    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 07-31-2016, 07:32 AM   #13516
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by TravisS27 View Post
So, after I put my laydown in with the new rear bulkhead, you think I'll be able to use the new 6.6 body if/when it's available?
It should. You have different cut lines on the body when using the different transmissions.
Nothing for the 6.6 shows up on amain as of last night besides the kit itself
True, I look at Kyosho America for information. Sometimes the big fella's are a little slow at adding items to their site or maybe they were not informed and don't know anything about them yet.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 07-31-2016, 02:15 PM   #13517
TravisS27's Avatar
Trader Rating: 25 (100%+)
Cool! That new body will be a must have lol!
TravisS27 is offline   Reply With Quote
Old 07-31-2016, 07:58 PM   #13518
Suspended
Looks the the new rb6.6 is available. Does anyone know or think how well this new car is going to do on turf/astro?
Is the rz6 still the oneto go for if looking for a dedicated turf car?
chriso138 is offline   Reply With Quote
Old 07-31-2016, 10:27 PM   #13519
mjd
mjd's Avatar
Trader Rating: 23 (100%+)
So our track is a High bite clay track. I bought the NEW RB6.6. Do I want to run the Laydown transmission? or just the 3 gear?
I am still running a RB6 and rt6 and sc6 with the spur gear on the wrong side.
Thanks www.norcal-hobbies.com "The Race Place!", AKA, Prime and Team Powers
mjd is offline   Reply With Quote
Old 08-01-2016, 03:50 AM   #13520
TravisS27's Avatar
Originally Posted by mjd View Post
So our track is a High bite clay track. I want to run the Laydown transmission? I am still running a RB6 and rt6 and sc6 with the spur gear on the wrong side.
Rear Bulkheads:
UMW740 (includes mm3 and laydown)
Laydown:
trans case - UM736
40T idler - UM737
motor plate - UM738
gear cover - UM739
Old 08-01-2016, 07:33 PM   #13521
GIHOSU's Avatar
That is something we will have to figure out, what beats what. Could be a toss up.
You may have to try both to know what is better. I have a similar dilemma.
Same here, at my track the 4 gear MMs seem to be better but I am willing to try a 3 gear MM to know the difference. I just got the new Kyosho 3 gear parts (yup, I waited for factory stuff) and I am not sure about trying with mod or 17.5
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 17.5 Turf ~ RB6 17.5 ~ RB6 ~ RZ6 Turf ~ RT6 Turf ~ SC6 17.5 ~ SC6 ~ SC6 Turf ~ ST-RR Evo.2E
TEKNO - SCT-410 ~ SCT-410.3
GIHOSU is offline   Reply With Quote
Old 08-01-2016, 11:59 PM   #13522
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
Default New RB6.6
Got to hold a new 6.6 in hand this past Sunday,
Looked good, owner had it setup for 3gear lay down and was trying to get it finished to run, but didn't.
Some observations after getting my meat hooks on it:
New chassis and side guards are a little wider than the old car, but not by a ton. If running in 3gear or 4gear mm (not lay down) the old bodies will still fit on the new car. Sides are flared out just a slight bit,,but they do fit. Just in case anyone was wondering
New lay down motor plate and gear cover are both well done, motor plate is lightened up top behind the spur gear.
Lay down tranny case looks good and does appear like it could work for lay down 4gear, though the manual has zero info on that.
If you want to run the lay down tranny in the 3gear (or possibly 4gear) and want to mount the shocks on the rear of the arms like the old car, the old mm rear bulkhead will fit right on in place of the new one and you can move the shock tower back to a position like the old car. Only issue I saw between the two setups was rear wing mounts and relative location/position, it is different and noticeably so.
Other than those things I noticed, the car looks good and is well done. Didn't see much else different from the old car to new.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 08-02-2016, 12:06 AM   #13523
vikingen's Avatar
Trader Rating: 27 (100%+)
Mine arrived from ProShop today
vikingen is offline   Reply With Quote
Old 08-02-2016, 06:38 AM   #13524
DriveKyosho's Avatar
Trader Rating: 44 (100%+)
Am I miss understanding this? Jared has on his setup sheet that he's running a 4 gear lay down tranny
DriveKyosho is offline   Reply With Quote
Old 08-02-2016, 09:07 AM   #13525
Michael#81's Avatar
Trader Rating: 254 (100%+)
The laydown transmission can be either 3 or 4 gear. It says nothing about it in the manual but the trans case is already molded for either. The case it has all the holes in the molds to run either 3 gear or 4. You just have to have an extra idler gear laying around. Also notice on that setup sheet that he is running a gear diff with 2k oil.
Michael Malott
Michael#81 is offline   Reply With Quote
Old 08-02-2016, 09:21 AM   #13526
Michael#81's Avatar
I received my rb6.6 yesterday and started building it last night. The build was to be expected from Kyosho and went great. Never had to dremel or cut anything that wasn't unnecessary. The manual is a little different and you jump around a lot from bag to bag if you try to follow the manual. I have built a lot of Kyosho kits and they all seem to be this way so I knew that going in. I always lay everything out on my table anyways and arrange all the parts, nuts, and screws by front to back and by screw sizes so it is a little easier to just grab from a pile instead of searching through bags.
I built the car as a 4 gear laydown. In the manual it says to use the new laydown bulkhead. If you want to run Tebo's or Tanner Day's setups and run the shocks on the rear of the arms you will just need to use the original Mid Motor bulkhead as it bolts the tower up just fine and allows you to put the shocks on the rear of the arms. My car went together great. I did have to rob some of the aluminum parts from my old RB6 but other then that I am very pleased. I did dremel an older aluminum "c" block to make it work with the laydown transmission. It is not the prettiest but it gets the job done until I get the new piece in from Kyosho.
All in all the build was super smooth and the car went together awesome. I am trying the Tebo setup from Omaha on it as a base and will adjust from there to suit my track conditions.
Michael Malott
Old 08-02-2016, 10:06 AM   #13527
Super Moderator
Kraig's Avatar
Since you can build a stand up 4 gear motor you can use the idler gears from that to build a 4 gear laydown transmission.
I pointed out the points in the transmission case that I believe you will use if you were building it as a 4 gear unit.
You will want to use the new rear bulkhead pieces in UM740. There are two to choose from. If you want to mount the shocks on the back of the arms use #1 in the picture. Otherwise, you can use #2 for all other shock mounting position and not have the wings from #1 sticking up in the air.
Old 08-02-2016, 11:54 AM   #13528
oPAULo's Avatar
Did we confirm that it is not 13mm longer than the RB6?
oPAULo is offline   Reply With Quote
Old 08-02-2016, 02:40 PM   #13529
Holmberg418's Avatar
The chassis is the same length.
Kyosho America, Hobbywing, Jconcepts, Lunsford, JTP
Full Throttle R/C Raceway www.ftrcr.com
Holmberg418 is offline   Reply With Quote
Old 08-02-2016, 07:00 PM   #13530
Waiting for all the options parts and titanium screw set to come in before I build her.
I just hope it compares to my yz2.
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Today 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
M3CSLDreamin
