    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-10-2012, 04:24 AM   #1321
Moderator
Posvar's Avatar
Trader Rating: 461 (100%+)
Starting my build tonight!!!
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-10-2012, 05:59 AM   #1322
Trader Rating: 1069 (100%+)
Originally Posted by Eric Summers View Post
Package tags say "Always the Best"
Too bad the manual isn't.
I called Kyosho on that and they agreed LOL. The "proper" way to install the shock bushing is to use the 4.8mm and crush them, but I see that as a little errrr queer at best. I'm gonna use the 5.8s I have and cut them to the same size.
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 10-10-2012, 06:09 AM   #1323
silvalis's Avatar
Trader Rating: 29 (100%+)
First race meet with the RB6, team japan setup with pink/red, changed to pink/gold and ifmar pins and the buggy was a dream to drive.
I notice that it tends to nosedive a bit. Nothing wrong with that, but didn't expect it on the first jump, dug the nose into the dirt and had to fight my way back from last to 2nd. I also notice that with my current setup (team japan, pink/gold, 35/30 oil, silver losi wide ribs/red pins) steering is good under power but if i let off a bit and the weight transfers back to the front, the fronts grab a bit and the rear gets a bit loose.
I'm going to fiddle with the shocks a bit, currently on 35/30wt f/r, might change to 40/35 or 40/40 as the rear is still a bit bouncy on my bumpy track. Any comments on slowing down the rear?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 10-10-2012, 06:23 AM   #1324
can't believe I beat you building it... I'm running saddles to start out with. I'll post some pics tonight when I get done with the wire clean up.
Old 10-10-2012, 08:04 AM   #1325
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by cantrell8 View Post
your going to need all the practice you can get, competitions is going to be high this weekend!
oh i know it! But, it has come down the wire here, building, wiring and painting the car. I don't think im going to see clay until friday at TRCR. It's ok though, team Matesa is supposed to be saving me a spot at the Kyosho table
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-10-2012, 08:05 AM   #1326
just got mine should i boil some of the plastic parts to make it stronger?
hollywood7 is offline   Reply With Quote
Old 10-10-2012, 08:05 AM   #1327
Super Moderator
Nope, the car will be money right out of the bx
- RCSpecialties -
Old 10-10-2012, 08:32 AM   #1328
Super Moderator
Bitchen!... make sure to take a photo of your final build with your electronics layout.
- RCSpecialties -
Old 10-10-2012, 08:58 AM   #1329
Derry's Avatar
Trader Rating: 27 (100%+)
Here is my layout..
Associated B64D
Associated B6D
Derry is offline   Reply With Quote
Old 10-10-2012, 09:30 AM   #1330
t8rtot's Avatar
Trader Rating: 14 (94%+)
are your wires going over your wing mount? weird camera angle?
Sfida
t8rtot is offline   Reply With Quote
Old 10-10-2012, 09:36 AM   #1331
Derry's Avatar
in between. Yeah, that angle does make it look over.
Associated B64D
Associated B6D
Old 10-10-2012, 09:52 AM   #1332
gas1313's Avatar
Trader Rating: 18 (100%+)
Default Rims
Does the rb5 rims fit the car front and rear! Sorry if this has been ask but did not see it! Thanks
gas1313 is offline   Reply With Quote
Old 10-10-2012, 09:53 AM   #1333
Moderator
Posvar's Avatar
Will do Brandon! Gonna be neat and tidy!
Old 10-10-2012, 09:56 AM   #1334
Moderator
Posvar's Avatar
Yes on the rims!!!
Old 10-10-2012, 10:04 AM   #1335
DeanV's Avatar
Finished mine over the weekend. The plastic battery posts with clips just irked me, so yesterday morning I modified the battery holder to accept my aluminum posts. Since I am running the standard lipo, I have a spare battery holder just in case I need to go back
Starting with the Japan setup with two minor changes. 0 degrees in the caster block (instead of 4) and .5 degree rear hubs (instead of 0).
Dean
Kyosho Ultima RB6 & RB6.6 Car Thread-2012-10-06_15-34-18_972_1024x768.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-2012-10-06_15-59-14_880_1024x768.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-2012-10-06_15-59-30_215_1024x768.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-2012-10-09_10-22-03_612_1024x768.jpg
ARC R11
XRAY T4 VTA
XRAY X12 2016
DeanV is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
