    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 10-15-2016, 04:27 PM   #13816
Trader Rating: 137 (100%+)
Originally Posted by 13Maschine View Post
John, do you want my setup? I haven't had it over to LRH lately but it's been to OCRC and SCVRC with good results so far. I'm planning to come over to LRH soon too. LMK.
Sure i'll take a look, but normally when I travel to other tracks from LRH, I need to change a lot in setup. But its worth a look. I just am basically interested to know what shock oil and springs people are using. The kit doesnt feel right.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-15-2016, 04:29 PM   #13817
Has anyone had experience running the Avid slipper with mod? Or the Schelle, they are very similar. Given the overall size of the slipper pads and plates, I wonder if the stock slipper plates would be better with a larger surface area. Most of the surfaces I race on are medium to high bite clay. I've been experimenting with two red pads, and one white, and I've also tried using the FR4 pads for the avid setup. I'm thinking FR4 pads with the vented KYO slipper plates might last longer with less fade.
I never liked the schelle slipper in mod for that very reason. those pads get hot. I stick with stock slippers in all my mod cars. Only run aftermarket in stock to reduce weight.
Old 10-15-2016, 06:22 PM   #13818
bdyche's Avatar
Send a message via ICQ to bdyche Send a message via AIM to bdyche Send a message via Yahoo to bdyche
Originally Posted by lynx75 View Post
@bdyche
Would you please give me further details on this part of the information?
...especially if you use some option parts such as aluminum rear hangers. A little bit of searching online helped me with that.
thanks
The aluminum hangers have a chart in the package that shows what to run to achieve what degree of toe. Comparing that to a couple of Tebo setup sheets helped.
Tacoma RC Raceway /// Mike's RC World (RIP) /// Skagit River Raceway /// DieHard RC
Kyosho America /// Maclan Racing /// Xpert RC /// AKA /// Pro-Match Racing /// Stuck On Racing (SOR)
Maclan Racing Northwest Region Team Manager
bdyche is offline   Reply With Quote
Old 10-15-2016, 08:28 PM   #13819
oPAULo's Avatar
6.6 chassis is 40 grams heavier than a 6.0 lightweight chassis.
oPAULo is offline   Reply With Quote
Old 10-15-2016, 10:25 PM   #13820
BOOSTN's Avatar
Originally Posted by hairymuffin View Post
To run a long pack,you will need to use the esc mount that comes in the kit,and your Rx on the side of chassis,you have more options using a shorty pack
I found that I can't run the esc on the shelf because my body doesn't clear it. I dunno I'll try post a few photos soon.
BOOSTN is offline   Reply With Quote
Old 10-16-2016, 04:53 AM   #13821
BOOSTN's Avatar
This is the only way I can run a long pack, does it look alright?
Old 10-16-2016, 06:29 AM   #13822
oPAULo's Avatar
I've seen guys mount the speed control on the battery strap where it will fit under the cab of the body. Then you could move the battery all the way back. You might also mount the speed control on it side against the servo to make space.
What you have might be fine though. It just looks like a lot of weight on the front end.
Old 10-16-2016, 08:26 AM   #13823
oPAULo's Avatar
The main part of a 6.6 chassis is .010" thicker than a standard 6.0 chassis. Guys running a laydown in a 6.0 might take note of this because the mounting surfaces are different. You should run a .3mm shim under the front mounting screws to match the 6.6 chassis.
I know it's not much and might not make a difference. Just pointing it out.
Old 10-16-2016, 08:43 AM   #13824
oPAULo's Avatar
I honestly don't believe the 6.6 chassis has more flex than a 6.0. Especially one that has been modified for sideways battery. This thing is thicker and heavier and more rigid.
I feel like reducing chassis flex is their goal because the only use for the block on the battery strap as far as I can tell is to limit chassis flex.
Now I really don't want to mill this lightweight chassis because it is so thin I'm afraid it will fold into a taco...
Old 10-16-2016, 09:25 AM   #13825
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Smile
Thanks John, I haven't done the math but I thought perhaps since the KYO slipper is only 2 pads, the avid might be close with 3. This is one of the things I like on the Xray, the stock slipper is a massive three pad system.
I agree, LRH to OCRC to SCVRC I usually want to change a bit. SCVRC has such high traction, if I was still racing there often I'd have some pretty major changes. Surprisingly LRH to OCRC wasn't as drastic for me. The RB6.6 is so well balanced that changing tires got me 90% there. I didn't change my shock package or springs. The real test will be when I come back to LRH.
My shock package is:
Front:
Gold Springs (I ran Red at SCVRC)
400 KYO/1.3x3 VRP Pistons
Rear:
350 KYO/1.6x2 VRP Pistons
Gold Springs
I should note that my lap times aren't quite on pace at OCRC yet, but perhaps that's me. It is close though, I can get into the mid to high 19seconds on the surf city layout. Plenty of guys in the 18s range though. I think my slipper was part of my issue here, lots of fade.
Can you PM me your email? I'll send you a full setup sheet. The Chris Jarousz setup is also very good. I hope I spelled that right.
Let me know if I can help
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 10-18-2016, 04:05 PM   #13826
oPAULo's Avatar
Finally starting my 6.6 build. 2 full sets of ball cups!? Who does that? I keep hearing that KYO is too expensive but Kashima coated shocks in the box? C'mon.... that's quality.
They need to pony up and get Tessman or Rivken or Phend on board and see how popular they become.
Old 10-18-2016, 05:42 PM   #13827
oPAULo's Avatar
Haha! Made it all the way to step 2!!
The instructions are all kinds of screwed up when you add the aluminum steering rack and support....
Looks like you ditch the 1mm shims under the rack to run the support and shim to feel? The instructions with the support show the 1mm spacers above the rack. Seems like the shims should be under the rack otherwise the arms rub on the bulkhead.
I wonder how the steering geometry is truly intended to be or if it really matters....
Old 10-18-2016, 08:17 PM   #13828
thecman26's Avatar
Trader Rating: 99 (100%+)
Actually Kyosho calls them velvet coated, been including them in kits for years, since the RB5 that is at least.
Kyosho has a pretty talented team, that Tebo guy comes to mind, TQ at worlds. Many many others, Matt Chambers, Joe Pillars, Chris Jarosz, Cody King, Elliott Boots, and Naoto Matsukura just to name a few.
Kyosho is in good hands!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 10-19-2016, 01:59 AM   #13829
Front:
Rear:
Gold Springs
Stock setup with 32.5 front/30 rear, stock springs, ballstud collars, everything is stock and the car is really good. Everyone who has driven it likes how balanced it is as a laydown car. I rear mounted the shocks cause the rear end gets skiddish on clay witht hem mounted front, but the car is stock, and is very good. I may not change much at all for the time being since i'm not travelling to run anywhere else for the next few months.
Old 10-19-2016, 03:27 AM   #13830
oPAULo's Avatar
Oh I agree and I'm a huge fan of all of them but you can't deny that Kyosho's presence in 1/10 scale offroad in the USA is lacking.
You know how kids are. They want to be like the cool kids. They buy what the cool kids have. Cody King is our only cool kid in the top 25 and he's a 1/8 scale specialist.
Tebo is my favorite driver but it's partly because I'm also a dad and not a cool kid....
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
