    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 11-01-2016, 08:22 AM   #13846
Michael#81's Avatar
Trader Rating: 254 (100%+)
Originally Posted by dmatter View Post
Kyosho using bleeder caps on the new cars?
Nope. Same shocks as they have had for a few years now that bleed through the bottom. IMO easiest shock to bleed on the market and stays consistent so much longer.
Michael Malott
Michael#81 is offline   Reply With Quote
Old 11-01-2016, 08:33 AM   #13847
dmatter's Avatar
Gotcha
dmatter is offline   Reply With Quote
Old 11-01-2016, 02:54 PM   #13848
JAE
Trader Rating: 28 (100%+)
Pm me if anyone wants to sell an rb6.6
JAE
JAE is offline   Reply With Quote
Old 11-01-2016, 07:21 PM   #13849
TravisS27's Avatar
Trader Rating: 25 (100%+)
Originally Posted by jrz93 View Post
whats good starting point for 17.5? 72/30? and will ae spurs work as all my lhs have?
If your running 17.5 I'd use a 69 spur...I don't remember what we ran for pinions on our 17.5 cars but I wanna say 32 on bigger open tracks and 31 on smaller tight tracks.
Yes, you can use AE spur gears but you have to use the AE slipper pads as well. The Kyosho slipper plates will work with AE spurs/slipper pads
AKA Tires
BOOMrc Graphics
Exotek Racing
RickyRacer Lidz
Jake's RC Topeka KS
TravisS27 is offline   Reply With Quote
Old 11-01-2016, 07:25 PM   #13850
TravisS27's Avatar
Originally Posted by oPAULo View Post
Haven't heard it mentioned but there's 3 options for mounting the rear tower with a laydown transmission.
Despite what everyone says, you CAN use the original RB6 rear bulkhead with the laydown tranny. This is how you run the shocks on the rear of the tower and rear of the a arms.
Use the taller 6.6 bulkhead to run the shocks on the front of the shock tower and rear of the a arms
Use the smaller one to mount the tower directly to the diff case to run the shocks on the front of the a arms....this is for high bite tracks/carpet/turf
AKA Tires
BOOMrc Graphics
Exotek Racing
RickyRacer Lidz
Jake's RC Topeka KS
Old 11-02-2016, 02:37 AM   #13851
I am wondering for high bite tracks like carpet/turf if its better to use 3 or 4 gears in laydown car layout using for mod like 6.5T.
thanks
lynx75 is offline   Reply With Quote
Old 11-02-2016, 03:25 AM   #13852
TravisS27's Avatar
thanks
Probably 3 gear. We run 4 gear on med bite dirt and med-hi bite clay
Old 11-03-2016, 07:13 PM   #13853
thanks
In the video at the beginning of this thread about the RB6.6 they recommend the 3 gear laydown for high bite carpet/turf tracks.
jcsfearless is offline   Reply With Quote
Old 11-04-2016, 02:45 PM   #13854
Thanks @traviss27 and @jcs
I will build the kit during the Xmas break :-)
Old 11-05-2016, 02:35 AM   #13855
JAE
3 hole rear Pistons: anyone running these? I ordered VRP 2 hole 1.6 front and 3 hole rears at recommendation of VRP. Thought I would try it out. I'm running th 3 gear laydown and am worried it may produce too much back and I'll lose read grip. Thought I would ask her before rebuilding shocks. Thx much
Old 11-07-2016, 09:15 AM   #13856
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Smile
JAE, I know we talked about this a bit but I figured it might be worth discussing on the forums too.
Shocks are one of the more difficult beasts in RC tuning, IMHO. Fluid Dynamics is no joke
If you have a lot of air in the shocks, this will change the dampening quite a bit.
Most of the SoCal tracks have fairly large jumps, OCRC, SCVRC, and LRH, definitely do, although sometimes the double single is better. Given the larger jumps I have found i need to stay in the middle of the 2 or 3 hole spectrum if I can call it that. I have experimented with 4 hole too, but found 2 and 3 to be better on most indoor clay conditions that I've had the time to test on. Currently I'm running 1.3x3 VRP with 400CST KYO FR/1.6x2 with 350CST KYO RR. My medium grip car (standup transmission) has 300CST with 1.6x2 all around. I've tested 1.3x3 in the rear as well, but found I preferred to have the pack of 1.6x2 to keep from bottoming out as often. If I ran 1.3x3 I'd probably run 350CST instead of 300.
In general, when I go to a thicker oil, I will go to the next step larger piston, to Accommodate the change in viscosity. For example if I am running 1.x6x2 with 350, I will switch to the 1.3x3 with 400. This way I can achieve similar pack, with a higher static dampening.
When it comes to piston sizing I think the VRP chart is pretty helpful, since it gives a progression in terms of piston sizing. Should be attached here.
I hope I was able to achieve some clarity here. Let me know if I can help!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 11-07-2016, 08:13 PM   #13857
Very helpful information
SCserfur is offline   Reply With Quote
Old 11-07-2016, 09:01 PM   #13858
Anyone had a chance to try these new proline positron tires yet? Just curious, looking at tire choices for my build and thought these might fit the bill. Right now dirtwebs are money.
Old 11-08-2016, 11:14 AM   #13859
Hi everyone,
I'm at a bit of a crossroads. I have been a Kyosho guy for many years. I currently have the RB6 and a TKI3. I am deciding between the Associated B6 with a ball diff and 3 gear laydown configuration, or the RB6.6. The track I race at is an indoor high bite clay. Typically slicks are run or very little pin. The fastest racers at my track run the Associated B6 in the 3 gear laydown configuration.
For high bite clay which transmission configuration is considered to be the fastest for the Kyosho RB6.6? From what I have been reading on this thread most people are running the four gear, but at my track the Associated B6 with a 3 gear laydown and ball diff is by far faster than the four gear.
Payton 34 is offline   Reply With Quote
Old 11-08-2016, 11:20 AM   #13860
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
Originally Posted by Payton 34 View Post
Hi everyone,
My track is a medium/high bite track and as of last Saturday I went with the 3 gear laydown. It was possibly the best car I have driven in a while. And I am a die hard K car guy.
motorfinger is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Today 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
