    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 06-12-2016, 10:26 PM   #13306
raz14's Avatar
Originally Posted by Kraig View Post
Welcome.
I have been up and down in ride height. There is something in this front end that is leaving me scratching my head. Maybe it is electronics related, not sure. Hopefully I find it otherwise it is time to swap front ends between the two cars.
I would bet the issue is hiding in the rear as the RB6 front end usually has a boiler plate setup.
Chris
Kyosho Ultima RB6/RT6/RZ6
raz14 is offline   Reply With Quote
Old 06-12-2016, 10:31 PM   #13307
raz14's Avatar
Just saw from your setup sheet that the rack is backwards to calm the steering. Turning it around should make it more pointy.
Chris
Old 06-13-2016, 01:31 AM   #13308
ralphee's Avatar
Welcome.
Kraig
I run on medium grip carpet. On the more open fast layouts we put down, the car is insane, soooo good, but, the tighter tracks with sharp 180 hairpins, she pushes off power terrible.
Im trying a shorter wheelbase next week, moving the hub 2mm forward. I will say flip your rack though, and get at least 20g under the steering bellcranks, that REALLY helps.
Ive a few things to try with advice from the UK team guys, so im eager to get the balance right, as like you, lots of rear end, just need the front to start gripping a little better, but its a fantastic car, on power corner speed is just spot on.
Also, try going one hole out on your rear tower.
lee
ralphee is offline   Reply With Quote
Old 06-13-2016, 10:14 AM   #13309
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Thanks!
I went back and read my radio manual again and found some options in it that I did not know existed. So I am going to try that before I start changing things on the car. The only reason why I am trying the radio is that right now, on the front, that is the only thing that is different between our two cars.
As for the rear shocks, I had to move them to the back of the arm to help with the rear grip. Once I did that I had the rear just the way I wanted it to feel.
So next trip to the track I am going after;
Radio changes
Steering rack change
Weight on front end
Playing with the rear hub spacing to see what that will do.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-13-2016, 10:17 AM   #13310
Super Moderator
Kraig's Avatar
Originally Posted by scoobyrs25 View Post
Try shortening the wheelbase by moving your rear hubs and arms forward. My shocks are up front and my speedo behind the motor. I'm also using the gear diff with 2k oil and it works great.
I had 5k in my diff and that didn't work out so well. I will get some 2k and give it a try in the future.
I moved the shocks, because it was easier to do at the track. Maybe my next step will be to move the speed control behind the motor like you suggested but I need to get the front to feel like I want it to feel.
Old 06-13-2016, 02:39 PM   #13311
GIHOSU's Avatar
Thanks for posting your setup Kraig, I am wondering if the change in the front comes from the RZ6 directions showing the hingepin block on top of the chassis instead of under...
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 17.5 Turf ~ RB6 17.5 ~ RB6 ~ RZ6 Turf ~ RT6 Turf ~ SC6 17.5 ~ SC6 ~ SC6 Turf ~ ST-RR Evo.2E
TEKNO - SCT-410 ~ SCT-410.3
GIHOSU is offline   Reply With Quote
Old 06-13-2016, 03:10 PM   #13312
raz14's Avatar
No way. It follows the other gen 6 cars. Step 1 is just unclear.
Chris
Old 06-13-2016, 11:48 PM   #13313
I'm also running the brass front hinge pin part. I think I added 10-15 grams of lead just behind the battery and under the driveshaft. Before I moved the speedo and added the weight, the car was undrivable.
scoobyrs25 is offline   Reply With Quote
Old 06-14-2016, 06:59 AM   #13314
Super Moderator
Kraig's Avatar
I have mine setup the same way as the RB6. I didn't think there was any other option.
Can you be more specific about being undriveable? Would it not turn, was it loose on/off power?
I am headed back to the track tonight to try my changes. If needed, I will swap entire front ends between my car and the kids RB6 and see if that makes a difference. It shouldn't take to long to do that.
Old 06-14-2016, 02:39 PM   #13315
Like a skateboard on ice.
Old 06-14-2016, 03:05 PM   #13316
raz14's Avatar
Were you running with a lightweight battery?
Chris
Old 06-14-2016, 05:48 PM   #13317
GIHOSU's Avatar
Thanks for clearing that up, it looked like they wanted the hingepin over but the shaded image shows it the right way. Thanks for clearing that up.
Now I have everything I need to get the build started. This will be a fun one.
Old 06-15-2016, 12:17 AM   #13318
Nope, just a regular shorty pack. I do have the lightweight chassis however. It's the only chassis I have. At least I get to place weight where I want it.
Old 06-15-2016, 06:46 AM   #13319
Super Moderator
Kraig's Avatar
Lightweight chassis on the RB6 or the RZ6? I was talking about the RZ6 so maybe I got messed up somewhere. I will say this though, we added weight to my son's car and he has better car control.
I made a few changes to the radio and now it appears to be reacting the same way as the RB6, front end wise. I didn't change the car at all but instead added more gear and the lap times kept on coming down. I think there is still more to be had but the motor temperature started going up. So next step is to install a fan.
Old 06-15-2016, 10:16 AM   #13320
Lightweight chassis on the RB6 or the RZ6?.
No, it was late and I wasn't thinking clearly. RZ6, not lightweight chassis. My RB had the light one.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22956 Today 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
