    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 10-10-2016, 09:25 AM   #13801
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Originally Posted by cnelson3 View Post
anyone tried this car with the sway bars. a friend of mine with a different car ran both front and rear sway bars this last race day. I haven't tried them yet but i have a set on the way. curious if anyone else tried the sways?
I've tried the rear sway bar in 1.1mm size at OCRC. Lately the grip has been pretty high and I thought this might help get me through the sweeper a bit faster, and keep from traction rolling. There's a small roller in the sweeper too, which is what made me take my sway bar back off again, as it would make the car jump sideways a bit at speed through the sweeper with the roller.
I will probably try it again on Wednesday at SCVRC as we typically run slicks, so the traction is VERY high.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 10-10-2016, 01:07 PM   #13802
Originally Posted by 13Maschine View Post
@lynx: I love my RB6.6, best 2WD buggy I've driven so far. I think you will too! Please let us know if we can help you get dialed.
Thank you. I will let you know my first impression. Keep you posted
lynx75 is offline   Reply With Quote
Old 10-10-2016, 09:46 PM   #13803
likea45's Avatar
Originally Posted by BOOSTN View Post
I tried 69/30 and that seems to be working well. I took that motor out and put a speed passion 17.5 in and it isn't as near as hot as the lrp so I dunno might've been the motor on its way out.
I don't have a temp gun I was just going off my finger. After 10 laps I couldn't hold my finger on the lrp but after I put the speed passion in it was just warm not hot after another 10 laps, even the esc was cooler. Either way I found what I'm looking for anyway thanks for the help.
I had an older motor that was starting to do that and once replaced I never looked back. Glad you found a solution.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 10-11-2016, 07:17 PM   #13804
JAE
Trader Rating: 28 (100%+)
it appears the kit setting is with the shorter links on the outside hole of the front shock tower? Ran it this way just to try it and buggy has been great. Moved to the middle hole, matching the fact that the rear is as well, and figuring it would tame the steering, give it a more even radius, and make the cornering a more natural progression. Unlike other buggies, lengthening the link made the buggy harder to control and it seemed to be losing cornering grip. Seemed to get out of control. Perhaps the cornering grip was not as good as the camber gain was reduced. Nevertheless I've never had a buggy harder to control with shorter links.
Anyone have any practical knowledge of testing the length/height of the camber links? I'm certain this is different between buggies which is why I'm asking about experience in particular with this buggy and not a theoretical general answer
JAE is offline   Reply With Quote
Old 10-13-2016, 02:46 AM   #13805
Hi All,
are you aware of if the RB 6.6 and ZX 6.6 car build reviews have been made on the Internet please? I cannot finding anything.
Old 10-13-2016, 07:16 AM   #13806
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
The ZX6.6 hasn't made it to the shores here in the U.S.
The build of the RB6.6 is similar to the RB6 if you built one in the past. You now have the different transmission options which means more bags to open to get a few parts out of it before you set it aside again.
If you are going to run the laydown transmission the case is warped a little bit, at least on mine it was. Once you bolt it all together it spins free so that should not be a problem.
Let us know if you have any specific questions.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-13-2016, 08:14 AM   #13807
bdyche's Avatar
Send a message via ICQ to bdyche Send a message via AIM to bdyche Send a message via Yahoo to bdyche
Originally Posted by lynx75 View Post
Hi All,
In typical Kyosho fashion the manual has some things that are lost in translation, especially if you use some option parts such as aluminum rear hangers. A little bit of searching online helped me with that. The manual doesn't give directions for 4 gear laydown, but it is self explanatory. Overall I'd rate it at a 7/10 for build experience. Not to the level of Durango, but it had all of the parts, which is better than some.
Build quality is a 8/10. The transmission case (laydown) is warped, but it goes together fine and runs free. Plastic ball stud washers are kind of a joke for a $400 kit, but a couple of 0.5/1.0/2.0mm washer packs for <$5 fixed that. Plastic lower shock eyelet inserts are disappointing as I haven't ever had a kit that wasn't metal, but they haven't been a problem yet.
Value in the box is a 8/10. I purchased this car to run on carpet with pin tires 3x a month and high bite clay for a monthly series. The only required upgrade parts were a gear diff (~$30 with the aluminum cap).
As far as non-essential parts go, I also purchased gold and red front springs and white rear springs ($60 total) to suit my track. For the sake of building it once and not having to upgrade later I added the aluminum rear hangers and aluminum hubs, but I wouldn't say those are required to make the car work. To make working on the car easier I will be upgrading to Lunsford ball studs so I can use a 2.0mm driver vs a 5.5mm.
Durability is typical Kyosho - 7/10. You may not get away with some crashes that a TLR or AE might, but you don't have to worry about it breaking randomly. Wear will be good as it uses the same material as the RB6.
Overall a solid 8.5/10 - the best value on the market for someone who races on multiple surfaces and only wants one car.
bdyche is offline   Reply With Quote
Old 10-13-2016, 01:35 PM   #13808
@Kraig and @bdyche I wanna thank you So much.
I will keep you posted in case of support. I will build my new kit with laydown trasmission to be used on carpet and astroturf.
Old 10-14-2016, 06:31 AM   #13809
@bdyche
Would you please give me further details on this part of the information?
...especially if you use some option parts such as aluminum rear hangers. A little bit of searching online helped me with that.
thanks
Old 10-14-2016, 09:04 PM   #13810
Trader Rating: 137 (100%+)
Looking for a setup for high traction tight indoor clay. Got a 6.6 in a trade for my B6.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-14-2016, 11:52 PM   #13811
13Maschine's Avatar
John, do you want my setup? I haven't had it over to LRH lately but it's been to OCRC and SCVRC with good results so far. I'm planning to come over to LRH soon too. LMK.
Old 10-15-2016, 03:16 AM   #13812
BOOSTN's Avatar
Is anyone here running rear motor with a standard size 2S pack?
I'm interested in seeing how you've run you're electrics.
BOOSTN is offline   Reply With Quote
Old 10-15-2016, 11:17 AM   #13813
13Maschine's Avatar
Has anyone had experience running the Avid slipper with mod? Or the Schelle, they are very similar. Given the overall size of the slipper pads and plates, I wonder if the stock slipper plates would be better with a larger surface area. Most of the surfaces I race on are medium to high bite clay. I've been experimenting with two red pads, and one white, and I've also tried using the FR4 pads for the avid setup. I'm thinking FR4 pads with the vented KYO slipper plates might last longer with less fade.
Old 10-15-2016, 11:24 AM   #13814
Well it's a shorty but this is what I've got.
Can anyone tell me the difference in the front kick up C mount vs the B mount?
Scott Smither is offline   Reply With Quote
Old 10-15-2016, 11:44 AM   #13815
hairymuffin's Avatar
Trader Rating: 93 (100%+)
To run a long pack,you will need to use the esc mount that comes in the kit,and your Rx on the side of chassis,you have more options using a shorty pack
hairymuffin is online now   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
