    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 10-10-2012, 11:10 AM   #1336
lbckevin's Avatar
Trader Rating: 91 (99%+)
Originally Posted by Jason.Dias View Post
Did you get an RB6 Kevin?
Yes....its on its way... may have it built by Sunday.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 10-10-2012, 12:57 PM   #1337
I love to hate building shocks.
FYI,Page 28
#42
161 is 163 small "o" ring
everyone got TWO (2) supplemental sheets?
whats with the servo saver shave? rubbn' some where? any other style or type to use ? does it make it weaker?
just curious.
ems
Eric Summers is offline   Reply With Quote
Old 10-10-2012, 01:12 PM   #1338
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
FYI,Page 28
#42
just curious.
ems
Iv built my kyosho shocks so many hundreds of times, I never even looked at the manual.
i did see where a trim is required to the upper bulkhead brace piece, but not the servo saver (the car doesn't have one). I just used my x-acto to shave off a mm or so so the steering rack clears properly. It looked like it was going to clear all by itself, but it only took 30 seconds so i just went ahead and did it.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-10-2012, 01:22 PM   #1339
Trader Rating: 1069 (100%+)
My plans for the battery holddown with screw down are simple:
1. Obtain gun metal nuts(on the way )
2. Measure and cut post to length using a precision light saber
3. Cut the head of a screw off that is long enough
4. Drill a hole to size for the screw to thread into the post
5. double nut the screw and thread it into the post inserting the cut off head side first so the good end of the screw will be sticking up.
Viola screw downs complete. You could make it easier if you had some long grub screws, but I don't so I'll just cut a screw...
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 10-10-2012, 01:25 PM   #1340
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Yea running stock, but lap time wise I am pretty close to the mod lap times, just harder to do those really fast laps back to back with traffic and battling.
http://mobile.liverc.com/results/?d=...T_(A_Main).xml
http://mobile.liverc.com/results/?d=...K_BUGGY_NT.xml
I am running the rb6 rear arms flipped to the 1 hole side. If you're using the stock pistons, I would run 37.5f 32.5r.
Yeah I ran the 1 hole to start. Im going to the track here in a bit when it opens. I suppose I can change the oil now and see how it does.
So stock setup based on the manual with that oil and 1 hole?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 10-10-2012, 01:30 PM   #1341
To Capt. America,
it was a 4x5 sheet accompanied with the other supp sheet, i believe the servo arm not a saver my mistake Page 13 #5.
yes i saw the front upper plate
supp sheet.
Modify Madness
but fun as can be.
Old 10-10-2012, 01:32 PM   #1342
ok i got to ask, what are Grub screws?
Old 10-10-2012, 01:34 PM   #1343
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
different name for set screw.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-10-2012, 01:38 PM   #1344
Trader Rating: 27 (100%+)
How are people liking the at with a shorty? Or does everyone like long?
Kyosho, Lunsford Racing, Express Motorsports, Dibrino Designs.
C_Money is offline   Reply With Quote
Old 10-10-2012, 01:41 PM   #1345
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Yeah, what he said? ^^^
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-10-2012, 01:49 PM   #1346
Super Moderator
To Capt. America,
supp sheet.
Modify Madness
but fun as can be.
hhmm.. I guess I overlooked that (i did get a small insert like that). I didn't see anything about shaving the servo horn... Mine doesn't hit anywhere though.
- RCSpecialties -
Old 10-10-2012, 01:54 PM   #1347
it was a small (i say shave ) on one side of the ball cup sides
Old 10-10-2012, 03:51 PM   #1348
CanyonCarverR1's Avatar
What is the purpose of this?
CanyonCarverR1 is offline   Reply With Quote
Old 10-10-2012, 03:58 PM   #1349
t8rtot's Avatar
Trader Rating: 14 (94%+)
there was an amendment page in there, i'm having no issues.
what is the smallest KYO spur i can buy, or what is the recommended gearing for 17.5 non-boosted?
thank you
Sfida
t8rtot is offline   Reply With Quote
Old 10-10-2012, 04:00 PM   #1350
Super Moderator
thank you
Personally, I don't like the kyosho spurs because they are a tad noisy. I am a HUGE fan of the Kimbrough spur gears, and run nothing else. All you need are standard AE slipper pads and a Kimbrough spur, and you are set. Nothing is as quiet, or as true/round.
With a revtech based motor with the endbell timing cranked, I run 31/69 on an 90f x 50f indoor clay track.
http://www.fantomracing.com/proddeta...prod=FAN27917S
http://www.amainhobbies.com/product_...ipper-Gear-69T
http://www.amainhobbies.com/product_...pper-Pad-B4-T4
(edit: I know this doesn't actually answer your question, its just my suggestion as I don't run K spurs )
- RCSpecialties -
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22977 11-13-2017 05:09 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
