    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 09-02-2016, 04:41 PM   #13651
Trader Rating: 60 (100%+)
for those running a front wing, what mounts are you using?
Sorry should say what wing mounts up correctly not seeing an option for the rb6.6 or rb6? Am I just missing it
This one time at rc camp............
Rb6, rb6.6, rt6, sc6, and lots and lots of shelf queens
motobigalow is offline   Reply With Quote
Old 09-02-2016, 05:18 PM   #13652
dmcguire's Avatar
Trader Rating: 21 (100%+)
I ran a jconcepts finnisher wing made for the B5, mounted via the to shock mounts. Just have to line up The holes.
Other way I ran it was by running a 4mm longer bottom shock tower screw (the one that mounts the tower to the bulkhead) and 4mm with of spacers. You then mount the wing in front of the tower, with the back of the wing screwed to it.
dmcguire is offline   Reply With Quote
Old 09-02-2016, 05:41 PM   #13653
JN2 Desgines wing mounts. I know the guy personally and have used his mounts with good results.
-Ryan-
TLR 22 4.0SR
CTRJ is offline   Reply With Quote
Old 09-02-2016, 07:02 PM   #13654
tobamiester's Avatar
Trader Rating: 278 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Check the wiki up top, pro-line one listed.
tobamiester is offline   Reply With Quote
Old 09-03-2016, 05:05 PM   #13655
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Anyone use the composite arms for the rb6? Thoughts? Worth it? What about the composite shock towers?
Thx
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 09-03-2016, 10:37 PM   #13656
I run all composite parts in my second RB6 which I only use on carpet/astro. These parts are lighter and flex less so I have found that help the way the car handles on high traction surface.
They are also lighter so if you run stock you will lose a couple og grams too
nitroargi is offline   Reply With Quote
Old 09-03-2016, 11:05 PM   #13657
teeforb's Avatar
How's the durability? This will be for med- high bite clay track.
Old 09-04-2016, 09:21 PM   #13658
likea45's Avatar
I run on that exact surface with all composite parts and haven't had a single issue. Also I don't crash much either which helps.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 09-04-2016, 09:26 PM   #13659
teeforb's Avatar
Did you lose any grip? How does it perform compared to stock arms?
Old 09-04-2016, 09:59 PM   #13660
ProfessorX's Avatar
Trader Rating: 17 (100%+)
Can I use the rb6 upgrades like exotek front shock tower And all Kyosho aluminum upgrades. ????
ProfessorX is offline   Reply With Quote
Old 09-05-2016, 06:30 AM   #13661
Everything should work. Main changes are in the transmission options.
heyscottn is offline   Reply With Quote
Old 09-05-2016, 01:34 PM   #13662
ProfessorX's Avatar
One more thing will it change the geamatry ??
Old 09-06-2016, 11:05 AM   #13663
I'm not sure about your exact question, but probably no. The chassis changed slightly (the sides and side rails), but as far as I know all of the geometry is the same.
Old 09-06-2016, 12:19 PM   #13664
teeforb's Avatar
everything is the same... just a long chassis. Front end, zero change. rear end, zero change except laydown w/ FR suspension hold and option or 3 gear.
Old 09-06-2016, 12:21 PM   #13665
Chassis length didn't change.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Yesterday 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
