    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 09-06-2016, 02:18 PM   #13666
oPAULo's Avatar
Muahahahaaaaa
oPAULo is offline   Reply With Quote
Old 09-06-2016, 02:21 PM   #13667
oPAULo's Avatar
The new RF arm hanger IS the old RF arm hanger with a notch milled it it. They didn't even bother to re-anodize it after they took the old ones and milled them....
Old 09-06-2016, 02:58 PM   #13668
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
You don't see the shiny silver once it is installed in the car anyway.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-06-2016, 03:08 PM   #13669
oPAULo's Avatar
Oh it doesn't bother me. Just pointing it out. A little filing on the old one and your good to go.
This new 6.6 is the kiddo's and I'm not allowed to crack the seal without him. Guess I'll just work on my old 6.0 hoopty.
Old 09-06-2016, 11:00 PM   #13670
likea45's Avatar
Originally Posted by teeforb View Post
Did you lose any grip? How does it perform compared to stock arms?
No performance change was noted to the negative. I used these parts to shave weight in a very competitive stock buggy class in my area.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 09-08-2016, 12:23 AM   #13671
ProfessorX's Avatar
Trader Rating: 17 (100%+)
He just wants to show off I have the same kit and I don't bothering posting it what for. ������������
ProfessorX is offline   Reply With Quote
Old 09-08-2016, 02:45 AM   #13672
oPAULo's Avatar
You are 100% correct sir! This is my first ever new kit and I'm VERY excited!
To my son and I, this hobby is everything.
Old 09-09-2016, 09:59 AM   #13673
Trader Rating: 5 (86%+)
this is my first rb6.6 kit and I was wondering what is a good alternative for some steel bushings that are a direct fit.
Smithracer11 is offline   Reply With Quote
Old 09-09-2016, 12:12 PM   #13674
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Are they doing an rt6.6?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 09-09-2016, 05:45 PM   #13675
Super Moderator
Kraig's Avatar
Originally Posted by Smithracer11 View Post
this is my first rb6.6 kit and I was wondering what is a good alternative to replace the plastic shock bushings with metal?
Metal on metal, most likely aluminum on aluminum will cause wear. You may want to look at the exotek parts. I don't have personal experience with them but maybe someone else does and can chime in.
Old 09-10-2016, 08:54 AM   #13676
Originally Posted by motobigalow View Post
Does anyone know if someone makes a precut chassis protector for the 6.6 chassis, I'm never happy with my end results cutting one myself
My GF works at UpgradeRC, the company that manufactures the chassis skins for Schelle, and she is fitting the original skins on her 6.6. The way they made the chassis wider most likely will not work with a wider skin. It probably will not stick to the contours since it changes angles twice in such a small area. I think they are going to test it, but she thinks the skins will remain unchanged.
ericschlaifer is offline   Reply With Quote
Old 09-10-2016, 08:43 PM   #13677
RMKinWI's Avatar
Trader Rating: 15 (100%+)
How do you determine the antisquat degree to number/size spacer under the rear arm hangers/blocks?
For example 1mm spacer under the RR block and 0.5mm spacer under RF block equals what antisquat degree?
Matthew Lust
www.WisconsinSurplus.com
RMKinWI is offline   Reply With Quote
Old 09-11-2016, 09:42 AM   #13678
TravisS27's Avatar
Trader Rating: 25 (100%+)
I'm sure this has been asked but I couldn't find it anywhere.
Do I have to run a laydown in my RB6 to use the 6.6 body or will it work with my stand up 3-gear?
AKA Tires
BOOMrc Graphics
Exotek Racing
RickyRacer Lidz
Jake's RC Topeka KS
TravisS27 is offline   Reply With Quote
Old 09-11-2016, 07:33 PM   #13679
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Thumbs up
I am not sure I understand what you mean. I have both cars, and comparing side by side they are very similar in shape. The new RB6.6 chassis is simply wider, with a similar angle of chamfer at the edges to the older chassis. I'm not sure I can get a proper angle in the pictures, without disassembling my cars. but hope these help.
Kyosho Ultima RB6 & RB6.6 Car Thread-img_1583-1-.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-img_1594.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-img_1598-1-.jpg
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 09-11-2016, 07:54 PM   #13680
13Maschine's Avatar
Anyone want to suggest a carbon fiber battery strap for the laydown config? The Mckune is a bit long. Pictures if you can Thanks!
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
