    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-05-2017, 04:25 AM   #14056
LoudOne's Avatar
Trader Rating: 31 (100%+)
Good morning,
I am looking to build my RB6 and RB6.6 for a carpet track. I went on Petite RC to look at some setups and noticed that on one particular build, the person was using Associated shock springs. Do these work interchangeably w/ Kyosho shocks or do some mods need to be made?
Thanks in advance for any advice/guidance.
LoudOne is offline   Reply With Quote
Old 01-05-2017, 05:08 AM   #14057
Originally Posted by Drift_Buggy View Post
Sorry, bit of a rookie question here. Recently purchased a 2nd hand one and it is mid motor. The rear suspension hangers are RF in the front and MM2 on the rear. Is this correct? Flicking through the manual It says to run RF2 when running mid motor.
RF2 is required to go with the plastic MM2 rear mount. The "2" signifies that they are the wider (standard on MM setup) width, RF is the narrower hanger often used with the rear motor setup.
Kyosho UK RB6.6 & ZX6.6
RogerM is offline   Reply With Quote
Old 01-05-2017, 05:24 AM   #14058
LoudOne's Avatar
Originally Posted by BigInJapan View Post
i run high grip carpet, gear diff way to go imo
What gear diff oil are you guys running? Weight?
Looking at getting Kyosho Silicone Differential Oil (40cc) (4,000cst) for KYOUMW604 w/ KYOUMW726. Thoughts?
Old 01-05-2017, 07:04 AM   #14059
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by LoudOne View Post
Good morning,
Springs, if you have the right size, are interchangeable between brands.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-05-2017, 08:39 AM   #14060
loaba's Avatar
Good to know.
Been looking at various pics of the RB6.6 builds - have a question; which side of the car did you put the spur gear on?
I carefully copied the setup in the manual, have my spur on the right side (looking forward, from rear to front). If you went the other way, why? What advantage, if any, does it offer?
Kyosho Ultima RB6.6 mid-motor/3-gear laydown 17.5t stock
loaba is offline   Reply With Quote
Old 01-05-2017, 09:25 AM   #14061
rider313's Avatar
Trader Rating: 94 (100%+)
the side its of depends on how many gears you have in it. 3 gear it will be on the passenger side (right), 4 gear it will be on the drivers side (left). you cant to four gear and right side spur for it will spin in reverse, same applies to 3 gear.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 01-05-2017, 09:31 AM   #14062
loaba's Avatar
I built mine 3-gear - thanks for the info
/note: I have an older Trackstar 17.5t motor/80a ESC combo in the car and I could not properly pair the ESC until the radio (Futaba 3PLS) was set to REV TH & ST
Old 01-05-2017, 11:55 AM   #14063
Default RB6.6 waterfall nub removal
Building my 6.6 right now and a fellow Kyosho driver gave me his setup for our local track. His comment area states that the nubs are removed from the waterfall. Question is where are these "nubs" thanks
Kylevergata is offline   Reply With Quote
Old 01-05-2017, 12:10 PM   #14064
loaba's Avatar
First - I'm setup for 3-gear mid-ship; if that's what you're doing, then we might be on the same page.
Looking at my "waterfall", I see 3 connection points. There are the posts that mount to the chassis; there's the connection to the tranny; finally, the two points for the battery strap's rear catch plate.
I don't see anything on the part that I would describe as a nub or nubs. I guess he could be referring to flashing?
Old 01-05-2017, 12:12 PM   #14065
I'm doing the laydown transmission. I could shoot him a text but I don't want to bother him at work.
Old 01-05-2017, 12:15 PM   #14066
loaba's Avatar
Laydown arraignment uses the same waterfall part. Maybe somebody else knows what the nubs are.
Old 01-05-2017, 12:53 PM   #14067
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Thanks for reply. This has the standard RF plastic mount and then some aluminum mount on rear with MM/RR2 on. Unsure of brand, pic of logo below.
So, pretty much I should switch the RF to RF2?
Drift_Buggy is offline   Reply With Quote
Old 01-05-2017, 03:20 PM   #14068
That is made by Revolution Design. I've only seen them sold as a kit. Part # RDRP0212.
RB6.6/YZ-2 DT/'17 XB2 CE
YZ-4/B64D/22-4 2.0/D413
YMMV is offline   Reply With Quote
Old 01-05-2017, 08:45 PM   #14069
Default Sway bar
Anyone else running a sway bar?
randywhite30 is offline   Reply With Quote
Old 01-05-2017, 11:26 PM   #14070
Thanks, wasn't sure who made them.
The RF2 aluminum one is in with spare parts but the standard RF plastic one is on the kit.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Arcain41
