    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 10-10-2012, 03:32 PM   #1351
is the Avid Triad slipper clutch going to be all that?
it sounds so.
how many of you build multiple tranny's for back ups?
i was thinking iam going to do a couple for sheets(s%!#) and giggles
emsrolling along
Eric Summers is offline   Reply With Quote
Old 10-10-2012, 03:33 PM   #1352
Trader Rating: 137 (100%+)
Originally Posted by t8rtot View Post
there was an amendment page in there, i'm having no issues.
what is the smallest KYO spur i can buy, or what is the recommended gearing for 17.5 non-boosted?
thank you
Kimbrough 69 tooth spur, AE pads and 31 tooth pinion to start. Im running comfortably with the Kevlar Losi 70 tooth spur and 33 tooth pinion, motor doesn't get past 120 degrees ever. And its fast
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-10-2012, 03:35 PM   #1353
it sounds so.
emsrolling along
I built a triad slipper for my brothers b4 and I can tell you this. It is super simple to get a perfect amount of slip, much less work then setting the stock slipper on his B4.
Old 10-10-2012, 03:39 PM   #1354
it sounds so.
emsrolling along
I have 3 spare diffs ready to go. One of the benefits to running all Kyosho cars, If I need to swap a diff it's quick and easy.
Jason.Dias is offline   Reply With Quote
Old 10-10-2012, 04:07 PM   #1355
Posted up my setup sheet for those interested.
http://jasondias.com/2012/10/10/rb6-...st-rc-raceway/
Old 10-10-2012, 04:11 PM   #1356
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Thanks Jason. I will try it at SDRC.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 10-10-2012, 04:18 PM   #1357
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
The avid slipper will be the way to go. Was told that the current slipper design is locked 90% of the time and only actually slips on the face of jumps. I have one on my b4.1 and you can definitely tell a difference from the stock dual disk setup.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-10-2012, 04:31 PM   #1358
Thankyou you guys,
they said somethn' about 3 weeks for our builds w/ Avid slipper
can't wait.
anyway i got to get this out of my head--------------
Page 18
17 section
18 part is LAW39 (page 40) Steel Sus. Bush (8pcs) i found only four(4) to my kit
now from what i see we only need four(4).
once again i'm double checkn'
Old 10-10-2012, 04:38 PM   #1359
Oh Jason Dias your car looks like rocket science ---
iam about to cut body out as soon as i quit finding errors in this damn manual
Old 10-10-2012, 04:55 PM   #1360
Trader Rating: 1069 (100%+)
Here are pics of my setup. I run futaba RXes, so I looped the antenna over between 2 of the antenna placement holes. Had to mount it on top of the battery as the RS pro that is in there has a relatively short wire and I'm going to be experimenting with batteries and placement anyway... Has CF strap and .5 rear carriers due running outdoors. Will have the japan base setup by friday night!
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 10-10-2012, 04:55 PM   #1361
silvalis's Avatar
Trader Rating: 29 (100%+)
Thankyou you guys,
can't wait.
Page 18
17 section
You only need 4 on the buggy.
If you buy a pack you get 8. Two complete sets.
Buying spares is different to what is included in the kit.
I think you need to go to sleep
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 10-10-2012, 05:36 PM   #1362
ZZZZZZZzzzzzzzzz............. where's the sleepy face icon?
Old 10-10-2012, 05:49 PM   #1363
fastestwon's Avatar
Trader Rating: 15 (94%+)
Default my setup
for those of you who want a good clay tight track setup
http://www.petitrc.com/setup/kyosho/...Hobbies201210/
fastestwon is offline   Reply With Quote
Old 10-10-2012, 06:35 PM   #1364
silvalis's Avatar
So do you think that 3.5 toe is necessary for outdoors?
Old 10-10-2012, 06:48 PM   #1365
gelshocker's Avatar
Originally Posted by eper View Post
maybe you have the caster inserts in wrong or something i built the links per manual and when the car was finished i put it in a hudy setup station and it was dead nuts
Sorry for the interruption, I can't let this one go
I probably shouldn't ask this: are your front inner ball studs on the outside hole? I have them in the middle. Caster inserts per manual (0 deg). And I did not get the left and right mixed up
When you say it's dead middle on the hudy, I believe you, as it was with my rb5. Set up per manual, never had to touch them until the ball cups wore out. I don't run front toe-out. If all else fails I'll go with what's worked for me: whatever works. Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22955 Today 12:08 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
