    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-06-2017, 02:25 AM   #14071
LoudOne's Avatar
Trader Rating: 31 (100%+)
Originally Posted by LoudOne View Post
What gear diff oil are you guys running? Weight?
Looking at getting Kyosho Silicone Differential Oil (40cc) (4,000cst) for KYOUMW604 w/ KYOUMW726. Thoughts?
Any advice? Thanks
LoudOne is offline   Reply With Quote
Old 01-06-2017, 06:24 AM   #14072
loaba's Avatar
Are some folks dropping the stock ball diff, after it wears, in favor of the SC6 gear diff?
/I did that in all of my Associated SC10's...
Kyosho Ultima RB6.6 mid-motor/3-gear laydown 17.5t stock
loaba is offline   Reply With Quote
Old 01-06-2017, 10:17 AM   #14073
Good morning,
I am looking to build my RB6 and RB6.6 for a carpet track. I went on Petite RC to look at some setups and noticed that on one particular build, the person was using Associated shock springs. Do these work interchangeably w/ Kyosho shocks or do some mods need to be made?
Thanks in advance for any advice/guidance.
I'm running that build. Spring work great!
jcsfearless is offline   Reply With Quote
Old 01-06-2017, 10:17 AM   #14074
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by loaba View Post
Laydown arraignment uses the same waterfall part. Maybe somebody else knows what the nubs are.
Kyle, please see the attached picture.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-07-2017, 12:11 AM   #14075
What surface will you be running on? 3000 is always a safe bet to start.
LAGuy is offline   Reply With Quote
Old 01-07-2017, 03:00 AM   #14076
LoudOne's Avatar
Carpet... I saw one of Jared Tebo's setups on Petit and decided on Kyosho 5000.
Old 01-07-2017, 10:55 AM   #14077
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Only if you are running on carpet or astroturf. The ball diff is much better on dirt.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 01-07-2017, 06:34 PM   #14078
YANMAN's Avatar
Trader Rating: 38 (100%+)
Originally Posted by Jack Smash View Post
For a dirt glue track without a doubt go 3 gear laydown with shocks on the front of the arm and a ball diff in 17.5. Kyosho ball diff is butter smooth out of the package with stock parts, and lasts quite a while.
The hot setup at my track is the lay down, gear diff 3k oil and shocks on the back of the arms. I am just not sure what to do. I was thinking of going midmotor, gear diff and shocks on the rear.
YANMAN is offline   Reply With Quote
Old 01-07-2017, 07:15 PM   #14079
Originally Posted by Kylevergata View Post
Building my 6.6 right now and a fellow Kyosho driver gave me his setup for our local track. His comment area states that the nubs are removed from the waterfall. Question is where are these "nubs" thanks
If you look at the waterfall brace you will see them they stick out the front and are for the shelf to screw on to. I'm assuming he removed them to get a normal size shorty as far back as possible.
danwilson is offline   Reply With Quote
Old 01-07-2017, 07:22 PM   #14080
Originally Posted by YANMAN View Post
Thank you. I will go that route. I rally appreciate everyone.
How many of you have built the kit stock with no aluminum? I plan on just building it as is.
In my experience the c hubs have a weak spot in them and the insert breaks out exotek make alloy ones that are great. Also the steering rack should be alloy so you can use bearings and remove a bit of play again exotek make a good one. Also lunsford make the best ball cups only problem is they are shorter then stock and you need the titanium turnbuckles to go with them.
Old 01-07-2017, 07:53 PM   #14081
I have a RB6 stock shocks and 3 times in races today, I cracked my shock end in half. Could someone please tell me why this is happening. I had minimal camber and haven't had this issue in the past. Any suggestions would be deeply appreciated.
ruttrowreroy is offline   Reply With Quote
Old 01-07-2017, 08:19 PM   #14082
loaba's Avatar
So here she is, just waiting to get my shell back from the painter. Might source a second shell and one-shot it white, put stickers on it.
Right now, I think my ball diff is way to loose. Give it gas and the thing really slips. Won't address that until the Schelle slipper shows up in the mail.
/if there's a better place for pics, lemme know
Old 01-07-2017, 08:46 PM   #14083
likea45's Avatar
Stop hitting stuff
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 01-08-2017, 07:41 AM   #14084
1st time racer as well yesterday and I agree with that as well, except my last race was pretty smooth with very limited carnage. Would anything else other than hitting something cause this? (Too stiff/loose shocks,wrong positions of shocks, camber)?
Old 01-08-2017, 12:24 PM   #14085
Super Moderator
Kraig's Avatar
Which end?
Was the air temp cold in the building?
If it was the plastic top, is there any chance that it can come in contact with the shock tower during full suspension compression?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
