    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 06-15-2016, 02:00 PM   #13321
ProfessorX's Avatar
Trader Rating: 17 (100%+)
Watching
ProfessorX is offline   Reply With Quote
Old 06-15-2016, 03:59 PM   #13322
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I am thinking that with all of the talk about the RZ6 that maybe I should change the title to include it? If you object, post here. If you are ok with the name change I will do it on Friday.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-16-2016, 10:58 AM   #13323
Actually a new thread is way better. Nothing worse than buying a car and having to figure out how many pages deep the new version started. I think especially with the RZ6 it will get confusing and annoying. Maybe a link to the RZ6 with a short description on the first page of this thread.
scoobyrs25 is offline   Reply With Quote
Old 06-16-2016, 11:35 AM   #13324
raz14's Avatar
I agree. A new thread for the RZ6 will encourage more collaboration specific to this model and reduce confusion between the 2 cars.
Just finished my RZ6 build and it's going to be the rainy day car. My old cannibalized RB5 provided the BB shocks along with raiding spares, a few new bits. That allowed me to keep my real dirt RB6s intact.
Looking forward to throwing it down on the track.
Chris
Kyosho Ultima RB6/RT6/RZ6
raz14 is offline   Reply With Quote
Old 06-17-2016, 07:27 AM   #13325
Super Moderator
Kraig's Avatar
Sounds good. I will create a new thread and do my best to bring over the posts about the RZ6 here to the new one.
Old 06-17-2016, 08:18 AM   #13326
Super Moderator
Kraig's Avatar
The Kyosho RZ6 thread has been created. I copied all of the posts on the RZ6 in this thread, that I could find to the new thread. You can find it here.
Old 06-18-2016, 12:50 PM   #13327
Hey guys,
Looking for some additional corner exit rear traction. Really hard to get on it at all without rear end coming around. Driving on loose/medium grip dirt track.
Where is the best place to start?
SETUP:
Front:
- Shocks: White spring, 1.4X3, 32.5 weight, middle on shock tower, outside lower hole
- Reverse akerman plate
- 1.0mm Spacers inside and out on camber arms, middle hole on front bulkhead
- Hubs spaced all the way up and forward.
Rear:
- Shocks: Pink spring, 1.6x2, 27.5 weight, second from inside on tower, middle hole on 3 position lower arm
- 3mm shims on inner bulkhead, outside hole on knuckle with 2mm shim
- Transmission raised 1.0mm
- Hubs spaced all the way forward
- 0.75mm anti-squat
- 1.0 degree rear hubs
- 20 gram weight on rear
Blockade M3 in rear and 3 rib fronts for tires
This is not your typical 1/10 smooth, clay track. It is blue groove in places, bumpy, dusty in others. Having a tough time getting rear traction when coming out of a tight 90 degree corner. Its really hard to get on it without rear end coming around or kicking out.
Looking for suggestions. How else can I lower rear roll centre to gain more traction?
Thanks,
RiPPeN78 is offline   Reply With Quote
Old 06-18-2016, 01:17 PM   #13328
Super Moderator
Kraig's Avatar
Originally Posted by RiPPeN78 View Post
Hey guys,
SETUP:
Front:
Rear:
- 0.75mm anti-squat
Thanks,
How much rear toe are you running, example d-in, d-in?
If you need the car to squat more in the rear end to get some bite I would move the lower shock mounts in on the arm. I would also move the rear hubs backs.
I would also swap the shock pistons around. I do believe the 3 hole variety that you listed does not pack up as fast as the 2x1.6's. If you have 4 or 5 hole you could try that as well.
Then I would also play around with the camber link shim on the hub and the length. I thought you would want a longer link on a high bite surface to allow the car to roll more. If you have trouble with grip maybe less shims or a shorter link will allow the car to square up better in the corner and allow you to get on the gas earlier since it isn't continuing to roll.
People have also told me that a stiffer spring forces the tire into the ground more than a softer spring. So that could be an option for you too.
These are just some ideas.
Old 06-18-2016, 01:30 PM   #13329
Thanks so much!
I am running C-IN & C-IN for the rear toe with the narrow rear holder.
Old 06-18-2016, 03:23 PM   #13330
oPAULo's Avatar
Thanks so much!
Hmmmmm. What narrow rear holder? C-in C-in or D-in D-in refers to C-in front holder C-in rear holder which gives you 3.5 degrees toe in. Running an adjustable holder with a fixed holder might have you all messed up if that's what you have.
oPAULo is offline   Reply With Quote
Old 06-18-2016, 03:37 PM   #13331
oPAULo's Avatar
The inner shock mount on 3 hole rear arms really helped me on low bite. A heavier wing also helps like a trifecta or Sworkz. They're only 10 grams heavier but it's up high and helps roll. Sideways battery right against the waterfall helps a great deal too.
But before anything is tires, tires, tires. Just because you have the same tires the fast guys do means nothing if your not prepping them the same. Tire preparation is HUUUUGE!
Old 06-18-2016, 03:55 PM   #13332
oPAULo's Avatar
Also just noticed you have 1 degree rear hubs. You may have way too much rear toe in for low bite track. Toe is when your wheels are not tracking parallel or actually steering twards one another. In a straight line they're kind of fighting one another and always in a state of skid. In a corner they're happy. You may have too much and always in a state of skid. From my research, you want more rear toe for high bite tracks where you carry a lot more corner speed and less for low bite.
Somebody chime in if I'm way off base here because I want to know too!!
Old 06-18-2016, 09:59 PM   #13333
SAMCRO's Avatar
Hey guys,
SETUP:
Front:
Rear:
- 0.75mm anti-squat
Thanks,
Move your arms/hubs all the way foward. Run the the four gear box if you have three gear.
Run the long front eyelet and go far inside hole on rear arm.
A pink rear spring is too soft. Would go to white or maybe gold since you have the added rear weight
SAMCRO is offline   Reply With Quote
Old 06-20-2016, 03:45 PM   #13334
GIHOSU's Avatar
Hey guys,
Thanks,
M4 Holeshots is my answer.
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 17.5 Turf ~ RB6 17.5 ~ RB6 ~ RZ6 Turf ~ RT6 Turf ~ SC6 17.5 ~ SC6 ~ SC6 Turf ~ ST-RR Evo.2E
TEKNO - SCT-410 ~ SCT-410.3
GIHOSU is offline   Reply With Quote
Old 06-27-2016, 10:47 AM   #13335
Trader Rating: 24 (100%+)
Anyone hear rumblings about a new car? With the updates they haven't released (3 gear, laydown, wide chassis, etc) it makes me wonder if they're releasing something. Would like to get an idea on if I should get an RZ for carpet, and if a new buggy will be out before Nats in August.
fenton06 is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Today 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
