://mobile.liverc.com/results/?d=...T_(A_Main).xml
Was on a 19 lap pace (which obliterates anytime a stock buggy has gone on that layout, only the good mod drivers or 4wds go 19 laps) but Kevin Smith and I started waiting for each other so we could race.
I'll make a new setup sheet for what I changed tonight and post it up.
TCR is offline   Reply With Quote
Old 10-11-2012, 06:05 PM   #1407
Trader Rating: 1069 (100%+)
yeah just as POSVAR
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 10-11-2012, 06:18 PM   #1408
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
How much rear toe are you running?
0
It always has for me, I may try some run down Rebar fronts.
I also don't know what a few adjustments do:
The outisde front hub adjustment. I'm assuming it does what the inner does, only to a lesser extent? That's what I remember from onroad racing.
I also am not real sure what the rear arm spacing does on the inside arm for the rear.
What the shims on the steering arm do, and the .0x shims on the outside axle do. I dont even remember shimming that except for the 1mm shim on the outside but it looks like people have split that up....
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 10-11-2012, 06:39 PM   #1409
Moderator
Posvar's Avatar
Trader Rating: 461 (100%+)
Originally Posted by bigwavedave33 View Post
yeah just as POSVAR
Yes, I have plugged in my Gens Ace packs backwards once.....or twice. Not any more as my packs have red nail polish on them and the wire has been shortened. Thank you very much!!!!
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-11-2012, 06:40 PM   #1410
Moderator
Posvar's Avatar
Back on track people!
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
