    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 11-19-2016, 12:20 PM   #13891
would this car be good for a beginner to racing off road competitively, or is it too much for someone new?
FreeBandz is offline   Reply With Quote
Old 11-19-2016, 01:02 PM   #13892
oPAULo's Avatar
My son and I each started with RB6's. I'm still surprised at the durability. I would recommend the aluminum front arm holder though. Not because they break but they get warped and twisted and it's sometimes hard to tell. If you start with a used buggy, take it all apart and check everything. Especially check the hinge pins for straightness and be sure there is no binding. I would do this with any used buggy.
oPAULo is offline   Reply With Quote
Old 11-19-2016, 09:39 PM   #13893
likea45's Avatar
Originally Posted by JAE View Post
I've got 1.6 2 hole front pistons. For the rear, on hand, I've got either 1.6 2 hole or 1.4 3 hole. Running med to high bite clay in stock. Which rears do every one recommend? Thx
[/QUOTE]
I have the 1.4 3 hole in my wheeler and they are good with heavier weight oil but I'd go with the 1.6x2 on the 2wd.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 11-19-2016, 10:15 PM   #13894
JAE
Trader Rating: 26 (100%+)
Thx!!! What oil and springs for 1.6 2 hole all around? Kyosho shocks feel so much stiffer than competitors (are, xray, etc) with the same oil and spring rates.
I have the 1.4 3 hole in my wheeler and they are good with heavier weight oil but I'd go with the 1.6x2 on the 2wd.[/QUOTE]
JAE is offline   Reply With Quote
Old 11-20-2016, 10:01 AM   #13895
oPAULo's Avatar
Used to race a lot of oval back in the early 90's and the only thing I kept was a sprint car chassis that I made way back then. Local track runs offroad and oval and I had a old RB6 laying around soooo...
Old 11-20-2016, 09:36 PM   #13896
likea45's Avatar
Depending on your track conditions, for medium bite clay I'd go 32.5F, 30R with kit pink front spring and kit gold rear. For higher grip, I go up in oil 35/32.5 etc and go one softer on front spring still run the gold rear. Hope this helps.
Old 11-25-2016, 02:54 PM   #13897
HotRod127's Avatar
Trader Rating: 14 (100%+)
I had to dig a little bit for this thread....... Page 3? Yikes! I'm not digging that! Lets get it rolling here a little more guys. Anyway, I've been a TLR guy my whole life and decided to make a huge switch. Built this bad mamma jamma over this last weekend and ran it for the first time this last Wed. I'm a lost of words on how good this car is. By far the smoothest out of the box and the quality is over the top. I can't say enough....
Kyosho RB6.6/ Kyosho ZX6.6/ Kyosho RT6/ Kyosho America- Peak Racing Products- Team Orion- AKA
HotRod127 is offline   Reply With Quote
Old 11-25-2016, 05:47 PM   #13898
How good is this car with laydown tranny installed on clay vs Losi or the B6d with laydown. Going shopping
Rcforlife13 is offline   Reply With Quote
Old 11-25-2016, 06:28 PM   #13899
JAE
I like it better than my b6d laydown. more aggressive steering, better suspension, equal traction,jumps a little lower which could be good or bad.
Old 11-25-2016, 06:33 PM   #13900
So u had both and raced both
Old 11-25-2016, 07:30 PM   #13901
JAE
I actively race both.
Old 11-25-2016, 07:40 PM   #13902
HotRod127's Avatar
I put the 3 gear laydown in the RB6.6 right off the bat and I love it. I have a little bit of Tebo's surf city setup in it and a little bit of my own based off the track I run only cuz I didn't know what to expect never owning a Kyosho. This car worked right off the bat.
Now the TLR 22 3.0 laydown I just had not too long ago was really good too, but it just was never consistent to me or my driving style. It felt like I was always trying to find something better, or it pushed too much or it had no forward bite. It was always one thing or another.
First night racing the RB6.6 and I was confident with it, way more consistent, easier to drive and I was way faster with it first night than I was weeks with the TLR. I didn't have to really work that hard or stay on my toes like the TLR.
I have drove the B6 3 gear laydown that other guys at my track have enough to know that on power with the shocks forward is a little different to get used to and there are just way too many things that you need to do to make that car work, flat arm this, gull wing this, or gull wing tower here, shim the bulkhead this or do that, dremel this. Just build it, throw a setup on it and go and that's what the RB6.6 is good for in my opinion.
I don't want to start a war or anything so hopefully nobody takes offense, but this is just clearly my opinion.
Old 11-26-2016, 12:52 AM   #13903
JAE
Anyone running a front wing? Wanted to try one but don't know if need a mount? Thx
Old 11-26-2016, 05:08 AM   #13904
tobamiester's Avatar
Trader Rating: 275 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Yup I run the Proline one some race days. See the wiki above.
tobamiester is offline   Reply With Quote
Old 11-26-2016, 07:10 AM   #13905
HotRod127's Avatar
Ive been running the JC front wing.You don't need a mount for that!
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22941 Today 04:55 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
