    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 07-27-2016, 11:23 AM   #13471
Trader Rating: 24 (100%+)
Originally Posted by TravisS27 View Post
I'm interested in running Kyosho brand diffs in my RB6, do we only need the diff case and rear bulkhead?
Rear Bulkheads:
UMW740 (includes mm3 and laydown)
3 Gear:
trans case - UM734
gear cover - UM75
Laydown: <-- ASSuming needs new chassis or holes drilled
trans case - UM736
40T idler - UM737
motor plate - UM738
gear cover - UM739
Will edit wiki...
EDIT: Wiki updated and formatted..ish
fenton06 is offline   Reply With Quote
Old 07-27-2016, 06:07 PM   #13472
Trader Rating: 6 (88%+)
Does anyone know if there is a shim In the kit that allows you to move the rear tower back and run the shocks on the back of the tower when using the laydown transmission? I know Tebo is running his shocks on the rear of the tower with the laydown on clay, but I did not see the option in the manual. I Thought maybe someone in here had some insight.
Chase Spears
_____________________________________
| Rb6 MM | Rb6 | ZX5 FS2 SP | SCTE 2.0
Roni45 is offline   Reply With Quote
Old 07-27-2016, 06:19 PM   #13473
oPAULo's Avatar
Looks like you could run the other bulkhead with the laydown to get the shocks to the rear of the arms.
oPAULo is offline   Reply With Quote
Old 07-27-2016, 06:24 PM   #13474
Which other bulkhead? Did I miss something in the manual?
Chase Spears
Old 07-27-2016, 06:29 PM   #13475
oPAULo's Avatar
There's 2 rear bulkheads. New style and old style. Looks like the new laydown transmission will key into the old style bulkhead with shocks out back.
Old 07-27-2016, 06:32 PM   #13476
GIHOSU's Avatar
The manual (pg. 33) has the shocks mounted to the rear in the 4 gear mid and RM setups, you will be able to choose front or back. Shim your shocks so they are at a 90' angle to the arms and you should be good, as per Tebo.
I just ordered a couple of the new 3 gear gear box sets and the reverse gear covers, should be lots of fun when they get here. Thanks for the heads up Toby.
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 17.5 Turf ~ RB6 17.5 ~ RB6 ~ RZ6 Turf ~ RT6 Turf ~ SC6 17.5 ~ SC6 ~ SC6 Turf ~ ST-RR Evo.2E
TEKNO - SCT-410 ~ SCT-410.3
GIHOSU is offline   Reply With Quote
Old 07-27-2016, 07:07 PM   #13477
GIHOSU's Avatar
Yup, UM740...
You will need it to run LD or 3 gear mid.
Old 07-27-2016, 07:13 PM   #13478
TravisS27's Avatar
Trader Rating: 25 (100%+)
After studying the manual and my spare chassis, this looks to be the only difference in the two chassis'. Just drill out those two holes for the front of the diff case and your ready for a laydown tranny.
Also looks like the laydown uses the same UM740 bulkhead as the 3 gear.
Are these parts available yet? Also, does the laydown use the same ball diff gear, idler and top shaft as the other diffs? Same as the RB6 diff internals?
TravisS27 is offline   Reply With Quote
Old 07-27-2016, 07:49 PM   #13479
GIHOSU's Avatar
Yup, add 2 holes to the chassis, the LD gear box, 40t idler gear, LD motor plate and LD gear cover. They are available. The internals are the same except for the 40t.
Old 07-27-2016, 08:07 PM   #13480
foampervert's Avatar
Send a message via MSN to foampervert
Default Elongate two holes
Actually, you prolly need to enlarge the two holes (for mounting the battery cradle) in the regular rb6 chassis. In the rb6.6, they are used to mount the waterfall in the laydown gearbox position. However, the waterfall holes are just very slightly wider (or narrower... I can't remember) then the battery cradle holes.
Personally, I don't mind drilling new holes, I don't mind enlarging holes, but countersinking an enlarged hole is annoyingly difficult without a mill and a setting plate.
And of Coz, drill the two holes for the laydown gearbox itself.
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 07-27-2016, 08:12 PM   #13481
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Are folks drilling because the chassis isn't available?
When will the chassis be available?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 07-27-2016, 08:30 PM   #13482
TravisS27's Avatar
I'm sure it's available, that's just a significant added cost to upgrading to a laydown with your existing RB6
Old 07-27-2016, 08:31 PM   #13483
TravisS27's Avatar
Anyone have experience ordering from Kyosho's website? Do the parts ship from the US or overseas?
Old 07-27-2016, 08:44 PM   #13484
Holmberg418's Avatar
Ships from California.
Kyosho America, Lunsford, Stickit1racing, Jconcepts, JTP
Full Throttle R/C Raceway www.ftrcr.com
510 Raceway
Holmberg418 is offline   Reply With Quote
Old 07-27-2016, 08:58 PM   #13485
TravisS27's Avatar
Thanks!
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
JAE
