    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 04-26-2016, 09:37 AM   #13216
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Default Adding fuel to the fire
Originally Posted by gokarter64 View Post
i found this spy shot from neobuggy of the new laydown trans case. it looks like you can change from 3 to 4 gear within the same case.
it also looks like the rear tower mounts up to the gearcase just like the yz2
I found these pictures of Naoto's car, on Red R/C, from the World's race.
I am going to guess that the chassis used in Japan has been used by Jared on the dirt based on the pictures below.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 04-27-2016, 08:05 PM   #13217
joecool's Avatar
Trader Rating: 19 (100%+)
Default Laydown trans
Here is another
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 04-27-2016, 11:58 PM   #13218
gokarter64's Avatar
gokarter64 is offline   Reply With Quote
Old 05-02-2016, 02:10 PM   #13219
Suspended
Originally Posted by scoobyrs25 View Post
My RZ6 showed up today
How are you liking the rz6 so far? I've been thinking about getting the conversion to try on turf or high bite clay.
chriso138 is offline   Reply With Quote
Old 05-02-2016, 02:19 PM   #13220
Suspended
Originally Posted by joecool View Post
Here is another
Who's making this new lay down tranny? Where can i get one?
Old 05-02-2016, 03:33 PM   #13221
gokarter64's Avatar
As far as we know its a kyosho prototype.
Old 05-02-2016, 03:44 PM   #13222
Actually this weekend was a huge improvement. I lightened up the rear shock oil and moved the esc to behind the motor (super clean). It was very smooth and easy to drive. I would like to try the ball diff and some pink or white rear springs. They are currently gold.
scoobyrs25 is offline   Reply With Quote
Old 05-02-2016, 04:00 PM   #13223
OriginalDonk's Avatar
Trader Rating: 41 (100%+)
Love that capacitor mounting location. Setup looks clean.
OriginalDonk is offline   Reply With Quote
Old 05-02-2016, 05:11 PM   #13224
cnelson3's Avatar
Trader Rating: 65 (100%+)
are the hubs all the way forward in the arms? I'm about to pull the trigger on the RZ6 and your layout was the same layout I started with on my ZX6. I remember how much traction I had but didn't steer worth a darn. That was the ZX6 though.
Trackside Hobbies & Raceway - Milwaukee, WI
cnelson3 is offline   Reply With Quote
Old 05-02-2016, 05:19 PM   #13225
Interesting. I have plenty of steering with my ZX6 setup this way. I'll check my hubs tonight. If they are not all the way forward, they will be. This chassis is way longer than the RB6.
Old 05-03-2016, 09:54 AM   #13226
TravisS27's Avatar
Trader Rating: 25 (100%+)
Picking up an RB6 tonight. What are my options for laydown trans for carpet racing besides the RZ6 conversion? Not really looking to put that much more into it right away.
TravisS27 is offline   Reply With Quote
Old 05-03-2016, 12:13 PM   #13227
BRSracing's Avatar
Trader Rating: 55 (100%+)
If you believe the rumors they have a new car coming anytime, (i have heard May) that will either have or have a option of a laydown transmission.
BRSracing is offline   Reply With Quote
Old 05-03-2016, 02:46 PM   #13228
TravisS27's Avatar
Any idea if the parts will be compatible with the RB6?
Old 05-03-2016, 04:52 PM   #13229
whitrzac's Avatar
Trader Rating: 95 (100%+)
It's a kyosho.... Most of the new parts should fit the old car if it's not just a conversion/update kit.
whitrzac is offline   Reply With Quote
Old 05-03-2016, 06:02 PM   #13230
Just drove my newly built RB6 for the first time.
Kyosho RB6
Orion R10 Pro
Trinity D4 6.5T 50 timming
Trakpower 100C 2S saddle
23T pinion.
I was breaking the ball diff in real good on pavement going in circles slowly.
Then I started getting on it. Maybe I need to back the slipper down..
It literally wheelies while spinning the back tires across the parking lot. Lol.
What a blast, Trinity D4 is sick power. My Trinity 24K 6.5T will be here Thursday from Amainhobbies.
And I got a deal on a bunch of Schumacher pin tires.
All I can say is, I'm coming from 1/8 to get in to 2WD MOD/ stock racing. And the smoothness is on another level. Power delivery is like tearing through silk. If that makes sense lol.I turned a brand new set of $6.00 bar codes in to slicks in 5 minutes. I could not help my self.
Will be hitting the track this weekend.
Temps were coming off at 120f motor/ 110f esc
tps3443 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22982 Today 01:26 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
