    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-06-2016, 04:28 PM   #13936
draboyd19's Avatar
Trader Rating: 19 (100%+)
Ok, so I'm picking up an RB6 that is setup for stock dirt racing to add to the collection of Kyosho racing toys - MIP Aluminum Pucks, cut gear, lightweight goodies and Schelle Nova Slipper system. Plan is to run it as a stocker, but most of the surrounding tracks don't have that class on a weekly basis, just larger events. Most times it's just a modified open 2WD buggy class at the club level.
With that in mind, is a 17.5T motor still the ideal fit with this stocker buggy if paired with a orion r10 Pro if I wanted to try and run it more often at the weekly level?
Guess my question is related to how much, is too much, motor for a buggy with the MIP system and cut gears set-up from a possible breakage standpoint, and can the Nova Slipper system handle bigger boy motors?
Ideally, it's be great to swap out motors as needed to run this more often, but curious what feedback anyone has on the topic.
Thanks!
draboyd19 is offline   Reply With Quote
Old 12-06-2016, 05:00 PM   #13937
Originally Posted by JAE View Post
Timing on the motor only. For 17.5. May I ask why you are adjusting timing on the ESC? If you are racing a class that allows timing, I would just get a cheap mod motor 7.5t-10.5t and never worry about tuning/optimizing an expensive stock motor
Yeah I figured that out after the fact. It was stock but I had no idea we weren't supposed to adjust the timing in the esc. I was so slow without any timing at all that I could barely clear the jumps. Also It isnt an expensive stock motor lol. It cost me 45 bucks on ebay.
jcsfearless is offline   Reply With Quote
Old 12-06-2016, 05:30 PM   #13938
JAE
Trader Rating: 26 (100%+)
Check your motor timing is not backwards. Still doesn't work get a new $90 fantom or reedy. If your esc doesn't have blinkyvget a $50 just-stock. Never seen anyone race a castle so don't know it runs blinky
JAE is offline   Reply With Quote
Old 12-06-2016, 08:05 PM   #13939
Trader Rating: 16 (100%+)
Thanks!
I think I can help you with this. I ran a 10.5 tekin on a kyosho scr-sp with MIP plastic 1st gen plastic style puck slipper for over a year. Besides wearing out the plastic pucks more often then my rb6 running 17.5 with plastic pucks, it held up just fine. Your rb6 will hold up to the r10 no prob with aluminum pucks. And that motor is not too much motor for a the rb6 buggy. But with any mod motor the faster speeds and higher torque will cause more wear and tear and the crashes are generally harder. Causing more broken parts. I have had my rb6 with 17.5 for over a year and i have only broken 1 front arm. That is the 1 and only broken part. And I hit a wall on a fast straight so there was saying good reason for the break.
On a side note. I did have a few detailed conversations with Matt, owner of MIP about running puck system with mod motor. He felt that as long as you didn't go lower than a 10 turn motor it would perform fine. Which for me it has.
Hope that helps.
rocdog is offline   Reply With Quote
Old 12-07-2016, 07:48 AM   #13940
draboyd19's Avatar
Hope that helps.
Exactly the type of response I was looking to get - thank you! Very helpful.
Old 12-07-2016, 09:20 PM   #13941
Last edited by metalry101; 12-07-2016 at 09:22 PM. Reason: wrong thread. stupid mobile site
metalry101 is offline   Reply With Quote
Old 12-10-2016, 09:57 AM   #13942
tsair's Avatar
How is the wear/slop of the Kyosho RB6/.6 cars? Associated used to be pretty bad, but the B6 is much improved. TLR is pretty poor IMO. Do Kyosho parts stay nice and tight over time?
I'm thinking of getting the RB6.6 as a complement/stand-up 3-gear to my laydown B6 for when the track is looser.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 12-10-2016, 10:53 AM   #13943
JAE
I have a 6.6 standup. Has the best cornerspeed and steering of any of the standups I've had (b6, xb2, b5m)great choice. Much less slop than associated including the b6. Very hard plastics
Old 12-10-2016, 01:54 PM   #13944
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 12-11-2016, 07:23 PM   #13945
JAE
Anyone have tips on making changes to the caster inserts? Broke a spindle and track only had exotek aluminum ones. They do not come with inserts. I cannot get my old 0 degree out of the broken spindle. So will be trying the 2 degree caster insert. Had questions on general caster settings anyhow. Anyone know how to get these out, have experience with exotek aluminum c hubs and just general tips/experiences with making changes at the c hub? Thx all
Old 12-11-2016, 08:54 PM   #13946
Jack Smash's Avatar
The inserts are tight but they can usually be forced out of the stock caster block. I put the caster block over something that has a hollow spot like the webbing of an A-Arm to push tap them out. The inserts arent all that tight going into the exotek caster block, but they have a small grub screw to secure them.
Old 12-11-2016, 09:26 PM   #13947
JAE
Exotek worthwhile? Thinking of just waiting for the carbon ones to be in stock. Wondering also how much weight this will add. Running stock this thing is a little porky but worth all the weight
Old 12-11-2016, 10:48 PM   #13948
Jack Smash's Avatar
Only real need for the aluminum ones would be if you have an issue breaking the regular ones. I wouldn't do the carbon ones as they are the most fragile.
Old 12-12-2016, 08:07 AM   #13949
skrichter's Avatar
Send a message via AIM to skrichter
Can anyone tell me which Kyosho wing this would be? Jared has been running it for quite some time (Reedy Race and his most recent race at Speed RC). You can see where the wing has a slight molded 'T' marking to help for alignment. It could be part# LA239, LA240, or LA241?
Part # would be appreciated! Thx!
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 12-12-2016, 08:10 AM   #13950
skrichter's Avatar
Another view of the wing -- from this weekend at JC race @Speed RC
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22941 Today 04:55 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
