    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 12-31-2016, 03:28 PM   #14041
Jack Smash's Avatar
Trader Rating: 29 (100%+)
For a dirt glue track without a doubt go 3 gear laydown with shocks on the front of the arm and a ball diff in 17.5. Kyosho ball diff is butter smooth out of the package with stock parts, and lasts quite a while.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 12-31-2016, 03:51 PM   #14042
JAE
Trader Rating: 28 (100%+)
Why's this diff so smooth? After a couple months still smoother than my other buggy after a couple runs. Seems like an ordinary diff upon building. My other buggies' diff was the Bain of my existence. I have 2 extra Kyo diffs just sitting here waiting. Incredible
JAE is offline   Reply With Quote
Old 12-31-2016, 04:25 PM   #14043
YANMAN's Avatar
Trader Rating: 39 (100%+)
Thank you. I will go that route. I rally appreciate everyone.
How many of you have built the kit stock with no aluminum? I plan on just building it as is.
YANMAN is offline   Reply With Quote
Old 01-03-2017, 04:10 PM   #14044
loaba's Avatar
Got an RB6.6 kit for Christmas and it was the hardest build I've ever done. But it's gonna be so worth it. I'm now in the process of accumulating spares. Already got arms (F and R) and just ordered shock stays (F and R). What else tends to break? Also, what's the thought on the stock slipper? Is it worth it, does anyone use the Schelle?
Just saw this...
As of right now, I am 100% stock and I'll likely stay that way for a bit. The only items that are even on my radar are the aluminum motor plate and aftermarket Schelle Slipper assembly.
Kyosho Ultima RB6.6 mid-motor/3-gear laydown 17.5t stock
loaba is offline   Reply With Quote
Old 01-03-2017, 05:07 PM   #14045
RandyB's Avatar
Because the balls are tungsten carbide, they retail for like 30 plus dollars for a set of balls only.
RandyB is offline   Reply With Quote
Old 01-03-2017, 05:10 PM   #14046
loaba's Avatar
This is by far the smoothest diff I've ever built.
Old 01-03-2017, 05:34 PM   #14047
oPAULo's Avatar
I don't think the kit comes with carbide balls. I bought carbide balls for a while and didn't really think they lasted any longer. Seems like the notchy feel comes from the groove that wears in the rings and not the balls.
oPAULo is offline   Reply With Quote
Old 01-03-2017, 06:27 PM   #14048
boner's Avatar
kit diff balls are tungsten carbide, #97030.
boner is offline   Reply With Quote
Old 01-03-2017, 06:37 PM   #14049
oPAULo's Avatar
By gosh your right!!
Who does that!
KYOSHO does...
Old 01-03-2017, 06:56 PM   #14050
boner's Avatar
lots of hidden goodies from "k". I think they started including them since RB5 series, it just no one taking attentions to them.
Old 01-03-2017, 11:45 PM   #14051
Ball diff for stupid high grip carpet or gear diff? Also I think I lost a a ball or two on the thrust washer( i think thats what it is called, the one on at the end of the shaft that goes through the center of the diff). should I replace them or will I be ok?
Also when I say stupid high grip carpet I mean if you are not careful running carpet tires you're going in to a wall if you touch the throttle too hard high grip.
jcsfearless is offline   Reply With Quote
Old 01-04-2017, 12:01 AM   #14052
BigInJapan's Avatar
Trader Rating: 15 (100%+)
i run high grip carpet, gear diff way to go imo
⚡ TEKNO ⚡ OS ENGINE ⚡ KO Propo ⚡
BigInJapan is offline   Reply With Quote
Old 01-04-2017, 03:53 AM   #14053
eper's Avatar
Trader Rating: 14 (100%+)
How many thrust balls do u have. If u are one short the diff isn't going to work the way it's designed
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 01-05-2017, 02:47 AM   #14054
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Sorry, bit of a rookie question here. Recently purchased a 2nd hand one and it is mid motor. The rear suspension hangers are RF in the front and MM2 on the rear. Is this correct? Flicking through the manual It says to run RF2 when running mid motor.
Drift_Buggy is offline   Reply With Quote
Old 01-05-2017, 03:12 AM   #14055
eper's Avatar
Rf is rear front rr is rear rear
new milford ct,
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Today 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
