    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 09-11-2016, 09:02 PM   #13681
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Smile RB6.6 Laydown Battery strap?
http://site.petitrc.com/setup/kyosho...ctronicsSetup/Does anyone know which battery strap this is?
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 09-11-2016, 09:50 PM   #13682
oPAULo's Avatar
Originally Posted by RMKinWI View Post
How do you determine the antisquat degree to number/size spacer under the rear arm hangers/blocks?
For example 1mm spacer under the RR block and 0.5mm spacer under RF block equals what antisquat degree?
Start reading at post #12885.
And you don't run shims under the RF holder.
oPAULo is offline   Reply With Quote
Old 09-11-2016, 09:57 PM   #13683
oPAULo's Avatar
Originally Posted by TravisS27 View Post
I'm sure this has been asked but I couldn't find it anywhere.
Do I have to run a laydown in my RB6 to use the 6.6 body or will it work with my stand up 3-gear?
The 6.6 comes with a standup 3 gear.
Old 09-12-2016, 06:18 AM   #13684
There is a good antisquat chart on petit rc for the RB6.
You can run up to a 1mm shim under the RF block with the laydown, I'm currently running one
http://model-car-racer.co.uk/
Today AE .. tomorrow who knows?
RogerM is offline   Reply With Quote
Old 09-12-2016, 08:36 AM   #13685
oPAULo's Avatar
Good info!!
Thank you.
Old 09-12-2016, 09:02 AM   #13686
13Maschine's Avatar
Tebo's chart is backwards.
Thanks oPaulo!
Last edited by 13Maschine; 09-12-2016 at 10:28 AM. Reason: removed for clarity (tebo's chart is backwards)
Old 09-12-2016, 09:37 AM   #13687
oPAULo's Avatar
Originally Posted by 13Maschine View Post
Tebo also has a decent chart for anti squat. Although it doesn't reference running a shim under the RF...Are you trying to achieve a higher roll center with this setup? Are you running no shims under the RR and thick and thin under the bulkhead?
https://jtprc.com/2015/11/29/jtp-sho...b6-rear-tower/
We've discussed Tebo's chart before and how he has it backwards.
I searched petit and still can't find any reference to running shims under the RF block. Never seen it on a setup sheet either.
I'm not saying you can't or shouldn't. I'm just curious about why. Is that much more anti-squat a benefit on certain surfaces? It moves the roll center?
Old 09-12-2016, 09:55 AM   #13688
13Maschine's Avatar
Roger Mills discussing shims under RF:
http://site.petitrc.com/setup/kyosho...eedback201209/
Old 09-12-2016, 10:38 AM   #13689
oPAULo's Avatar
Thank you sir.
Looks like he was on carpet or turf.
Old 09-12-2016, 03:17 PM   #13690
TravisS27's Avatar
Trader Rating: 25 (100%+)
Haha good point! I wasn't thinking lol
TravisS27 is offline   Reply With Quote
Old 09-12-2016, 04:01 PM   #13691
TravisS27's Avatar
Anyone have a body on pic of your 6.6 with 3 gear stand-up?
Old 09-13-2016, 06:41 AM   #13692
Indeed, in the UK it's 99% astroturf or carpet.
Same principles apply to any surface ;
Overall pin higher = more natural rotation & more on power steering @ expense of off power sidebite.
Low pin the opposite.
More antisquat = less weight transfer on/off power so more on power steering & a little more instantaneous traction as you get on the gas at the expense of on power sidebite & ability to accelerate through bumps.
Less total antisquat the opposite.
As a rule of thumb if grip high & track smooth then increase both.
In 30+ years I've never seen a sugared dirt track but if you are running slicks you should be running high pin & loads of antisquat
Old 09-13-2016, 05:44 PM   #13693
13Maschine's Avatar
On the latest setup sheets, they reference shims under the RF and RR both.
Old 09-13-2016, 05:49 PM   #13694
oPAULo's Avatar
Some excellent info here.
Thanks for sharing!
I'm going to try more anti-squat next time out because I do notice that I'm really hooked up on power and have to blip off the throttle to make it steer.
Old 09-18-2016, 08:31 PM   #13695
ttr_racer's Avatar
Trader Rating: 23 (100%+)
Cannot anyone help with a baseline indoor clay med-high traction setup for a 6.6?
ttr_racer is online now   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Today 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
