    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-14-2016, 10:41 AM   #13966
LKF
3rd and last part of building rb6.6 with lots of pictures and an additional battery position using hop up part (UMW728)
more
LKF is offline   Reply With Quote
Old 12-14-2016, 08:05 PM   #13967
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Smile
Originally Posted by skrichter View Post
Here is the response I received from Tebo on Instagram:
On the RB6 C block, no shim is used. The d block MUST use shims. Thin on bumper, thin under bulkhead is 2 degree. Nothing on bumper and thick under bulkhead is 1 degree. Thick on bumper and nothing under the bulkhead is 3 degree. You MUST use the total amount of 1 thick shim to have your transmission mounted properly. I don't know exact off my head the shims for ZX6. I think nothing under c and nothing under d is 2 degree.
I'm not sure in regards to the C block vs D block statement. The Alum suspension blocks come with pills; A,B,C,D blocks which are ONLY used to adjust the toe in. It has zero effect on Anti-Squat. Anti-Squat is adjusted by shims as described. Are you using the plastic suspension blocks?
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 12-15-2016, 06:44 AM   #13968
skrichter's Avatar
Send a message via AIM to skrichter
Correct - we were discussing antisquat. I understand toe (and different rear pivot widths) is achieved with the pills -- I am using the brass C block for laydown and the aluminum D block. I like to reference the actual blocks as C or D blocks vs. calling them RF and RR. For example a 4wd buggy has 4 blocks in total - A,B,C,D. I know this can be confusing a little bit since KYO uses pills with 'letters'. But I feel its easier to describe which block I am referring to when discussing setups. I think Ryan Lutz had a web blog about this once, where he liked the A/B/C/D blocks as well. Anyway....
However nowhere in the manual (or online) does it state what the stock anti-squat is for the RB6/6.6. However, according to Tebo, you MUST use at least 1mm of total shims on the D block (in between the rear bumper and camber block) in order for the tranny to fit correctly. In other words, you need to use two 0.5mm shims (in any fashion), or a 1mm shim (either below/above the bumper or rear camber block). Tebo mentioned you can achieve 1deg, 2deg, and 3deg -- depending on where you place the shims.
However, Joe Pillars recently mentioned the stock antisquat should be 2.5deg. Sounds like no one really understands what the true antisquat is with the RB6/6.6. If anyone does, please let us know!
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 12-15-2016, 07:40 AM   #13969
Trader Rating: 14 (100%+)
If I was to run a gear diff in my Rb6.6 laydown. What oil should I start with. ???
Rcforlife13 is offline   Reply With Quote
Old 12-15-2016, 09:33 AM   #13970
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Where will you be running the car, dirt, astro, carpet and what kind of tires will you be using, slicks, foam, treaded?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-15-2016, 09:36 AM   #13971
Clay dirt Electrons tires
Old 12-15-2016, 08:35 PM   #13972
3k
Too little steering in corner, try 1k.
Too much steering/rotation, try 5k.
LAGuy is offline   Reply With Quote
Old 12-17-2016, 07:19 AM   #13973
I have a question. In my Rb6.6 in laydown config. Can u put 4 gears in there not 3 as the kit manual says. ??
Old 12-17-2016, 07:35 AM   #13974
tobamiester's Avatar
Trader Rating: 274 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Absolutely!
tobamiester is offline   Reply With Quote
Old 12-17-2016, 08:18 AM   #13975
Should I when the track isn't carpet or super high grip
Old 12-17-2016, 08:32 AM   #13976
I know some of our local fast guys (Tebo being one), are running the 4 gear laydown on med to high grip.
will5879 is offline   Reply With Quote
Old 12-17-2016, 09:33 AM   #13977
That's what I saw. With that being said. Using everything the Rb6.6 kit came with. Where should I be running the shocks. I see them in the rear. I don't have the old Rb6 rear bulkhead. I wanna stick with what the kit came with but mount the shocks in the rear.
Old 12-17-2016, 10:56 AM   #13978
oPAULo's Avatar
The kit comes with all the bulkheads. I started with laydown and shocks on the rear then moved them to the front. I like them on the front way more. Much tighter package. On our smaller 1/10th scale medium bite tracks it just snaps through the 180 turns. The biggest difference to me is that it pulls the wing in closer to the center of mass. Speaking of wings, they're sooo much easier to cut out with shocks on the front.
oPAULo is offline   Reply With Quote
Old 12-17-2016, 11:11 AM   #13979
draboyd19's Avatar
Trader Rating: 19 (100%+)
Question for you guys.
I've got a RB6 in 3 Gear stand up setup. I've lost the small little black circle cap that covers the top shaft bearing on the side opposite the slipper and spur gear side.
Rather than spending $10 for the whole 3 gear kit and getting all the extra parts again, any solutions as to how to close that up? It appears its just a cap to keep dust dirt from reaching the exposed bearing and top shaft end. I believe it's 10mm wide so not sure if that helps locate any replacement options.
Thanks in advance.
draboyd19 is offline   Reply With Quote
Old 12-17-2016, 11:13 AM   #13980
oPAULo's Avatar
Think I lost mine on the first day. I don't run outdoors so I haven't worried about it.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
