    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 09-24-2016, 06:03 AM   #13726
Originally Posted by JAE View Post
How's the traction in laydown form on this buggy? Any comparison to the xray, yokomo, or b6 laydowns? Want to know if I should be planning to take away weight in some places and needing to add in others once I get mine. thx
Lots!! Run the car twice so far.. First time out not so good as issues with electrics and a servo fail but second time out was much better!
Was running on high grip Astro in 3 gear laydown layout and was constantly trying to loose grip! The car has loads of drive, to help rotation I ran the gear diff and the only weight I had in it was the front brass hinge pin holder. The only other options were the ally rear hangers. Spent about 4 hours and have a good dry high grip set up
You won't be disappointed!
njc11 is offline   Reply With Quote
Old 09-24-2016, 07:09 AM   #13727
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
hey guys can you point me to post about updating an rb6 to a 6.6?
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 09-24-2016, 06:30 PM   #13728
tobamiester's Avatar
Trader Rating: 275 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
See Wiki above. Also put a post here
tobamiester is offline   Reply With Quote
Old 09-24-2016, 08:19 PM   #13729
JAE
Trader Rating: 26 (100%+)
Looks like tebo ran his at surfcity at OcRC laydown with shocks in front. Can't seem to find that setup. Anyone have it or a laydown setup for med/high bite clay with shocks in front?
Thx
JAE is online now   Reply With Quote
Old 09-24-2016, 10:09 PM   #13730
534
Default Rb6.6
Thx
I'm running my rb6.6 with lay down 3 gear,with a little weight up front , 22 ride height, shocks in front , high bight clay , running a 7.0 motor car is dialed.
534 is offline   Reply With Quote
Old 09-25-2016, 12:08 AM   #13731
JAE
Thx! What springs? On paper Kyosho pink front is very soft and coupled with a gold rear seems different than what a lot of other manufacturers do with their spring setups out of the box.
What are good spring combos? For laydown
Old 09-25-2016, 06:44 AM   #13732
symmetricon's Avatar
Trader Rating: 27 (100%+)
gold front and rear, the laydown configuration still has tons of rear grip...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 09-25-2016, 11:56 AM   #13733
Potoczak's Avatar
Trader Rating: 111 (100%+)
What oil and Pistons are you running in your shocks??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 09-25-2016, 03:20 PM   #13734
Guys, I'm running 20.3mm shock length front shocks and stripped the piston shaft out of the eyelet (Long) twice this Friday. This happened to another guy also. Any ideas other than running a shorter shock length ?
Old 09-25-2016, 05:13 PM   #13735
Could someone please tell me what the spring rate is in lbs. for the pink kyosho big bore front springs?
Thomas2225 is offline   Reply With Quote
Old 09-25-2016, 05:50 PM   #13736
oPAULo's Avatar
What tower are you running?
It's my understanding that the Tebo tower is longer and takes away droop. The stock tower allows the same droop with more shaft in the eyelet. Kiddo and I run 20mm and rarely break one even as rough on equipment as we are.
Are you tapping the eyelet? I wouldn't do that either.
oPAULo is offline   Reply With Quote
Old 09-25-2016, 06:28 PM   #13737
Running Tebo's HRS setup (mostly) with stock tower. Not taping eyelet.
Old 09-25-2016, 06:58 PM   #13738
oPAULo's Avatar
Tebo is running Tebo towers so with stock towers you have more droop than he did.
Tire diameter also effects droop. What was his tire diameter? Do you measure droop and adjust shock length when you change tires?
Wish I could be more help. I'm not sure I'm good enough to feel .3mm of shock length, which is approximately the thickness of 4 human hairs or .012 of an inch. It's not much.
One old racing adage comes to mind.
To finish first, you must first finish.
Run that eyelet on there so it won't come off and find another adjustment to make it do what you want.
Or, do we need a longer front shock shaft? It's not super hard to make a front shaft from a rear. There are plenty of manufacturers that run the same diameter shaft if we could find one slightly longer.
Old 09-26-2016, 02:19 AM   #13739
eper's Avatar
Trader Rating: 14 (100%+)
Are u guys running shims tonr move droop?
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 09-26-2016, 02:31 AM   #13740
JsK
JsK's Avatar
site.petitrc.com/reglages/BuggyBigBoreSpring.pdf
JsK is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
