    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 05-12-2016, 08:30 AM   #13261
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Originally Posted by tps3443 View Post
The MIP pucks system looks really clean when it's installed but, the stock ones are super strong. None bent or broken so far I'm sticking with the stock cvd setup.
What is the best, thickest carbon fiber towers / hangars to run?
Avid axles are the strongest.. I've been using the tebo towers,so far they have been good.. Kyosho hangers
hairymuffin is offline   Reply With Quote
Old 05-12-2016, 09:35 AM   #13262
Trader Rating: 8 (90%+)
Originally Posted by Tpg racer View Post
Not really sure which bodyshell you are referring to but i am guessing you are looking for the Muchmore WonderBody bodyshell
This one
http://events.redrc.net/2015/10/chas...o-matsukura-5/
I know it says xgear but i cant find anythg on the internet.
juicy74 is offline   Reply With Quote
Old 05-12-2016, 10:13 AM   #13263
Tpg racer's Avatar
Originally Posted by juicy74 View Post
This one
Google Muchmore WonderBody / XGear WonderBody
Tpg racer is offline   Reply With Quote
Old 05-13-2016, 12:39 AM   #13264
akimrc's Avatar
in my previous post is answer...
lightweight Tamiya #84374
standard Tamiya #84368
same bodyshell
TRF211XM
XFactory X6 Cubed
akimrc is offline   Reply With Quote
Old 05-13-2016, 10:47 PM   #13265
Thanks!
Old 05-14-2016, 01:40 AM   #13266
same bodyshell
Oh sorry i misread your previous post. Thanks!!
Old 05-15-2016, 02:29 PM   #13267
Is it just me, or is the Kyosho RB6 just super tough?
I have yet to break anything. Other then a bad sensor wire at the track today. R10 Pro was flashing green with reduced power. Changed sensor wire out. It fixed it.
I'm running the punch on my R10 Pro at #1 slipper is quite loose, diff tight. And it is amazingly smooth and just perfect with my Trinity 24K 6.5T. This car just seems to be like butter on the track. It feels alot smoother then a team associated I drove.
I must say though, I did drive a Schumacher KF2 I liked it .
tps3443 is offline   Reply With Quote
Old 05-16-2016, 11:06 AM   #13268
Could someone please tell me how to attain 0 degree anti-squat?
How or where do you add shims to the rear front hanger? I am a little confused on this portion. Are they telling you to put shims under your front suspension holder? In the instructions they do not show this. I am completely lost.
Does anyone have an idiots guide to setting up anti-squat and pro-squat? Been searching for quite some time but have not found anything.
RiPPeN302 is offline   Reply With Quote
Old 05-16-2016, 03:01 PM   #13269
oPAULo's Avatar
You can't get zero degrees.
You must have 1mm worth of shims somewhere in the rear.
Either 1mm below the rear hanger, 1mm above the rear hanger, .5mm above and below, or any other combination of shims that add up to 1mm above or below the rear hanger.
1mm under the rear hanger gives you .75 degrees
.5mm above and below gives you 1.5 degrees
1mm above gives you 2.25 degrees
No shims under the front hanger. Ever.
Seems like most run 1.5 degrees and forget it.
oPAULo is offline   Reply With Quote
Old 05-16-2016, 06:54 PM   #13270
RZ6 update.
I love it. After moving the speed control to behind the motor and adding .5 ounce of weight just behind the battery, the car is dialed. I run on a track that slicks work great on. I'm confident it would work really well on a looser surface too.
scoobyrs25 is offline   Reply With Quote
Old 05-16-2016, 09:11 PM   #13271
Originally Posted by scoobyrs25 View Post
RZ6 update.
where do you race at? i want to check out some vehicles outside of team associated brand.
vietjdmboi is offline   Reply With Quote
Old 05-17-2016, 02:09 PM   #13272
raz14's Avatar
Thanks for the info as I try to understand this.
What happens when you assemble without any shims at all? Bad things? I race on a low to mid traction dirt track where RM dominates currently.
Why 1mm minimum total shim?
The RB6 instructions for RM show a single 0.5mm spacer below the holder, while MM shows 0.5mm below the holder plus an optional 1mm above.
Wouldn't that suggest 0.5mm is acceptable for some setups? What am I missing? Thx!
Chris
Kyosho Ultima RB6/RT6/RZ6
raz14 is offline   Reply With Quote
Old 05-17-2016, 03:42 PM   #13273
LRH on Sundays
Old 05-17-2016, 03:51 PM   #13274
oPAULo's Avatar
No idea about rear motor but my manual shows .5mm above and below or 1mm above for more anti-squat. All the parts are sandwiched between the chassis and the transmission. 1mm gives the correct spacing so there is no binding or flexing of anything.
Old 05-17-2016, 03:59 PM   #13275
raz14's Avatar
Looking closer at MM in the book, it does indeed show 2x0.5mm std then the 1mm optional shim, you're right.
Thanks for explaining. I'll make sure my cars have at least the proper std spacing.
Chris
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22953 Today 12:29 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
