    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 12-29-2016, 06:47 AM   #14026
Trader Rating: 16 (100%+)
Originally Posted by randywhite30 View Post
I've tried a number of things to improve traction including
Reducing shock oil from 30 to 27.5
Making my rear links longer
Moving out the shock on the rear shock tower
And using the same tires as the guys that are going fast at my home track
I've had a few people tell me to switch from a gear diff to a ball diff
Anyone else agree that a ball diff for some reason give bear rear traction?
The changes I've made to this point have made things better but still looking to know if a ball diff really makes traction better over a gear diff
There is no doubt that a ball diff is better on medium grip. We are running a 3 gear laydown on a dirt grooved track and its hooked up. The rb6 steers in hard. I find myself balancing steering and rear grip. Rear grip always overrides my other needs. It's looks like gears diff want to keeps rotating on corner exit. Post up your setup and which track you race at.
Cfconcrete is offline   Reply With Quote
Old 12-29-2016, 07:12 AM   #14027
tobamiester's Avatar
Trader Rating: 281 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
^^ What he said. Definitely Ball diff is the way to go.
tobamiester is offline   Reply With Quote
Old 12-29-2016, 10:45 AM   #14028
JAE
Trader Rating: 28 (100%+)
I've been running my shocks on front since beginning to drive this buggy for more rotation. Did this based on the performance of shocks on front of my other buggies (Xb2 and b6) I wouldn't run those buggies any other way. But, the rb6 has so much steering am contemplating running them on the rear. Anyone opine on their experience on front vs rear shock placement?
JAE is offline   Reply With Quote
Old 12-29-2016, 10:59 AM   #14029
jmackani's Avatar
Trader Rating: 14 (100%+)
What weight fluid are you running in the gear diff?
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 12-29-2016, 05:54 PM   #14030
Trader Rating: 29 (100%+)
I think a common issue is people think a 2 wheel buggy gear diff somehow translates or is semi-equal to that in a wheeler or sct. unless your on SRS clay or carpet chances are a ball diff is going to do wonders for your car over a gear diff.
At my local track we run slicks all the time and wheelie out of every corner but its still not enough to warrant a gear diff. We have tried it and it actually took grip away from the car on our track.
From what you have explained without knowing the exact surface you will be better off with a ball diff as others have mentioned.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 12-30-2016, 06:55 AM   #14031
My son tested it. He's the fast guy in the family. I think it actually makes the car drive weird. I built a 3 gear standup to compare against the 3 gear laydown, the laydown made more usable grip. I had to drive the standup harder and I never hit lap times I could with laydown. If your track has grip, I have no doubt that shocks on the front is better. We are running the Matt Chambers setup adjusted to our layout. We are running 1.7 rear shock Pistons, and a longer wheelbase. Ive been very happy with the laydown on a medium/high grip track. I've been told that our cars do not steer as hard as the B6. We run mod, so we are always balancing steering and grip.
I would have to be really struggling for rear grip to move the shocks to the back of the arms.
Old 12-30-2016, 07:03 AM   #14032
I was so confident in the laydown configuration, I turned the standup rb6.6 into a 4 gear laydown car.
Old 12-30-2016, 08:32 AM   #14033
YANMAN's Avatar
Trader Rating: 39 (100%+)
I am so confused on how to build this car. There are so many options and I think I know where to start, but I am not sure. I am building a 17.5 car, the track is indoor/outdoor clay. They add dirt glue to the dirt so traction is good.
I was thinking of going 4-gear laydown with shocks on front of arms. I wanted to use the gear diff with 3k in it for easy/Bullitt proof diff. There is only one other RB6.6 at the track and he is running the 3-gear lay-down with shocks on the back of the arms. I was thinking the 4-gear would add more mechanical grip to the car so I should be good to go with shocks on the front of the arms.
Also, how many of you have built the car stock with no aluminum up-grades?
Bellgate Dist. / Highest RC Servos / Procircuit Tires
Nitro Pro Race Fuel
YANMAN is offline   Reply With Quote
Old 12-30-2016, 02:16 PM   #14034
Trader Rating: 17 (100%+)
I built a gear diff for my Rb6.6 laydown and it is not smooth or anything compared to the gear diff I just built for my B6d. Night and day comparison
Rcforlife13 is offline   Reply With Quote
Old 12-30-2016, 07:51 PM   #14035
oPAULo's Avatar
Fluke hit from a SCT. Can't believe it didn't break the tower though.
oPAULo is offline   Reply With Quote
Old 12-31-2016, 01:12 AM   #14036
If your using a clay compound tire or slicks, I would think a 3 gear laydown would be the way to go for stock racing. Shocks should be on the front.
Old 12-31-2016, 06:18 AM   #14037
eper's Avatar
Run a 3 gear with 17.5. Or your going to feel slow compared to other 3 gear cars with 17.5. Traction won't be a huge issue with stock motor. If I were you I'd run a 3 gear lay down with a ball diff and start from there on set up. The rb6 generates good rear grip in lay down configuration. I'd say from what I've heard I'd run shocks the the rear of the tower. Good luck and ask any questions u want. We are all glad to help.
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 12-31-2016, 12:00 PM   #14038
YANMAN's Avatar
Thank you. Do you think the gear diff will be good to go. I really don't want to mess with the Ball but if it is the better option I will use it.
Old 12-31-2016, 03:32 PM   #14039
3gear laydown with Ball diff is way to go; Ball Diff definitely the best option for your surface.
Old 12-31-2016, 03:44 PM   #14040
Default RB6 shock mounting
I'm reading some people mounting their shock so on the front anyone have a picture of that?
randywhite30 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22981 Yesterday 04:29 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
