    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 05-10-2016, 11:49 AM   #13246
I have the 2015 Kyosho RB6 kit. Do I have the wider chassis?
Are the MIP pucks worth getting? I run 6.5T MOD racing.
One more question, is the RZ6 worth getting? I know it comes with alot of nice upgrades. Like , aluminum braces, and hinge pin holders etc. Etc. Or should I wait on a new kit?
And, I've noticed my ball diff is tight . It doesn't bark. But, if I rotate one wheel the other does not rotate the other direction. If I hold both wheels and rotate the opposite directions it is smooth. But, not super smooth or anything.
tps3443 is offline   Reply With Quote
Old 05-10-2016, 12:43 PM   #13247
hairymuffin's Avatar
Trader Rating: 93 (100%+)
New chassis is not out(yet).. Not sure if or when? Rz6 is for carpet or Astro. Not sure about your diff,loosen it but not to a point where it slips
hairymuffin is offline   Reply With Quote
Old 05-10-2016, 01:31 PM   #13248
so, are the MIP pucks worth buying? I like the idea that there is no play in them but, not sure if they can hold the low turn MOD motors
Old 05-10-2016, 02:14 PM   #13249
roadkill's Avatar
Trader Rating: 126 (100%+)
Send a message via Yahoo to roadkill
I thought the puck system was for stock class(17.5) not sure they would hold up to a low turn mod.
Keeper of the check book, Pit butler,(for hire) President and life long member of the Black Flag Club,
roadkill is offline   Reply With Quote
Old 05-10-2016, 02:19 PM   #13250
OriginalDonk's Avatar
Trader Rating: 38 (100%+)
There are two kinds of pucks:
1) Standard pucks with aluminum diff outdrives, aluminum C-CVD bones designed for stock racing with 17.5 turn motors.
2) Bi-metal pucks with a keyed joint made of hardened alloy steel that connects to a 7075 hard anodized aluminum driveshaft that can handle modified (does this need ALL CAPS? MOD?) motors. No real rotational weight savings with the bi-metal pucks.
Some guys run the bi-metal pucks in mod. I personally would go for pucks in stock racing and would pass on bi-metal pucks for mod.
OriginalDonk is offline   Reply With Quote
Old 05-10-2016, 03:06 PM   #13251
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I have no experience with the puck system with mod motors but I wanted to highly suggest putting some black grease on the pins that go into the outdrive. This will help prevent excessive wear on the pins and the outdrives.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-10-2016, 03:40 PM   #13252
Like the other guys said, mainly stock guys use the pucks, Mip does make a standard cvd polished set.. I run the stock bones but avid axles for strength..
Old 05-10-2016, 04:31 PM   #13253
Great advice right here. If you grease the driveshaft pins, the outdrives and pins will last a very long time. I usually clean and re-grease every couple race days to prevent any dust/dirt from building up as well.
Rusty's Sled Shop LLC ~ Dirtheaven Hobby and Raceway-Champion,WI
Ballistik Ink Designs ~ Revolution Raceway-Appleton,WI ~ Cherry Juice Tire Traction
Support your local hobby shops!
RIchie-Peters is offline   Reply With Quote
Old 05-10-2016, 05:45 PM   #13254
MOD does not need caps my phone does that automatically. Why would that bother someone..
I use purdy paint brushes to keep my cars spotless after each run. More expensive brushes. But they don't wear out like cheap ones.
I'm going to skip the MIP pucks.
Old 05-10-2016, 06:09 PM   #13255
oPAULo's Avatar
MIP quit making replacement parts for the RB6 pucks kits so if you break an axle or wear one out your kinda screwed. There are no more to be had that I have found. I have found a way to adapt AVID axles to MIP drive shafts but the spacing is different so I'm forced to run narrow on the rear arm hanger width.
oPAULo is offline   Reply With Quote
Old 05-10-2016, 06:34 PM   #13256
oPAULo's Avatar
I should add though, I'm still a huge fan of the pucks system. I got my sons RB6 used over a year ago and it had pucks on it. We've raced it nearly every weekend since. At 7 to 10 battery packs on a race day that's over 400 runs a year. The outdrives and drive shafts still look perfect. 3 dollars worth of plastic pucks every couple months and it's good as new. That's why I went to the trouble of making AVID axles work with MIP drive shafts.
Old 05-12-2016, 12:34 AM   #13257
Trader Rating: 8 (90%+)
Hey guys,
Where can i get the body shell that naoto is running?
juicy74 is offline   Reply With Quote
Old 05-12-2016, 12:43 AM   #13258
Tpg racer's Avatar
Originally Posted by juicy74 View Post
Hey guys,
Not really sure which bodyshell you are referring to but i am guessing you are looking for the Muchmore WonderBody bodyshell
Tpg racer is offline   Reply With Quote
Old 05-12-2016, 03:34 AM   #13259
akimrc's Avatar
Hey guys,
the shell is from Xgear maybe
and same shell is standard Tamiya TRF201XM,XR,XMW and new TRF211XM
TRF211XM
XFactory X6 Cubed
akimrc is offline   Reply With Quote
Old 05-12-2016, 06:36 AM   #13260
The MIP pucks system looks really clean when it's installed but, the stock ones are super strong. None bent or broken so far I'm sticking with the stock cvd setup.
What is the best, thickest carbon fiber towers / hangars to run?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22944 Today 12:18 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
