Kyosho Ultima RB6 & RB6.6 Car Thread
they say the chassis is +13mm longer ? at 285
longer that what ??
my rb6 is 283 ....
longer that what ??
my rb6 is 283 ....
Super Moderator
When they introduced the RB6 they mentioned the changes between it and the RB5. My guess is that they left some of those changes in the RB6.6 information even though they didn't change it in the RB6.6.
MSRP is 639.99. Don't know what Map is yet
Hopefully someone has some time to put a parts list together for those that are just upgrading. ;-)
Super Moderator
$399.99.
One thing that they don't talk about but looking at the manual it appears you can run a 4 gear laydown transmission like Tanner is currently using.
Plus, with the 3 gear transmission the wing now mounts behind what I am calling the rear bulkhead. That should make it easier to get access to the inner ballstuds. I am curious if you could run a three gear laydown with the wing in that position, something tells me you can but I won't know for sure until someone confirms.
Super Moderator
um732 chassis guards, side plate
um731 main chassis
um734 RF2L suspension mount, plastic
um736 RF2L suspension mount, plastic laydown motor plate spacer
um733 battery strap
um741 battery foam
um735 3 gear mid motor gear cover
um740 rear bulkhead
um734 3 gear mid motor plate spacer and transmission case
um739 laydown tranmission gear cover
um738 laydown motor plate
um736 laydown trasmission case
um728 sponge tape
um737 laydown idler gear
Super Moderator
Trader Rating: 31 (100%+)
I think my buddy Kraig just needs to create an "official" (such a dumb term) RB6.6 thread.
IMO
IMO
I started adding stuff to the Wiki...
Super Moderator
This is what I came up with but feel free to add. These are my descriptions just to give you an idea as to what the part number is.
um731 main chassis
um733 battery strap
um741 battery foam
um740 rear bulkhead
um728 sponge tape
um731 main chassis
um733 battery strap
um741 battery foam
um740 rear bulkhead
um728 sponge tape
Based on that list, it might be economical to convert from a 6 to a 6.6 - just need suspension mount, bulkhead, choice of transmission, chassis, side plates, and battery strap. What's a good estimate for those, maybe $200?
Super Moderator
Track down the prices and let us know vs. asking..
I tried a couple of the big vendors as well as google, no luck.
