    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 08-21-2016, 01:54 PM   #13606
chriso138's Avatar
Ok, so I ordered the new 6.6 . Does the kit come with the aluminum rf hanger for the lay down tranny?
Also, is there anything else the kit needs to complete? I already have the aluminum steering rack and aluminum rear hubs. Is there anything else that people are getting?
chriso138 is offline   Reply With Quote
Old 08-21-2016, 06:48 PM   #13607
tobamiester's Avatar
Trader Rating: 274 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
No it doesn't.
Also get the Alum RR hanger.
tobamiester is offline   Reply With Quote
Old 08-21-2016, 09:53 PM   #13608
Default Kyosho Rb6 metal idler
Looking for a hardened metal idler for my RB6 or SC6 I've got a aluminum one but looking for steel if anyone has any insight on one please help.
Thanks Travis Hammond
Trav515 is offline   Reply With Quote
Old 08-22-2016, 07:45 AM   #13609
Send a message via AIM to David Alberico Send a message via Yahoo to David Alberico
Hey all, I don't post too much here but if you ran the 3 gear RB6, I would seriously look at going to the laydown 4 gear setup. I had a similar shock package to my 3 gear execpt the alum front arm mount instead of brass. Car felt very balanced and I had better laptimes, and more comfortable to hit brakes.
Castle Creations, J-Concepts, WMD Products, Clints Creations
David Alberico is offline   Reply With Quote
Old 08-22-2016, 10:51 AM   #13610
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by toepush View Post
Kraig what are you running at trackside. 6-6.6? And what trans?
Lately I have been using another manufacturer's car. I just broke out the 6.6 last Saturday for a few trial runs and decided to bolt a 7.5 in it. It has the laydown 4 gear transmission in it. Imo, the rear rolls to much in the corner so I need to work on that. Otherwise, it is very smooth and easy to drive.
My kids car is a regular 6 with a converted 3 gear transmission and sideways battery. He will get a 6.6 eventually.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 08-22-2016, 01:32 PM   #13611
Trader Rating: 24 (100%+)
Does anyone know if the Schelle / Avid slipper will fit under the laydown gear cover? Thanks.
fenton06 is offline   Reply With Quote
Old 08-22-2016, 01:42 PM   #13612
Well laydown uses same diff/topshaft as standup so I wouldn't see any reason why they wouldn't work.
Old 08-22-2016, 03:06 PM   #13613
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
YES IT DOES! I've installed my avid setup and it fits great as long as you don't use the spacer on the top shaft between the slipper plates and top bearing. otherwise the slipper assembly is pushed out too far.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 08-22-2016, 04:10 PM   #13614
oPAULo's Avatar
Anyone have a 6 lightweight chassis they'd like to part with? Scratched up is fine as long as it's not bent.
oPAULo is offline   Reply With Quote
Old 08-22-2016, 04:31 PM   #13615
I do. its pretty fugly and 'dremeled' for transverse (not by me).
Old 08-22-2016, 04:39 PM   #13616
oPAULo's Avatar
I should add, not milled flat. That might be waaay too much flex. Thanks though Tobe! Appreciate the offer.
Old 08-22-2016, 07:28 PM   #13617
bdemegs's Avatar
Trader Rating: 18 (100%+)
I do, and it has zero use on it. I just took out of the package, installed it, then a few days later they released the 6.6 chassis. Didnt even stick the electronics to it.
bdemegs is offline   Reply With Quote
Old 08-22-2016, 07:48 PM   #13618
I knew the topshaft wuld work, I wasn't worried about that part
Thanks! Just what I needed to know. Would you mind snapping a pic?
Old 08-23-2016, 08:00 AM   #13619
13Maschine's Avatar
Smile
I went from my Xray XB2CE to the RB6.6 laydown (3gear) and I'm now selling my Xray.
The RB6 was awesome. This is another world.
Old 08-23-2016, 11:27 PM   #13620
Hey guys....has anyone tried to fit the side guards from the RB6.6 to the original RB6 chassis?
nitroargi is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
