    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 08-12-2016, 12:38 AM   #13591
Tobemeister thanks for the help.
Twisterdave is offline   Reply With Quote
Old 08-12-2016, 06:09 AM   #13592
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by BiLL77 View Post
What are the differences from 2015 rb6 and rb6.6 besides trans chassis and body?
The springs and shock pistons too if I remember correctly.
You can get most of the parts for the 6.6 except for the chassis. At least the first shipment here to the U.S. had the other parts.
The new parts are backwards compatible and no additional work is required to install them unless you want to run the laydown transmission. Then you have to add two holes to the 6 chassis.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 08-12-2016, 06:22 AM   #13593
tobamiester's Avatar
Trader Rating: 279 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
^^What he said.
Also, Rear Arms included have the extra hole UM713.
Most of the bits are listed here: http://www.kyoshoamerica.com/Replace...ts_c_1537.html
and here:
http://www.kyoshoamerica.com/Option-parts_c_1538.html
tobamiester is offline   Reply With Quote
Old 08-12-2016, 11:48 AM   #13594
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Has anyone replaced the drive pins on their drive shafts? Either with the HUDY or Mugen tool, or perhaps a vise, or worse pliers? I have the mugen tool, and I'm wondering which pins I should pick up. I don't want to cut my own, so I'd prefer pre cut. Thanks for the input! happy Friday all
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 08-12-2016, 09:22 PM   #13595
mjd
mjd's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Twisterdave View Post
Can we just use the standard chassis protector for the rb6.6?
I used a Scheele one from a SC6 and trimmed it to fit.
Thanks www.norcal-hobbies.com "The Race Place!", AKA, Prime and Team Powers
mjd is offline   Reply With Quote
Old 08-13-2016, 09:05 AM   #13596
RokleM's Avatar
Trader Rating: 33 (100%+)
I think those are 1/8th scale tools, I believe the pins are too small on a 1/10th, but worth checking. If someone can give me the pin dimensions on what you're talking about I can compare.
- Eric G. -
Tekno EB48.3, NB48.3, ET48.3, NT48.3, Kyosho RB6, RT6
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 08-13-2016, 11:43 AM   #13597
bdemegs's Avatar
Trader Rating: 18 (100%+)
I was able to order the chassis off of kyoshoamerica this morning. We'll see if i get any emails to the contrary from them
bdemegs is offline   Reply With Quote
Old 08-13-2016, 08:08 PM   #13598
13Maschine's Avatar
Smile
Xray recommend the HUDY pin tool for their 10th scale cars like the XB2. Pin size on the Kyosho seems to be 2x10mm.
Old 08-14-2016, 12:42 AM   #13599
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
I've used a Hudy tool a friend had and it works, he modded his tool a little for the smaller pins and broke it. There was just enough to get the old pin pushed out enough to get a new pin to line up. If you use that tool with a vice, you can control things better when pushing out/in pins. I use it with a small hammer to tap them out/in.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 08-14-2016, 10:19 PM   #13600
IRM616's Avatar
Trader Rating: 29 (100%+)
Send a message via Yahoo to IRM616
Hello my kyosho friends,
I am looking to convert my rb6 to a laydown transmission. With the rb6.6 out, can i use those part and it will be an exact fit? Also can you help me with all the parts I need.
I have an idea but want to be sure. Thank you in advance.
SikLidz Custom Rc Painting-Coyote RC Raceway-BSR-Kyosho
IRM616 is offline   Reply With Quote
Old 08-14-2016, 11:34 PM   #13601
Lay down tranny cases, lay down idler gear, lay down motor plate and gear cover, rear lay down bulkhead (if you plan to run the shocks on the front of the rear arms). That's pretty much the parts you need. Then you'll have to drill two holes in the regular RB6 chassis for the more forward waterfall brace. Then likely have to shave/grind/mill the chassis sides down more forward if you plan to run the battery sideways, along with modding the sideguards for battery clearance more forward as well. Lastly, you'll have to mod the rear front arm mount to fit under the lay down tranny cases, unless you get one f the new ones that's already milled down for clearance.
That should be all you need/need to do
J.Mikoliczyk
RB6 - MBX7R Eco
Old 08-15-2016, 02:07 AM   #13602
oPAULo's Avatar
You have to drill 4 holes. 2 for the waterfall and 2 for the forward screws in the laydown case. The laydown case has 4 screws through the chassis.
oPAULo is offline   Reply With Quote
Old 08-19-2016, 03:10 PM   #13603
Derry's Avatar
Trader Rating: 27 (100%+)
6.6 Chassis has been available on KyoshoAmerica for a week now but no where else in US. hope losi parts house gets some soon. Wondering how much they will be there.
Associated B64D
Associated B6D
Derry is offline   Reply With Quote
Old 08-19-2016, 03:17 PM   #13604
CCristo's Avatar
Trader Rating: 55 (100%+)
Check eBay. I picked one up today for far less than retail price.
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 08-19-2016, 04:26 PM   #13605
Trader Rating: 103 (98%+)
Kraig what are you running at trackside. 6-6.6? And what trans?
toepush is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Yesterday 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
