    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 05-03-2016, 07:21 PM   #13231
TravisS27's Avatar
Trader Rating: 25 (100%+)
RB6 mid-motor gearing for 13.5....and go!
TravisS27 is offline   Reply With Quote
Old 05-03-2016, 09:08 PM   #13232
BRSracing's Avatar
Trader Rating: 53 (100%+)
Originally Posted by TravisS27 View Post
Any idea if the parts will be compatible with the RB6?
I really don't know, just a guess it will be a updated kit to for the sideways battery and laydown option. Like someone else said likely a lot of carryover parts. the current car is pretty good.
BRSracing is offline   Reply With Quote
Old 05-03-2016, 09:48 PM   #13233
TravisS27's Avatar
Some RB5 parts work on the RB6 don't they? I have a complete RB5 and enough spares for it to start a small RB5 parts shop lol
Old 05-03-2016, 11:29 PM   #13234
I am guessing the front end will remain pretty much the same in the new car. Kyosho should introduce a new chassis for the verical battery position as well as the laid down transmission.
I would love to have some extra features like accepting the "old" transmission for dirt use for example...I quess we will have to wait and see...
nitroargi is offline   Reply With Quote
Old 05-04-2016, 06:25 PM   #13235
Just got the new 24K 6.5T came a day early
tps3443 is offline   Reply With Quote
Old 05-04-2016, 10:16 PM   #13236
likea45's Avatar
I'm assuming the reason we don't see a genuine Kyo mm 3 gear trans is they are planning to include it with a new kit. Probably mid motor only with the lay down trans as an add on. Guessing similar geometry to the RB6 but with sideways shorty supported, 3 gear/4 gear mm.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 05-06-2016, 09:06 PM   #13237
Trader Rating: 41 (98%+)
New kit huh?
cobra408 is offline   Reply With Quote
Old 05-06-2016, 11:06 PM   #13238
likea45's Avatar
That's the word. When is another story.
Old 05-06-2016, 11:13 PM   #13239
ralphee's Avatar
Hoping they may go for another conversion, or at least a choice, just bought an RB6 along with an RZ6 conversion, so it would be nice to try the laydown car without the need for a full car buy again.
lee
ralphee is offline   Reply With Quote
Old 05-07-2016, 07:33 AM   #13240
tobamiester's Avatar
Trader Rating: 274 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
First time out last night, after switching back to RB6. Brought a used one locally and the previous owner had butchered the chassis/side pods for transverse battery. Wow what a difference, car felt awesome. Very consistent and predicable.
tobamiester is offline   Reply With Quote
Old 05-07-2016, 07:41 AM   #13241
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Depends on if you have a RPM stator (short stack) or Torque (standard stator)
General rule of thumb as it was explained to me, was to start 3 teeth less on the pinion from where you'd run a 17.5.
So for example:
17.5- 33/69
13.5- 30/69
Just as a starting point
I normally use a short stack/rpm stator for both 17.5 and 13.5
17.5- 30-31/69
13.5- 27-29/69
Should be close as a starting point
If you want to use a different size spur, say a 72 avid/schelle, do the math to get the ratio as close as you can and go from there.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 05-08-2016, 08:00 PM   #13242
TravisS27's Avatar
So for example:
17.5- 33/69
13.5- 30/69
17.5- 30-31/69
13.5- 27-29/69
Thank you sir! I found a brand new 70t spur and slipper pads in my parts box, no clue where it came from or what it's out of but it works! Can't wait to get my new RB6 on the track...just switched over from AE. My RT6 is on it's way as well
AKA Tires
BOOMrc Graphics
Exotek Racing
RickyRacer Lidz
Jake's RC Topeka KS
Old 05-09-2016, 11:13 PM   #13243
I ran my first main even, I finished 5th. The RB6 is just super smooth. This is my first race with 2WD mod.
It is unbelievable how good the software is on the Orion R10 Pro, messing around with Turbo, and boost is really great such a smooth power transition when your at that thin line between grabbing, spinning, and the nose lifting just a tiny bit.
I'm use to SCT 4WD racing. So, it's amazing how clean my RB6 always stays.
I ran Schumacher cut stagger tires in the front. With mini pins rear on my dusty groove track the front dug in like crazy when turning I had to adjust end points way down on steering .
Very predictable car though. Love it.
Old 05-10-2016, 10:21 AM   #13244
SAMCRO's Avatar
What is the word on a new kit? Will it happen this year or next?
SAMCRO is offline   Reply With Quote
Old 05-10-2016, 10:43 AM   #13245
hairymuffin's Avatar
Trader Rating: 93 (100%+)
I think it's just an assumption,because of some new stuff the team guys are running.. But that's not to say it's not going to happen.. Maybe a updated kit. That's all the rb6 needs is just an update.. Only new Kyosho part I've seen new is the wider chassis, the 3 gear trannies are not Kyosho,as far as I know
hairymuffin is online now   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
