    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 07-16-2016, 08:19 PM   #13411
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
https://www.amainhobbies.com/kyosho-...34302b/p523452
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 07-16-2016, 10:11 PM   #13412
GIHOSU's Avatar
Originally Posted by foampervert View Post
They always think Ima cheating, cos everything looks so nice and neat.
Actually, I always think I'm cheating too!
I do like a battery forward position on a regular/old/2012 rb6 in 4 gear mid motor... Car seems the best balanced... With a normal shorty, I'll still get quite a bit of on power push, out of corners.
The guys at my track think stuff is missing. With low profile servos, tiny or combo Rxs and wire hiding channels there is no help for the uninformed. I am a lonely K car in a sea of Losi and TA racers. I hope some will come back for the 6.6. The first time I was accused of cheating I knew I was getting faster
Motor, ESC and battery from back to front has been good for me.
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 17.5 Turf ~ RB6 17.5 ~ RB6 ~ RZ6 Turf ~ RT6 Turf ~ SC6 17.5 ~ SC6 ~ SC6 Turf ~ ST-RR Evo.2E
TEKNO - SCT-410 ~ SCT-410.3
GIHOSU is offline   Reply With Quote
Old 07-17-2016, 12:55 AM   #13413
yodace's Avatar
R/C Tech Charter Subscriber
I am running on avtight indoor loose track. I set up the rb6 with a 3 gear transmission and a mixture of tebo's fastlane setup and reedy setups. With electrons. Buggys is loose everywhere ?
yodace is offline   Reply With Quote
Old 07-17-2016, 06:51 AM   #13414
foampervert's Avatar
Send a message via MSN to foampervert
Default Almost bought a
I had a first gen b4 which I raced till I got myself a rb5, which I raced till I got a rb6 in 2012 at $650!
I almost bought the ae b6 and I am delighted to get the rb6.6 instead. I've always enjoyed the kyosho cars for the fine fit and finish... But the pricing is killer!
I can understand why a lot of peeps prefer tlr or ae cos they are priced more economically. I believe the cars are well designed, but I like kyosho...
foampervert is offline   Reply With Quote
Old 07-17-2016, 09:36 AM   #13415
Trader Rating: 16 (100%+)
What's your rear track width? Is your battery sideways. Are you using McCune brace? Post your setup. This car make a ton of steering. Sometimes the rb6 can steer past what some can hold on to. Is it loose or does it rotate?
Cfconcrete is offline   Reply With Quote
Old 07-17-2016, 04:11 PM   #13416
Just getting back into racing after a long absence, and I'm very interested in this car. If I needed to buy extra parts in case of breakage, what would you recommend? Any help on this is greatly appreciated, Dave.
Twisterdave is offline   Reply With Quote
Old 07-17-2016, 04:39 PM   #13417
oPAULo's Avatar
I have 2 RB6's and my 11 year old son runs one of them, hard. A few things I've replaced, a few times.
Rear arms
Rear inner and outer hinge pins
Front arm mount
Front inner hinge pins
Wing mounts, bend easily.
Front hub carrier but it's rare.
Had a few bent rear shock shafts because they're on the back of the buggy so they take the hits.
I think once in a year and a half we've broken one front arm.
I would recommend,
Aluminum front arm mount
Aluminum rear arm mounts
Aluminum rear hubs
Aluminum wing mounts
oPAULo is offline   Reply With Quote
Old 07-17-2016, 05:05 PM   #13418
oPAULo, thanks for the quick reply. I'll start making a list with the parts you suggested. Do you think a turn buckle kit for the rb6 will be all right for the newer car? I'm trying to get as much of the parts in as I can before the new car comes out.
Old 07-17-2016, 05:28 PM   #13419
oPAULo's Avatar
I don't think they changed the tie rods or ball cups. Ya have some extra ball cups too. I've never broken or bent a stock tie rod. Broke 2 titanuim tie rods and went back to stock.
Old 07-17-2016, 06:57 PM   #13420
GIHOSU's Avatar
Just goes to show, you get what you pay for... My Kyosho racing started long ago and took a detour to keep up with sponsorship changes. I went from managing an on-road team to wrenching for an off-road team in the blink of an eye. When that faded away I went back to Kyosho because of the part quality and stayed off-road. Now the only things that break are just my fault.
Old 07-18-2016, 08:11 AM   #13421
skrichter's Avatar
Send a message via AIM to skrichter
I posted on FB as well but, it appears Tebo is running a 4 gear laydown tranny. I didn't see the option in the manual. I think this would be a nice setup option for med/high bite dirt, who want to run a laydown tranny. Hopefully more grip with a 4 gear vs. 3 gear.
Hopefully KYO will release it -- it might push me over the edge to try my first K-Car.
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 07-18-2016, 08:28 AM   #13422
the kit DOES come with a 4 gear laydown tranny... there just isnt instructions to build one in the manual.
You'll quickly figure this one out, once you've bought the kit...
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
Old 07-18-2016, 08:32 AM   #13423
Rear arms
Front arm mount
I would recommend,
Aluminum rear hubs
I like the Yaiba front suspension mounts the BEST! makes most sense, of all the aftermarket alu or brass mounts. Why cant hopup makers put in some brainwork when making hopups? instead of just making an alu or brass version of the original part...
after wrenching the rb5 for years, the yaiba front suspension mount was a huge and welcomed innovation I just had to transplant to to the rb6.
Old 07-18-2016, 08:34 AM   #13424
skrichter's Avatar
It appears you could be right -- there are mold/bosses for what appears to allow multiple idler gears within the laydown case.
Old 07-18-2016, 05:07 PM   #13425
Do it. You won't be disappointed. Best in the business.
Deff_not_Norm is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22977 11-13-2017 05:09 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
