    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 06-06-2016, 10:28 PM   #13291
likea45's Avatar
Originally Posted by psycho02 View Post
Supposedly the Rb7 is supposed to be out in August.
Possibly September I've heard. But with Kyo it can always be longer.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 06-07-2016, 06:02 AM   #13292
alexfry's Avatar
Would we expect to see a standalone RZ6 kit at some point?
What are people expecting to see from the RB7? Something like the RZ6 or a more direct evolution like the B6 or XB2?
alexfry is offline   Reply With Quote
Old 06-07-2016, 07:22 AM   #13293
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I have my RZ6 working pretty good on dirt right now. It is very easy to drive consistently. I will post my setup after this weekend when I will be able to really gauge as to how it is working against others.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-07-2016, 08:41 AM   #13294
Gayosaka's Avatar
Please keep us informed
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 06-07-2016, 09:06 PM   #13295
GIHOSU's Avatar
Did you build the gear diff with the conversion parts? I have the aluminum diff cover, thinking I should build it up the gear diff with it. I will try both and see what works best.
I am curious too.
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 17.5 Turf ~ RB6 17.5 ~ RB6 ~ RZ6 Turf ~ RT6 Turf ~ SC6 17.5 ~ SC6 ~ SC6 Turf ~ ST-RR Evo.2E
TEKNO - SCT-410 ~ SCT-410.3
GIHOSU is offline   Reply With Quote
Old 06-08-2016, 03:06 AM   #13296
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
[QUOTE=GIHOSU;14559339]Did you build the gear diff with the conversion parts? I have the aluminum diff cover, thinking I should build it up the gear diff with it. I will try both and see what works best.
You shouldn't have to use that Aluminum diff cover. All you have to do is use a bearing instead of the plastic bushing and that diff is bulletproof. I have been running them in my ZX6 for over a year now and no leaks. I think that the Aluminum diff half is for the 2wd gear diff which is different. the RZ6 uses the ZX6 gear diff.
Team Kyosho (RB6, RT6, ZX6 & SC6)
Team Orion R10.1 Pro
Team Orion Touch Duo Charger
Team Orion Pro Carbon 100C Batteries
motorfinger is offline   Reply With Quote
Old 06-08-2016, 09:35 AM   #13297
Super Moderator
Kraig's Avatar
I built the gear diff without the bearing modification (others have mentioned this mod) and tried it for one run. I probably had the wrong weight of oil in it and didn't like how it felt. So I built up a ball diff and I have been using that. I will probably try the gear diff again but I plan on using/trying something other than 5k.
Old 06-08-2016, 09:37 AM   #13298
Most of the guys that run the RZ6 here use anywhere from 8k to 15k in the diff. we are on high traction wet clay.
Old 06-08-2016, 09:49 AM   #13299
Super Moderator
Kraig's Avatar
My track isn't like that so that probably explains why I didn't like it.
Old 06-08-2016, 01:48 PM   #13300
raz14's Avatar
RZ6 low traction questions:
1. How does the RZ6 fare compared to the RB6 MM for low traction?
2. Will it squat and transfer the weight to the rear?
3. Is it capable of getting comparable rear grip and if so how?
4. Is there anti-squat adjustment?
Chris
Kyosho Ultima RB6/RT6/RZ6
raz14 is offline   Reply With Quote
Old 06-12-2016, 09:11 AM   #13301
Super Moderator
Kraig's Avatar
My RZ6 was pretty good last night. I will get the setup posted later today. I just came in to do some other things, i.e. make sure nobody was causing trouble.
I will say this though. With my RB6 it wasn't reactive like my sons RB6. So I am trying to figure out what the problem is because I really believe that is holding my RZ6 back right now. Maybe you guys and girls can see something on the setup sheet I am missing or did wrong.
Stay tuned!
Old 06-12-2016, 04:13 PM   #13302
Super Moderator
Kraig's Avatar
Default RZ6 Dirt Setup
Here is what I used this past Saturday. My hot lap was .1 off of the TQ's hot lap and he was running a 22 3.0. There is more in the car, just need to work on my driving issues.
Old 06-12-2016, 04:55 PM   #13303
raz14's Avatar
Thanks for sharing your setup. So you have plenty of rear grip but it's not handling as well as your son's RB6?
Have you played with the ride height? Perhaps match the RB6 and see what happens.
Chris
Old 06-12-2016, 08:15 PM   #13304
Super Moderator
Kraig's Avatar
Welcome.
I have been up and down in ride height. There is something in this front end that is leaving me scratching my head. Maybe it is electronics related, not sure. Hopefully I find it otherwise it is time to swap front ends between the two cars.
Old 06-12-2016, 08:43 PM   #13305
Welcome.
Try shortening the wheelbase by moving your rear hubs and arms forward. My shocks are up front and my speedo behind the motor. I'm also using the gear diff with 2k oil and it works great.
scoobyrs25 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22955 Today 12:08 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
