    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 04-08-2016, 10:44 AM   #13156
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
I really really don't need another car, I just bought at XB2 CE, and I have my RB6, D413, and DEX210v2...BUT I REALLY WANT THE RZ6!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 04-08-2016, 03:32 PM   #13157
The RZ6 looks amazing. The conversion alone is as or more expensive then some entire kits.
But, Kyosho is worth the money. I'm having a hard time bleeding the shocks, they are smooth. But, oil is all mixed with bubbles, I understand the bleeding idea but, once I fill with oil and get all the air out its to much oil, and the shaft rebounds.
If I use less oil, Air stays inside.
Is it OK to have some rebound?
What's a good starting weight oil?
All I've got is 27.5/37.5
tps3443 is offline   Reply With Quote
Old 04-08-2016, 03:33 PM   #13158
The RZ6 is a conversion for the RB6. It's not a whole new kit.
Old 04-08-2016, 04:03 PM   #13159
dmcguire's Avatar
Trader Rating: 21 (100%+)
This video Tebo did in shocks is great. Give this method a shot and make sure you're bleeding from the bottom, not removing the cap
https://youtu.be/4OI3evgMM30
dmcguire is offline   Reply With Quote
Old 04-08-2016, 08:55 PM   #13160
I enjoyed this kit so much, I ordered another Kyosho RB6!
Kit is finished. I'm doing the body white, now I just need my Orion R10.1 Pro, and a 7.5T motor!
Great kit to build!
One thing I recommend about the entire kit... The plastic is hard like no other, it's like hardened polymer! So hard in fact, you will strip the included hex heads.
Everything is nice and tight!
Old 04-10-2016, 01:37 PM   #13161
Is kyosho releasing the 3 gear transmission. I am tired of modifying the old one.
beardog661 is offline   Reply With Quote
Old 04-10-2016, 08:16 PM   #13162
I got a really good deal on a Trinity D4 10.5T
It's a certified Trinity D4 motor with dyno sheet, and a high torque 13mm rotor.
Think this will get the RB6 moving OK with some 100C 2S packs?
Old 04-10-2016, 09:23 PM   #13163
It should make it rip. Gear it for the track you normally run on. Kcars simply rock.
joel45acp is offline   Reply With Quote
Old 04-10-2016, 09:39 PM   #13164
likea45's Avatar
This is a good question. Every other manufacturer offers this. It would be so easy for them to do. What's the deal Kyo?
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 04-11-2016, 06:38 AM   #13165
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I liked the video but I always struggled with putting in just the right amount of oil so I went back to my old routine.
Fill the oil up to the first thread.
Extend the shock shaft so the eyelet bottomed out on the shock bottom.
Place the piston into the shock body but let gravity pull it down into the body.
Once the shock bottom reaches the shock body help align it into the body so that the treads line up.
Turn the shock bottom so that it starts to thread into the body.
Wait for 1 second to give the excess oil time to escape.
Continue to turn, wait, turn, wait process until the shock bottom is tight.
Pump the shock shaft a few times and then bottom out the eyelet to the bottom of the shock and release.
Hopefully you should not have any rebound or maybe just a little bit.
If you have more than you like, loosen the shock bottom, push the shock shaft down, wait for a little bit and then re-tighten the shock bottom.
I hope that made sense.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 04-11-2016, 09:56 AM   #13166
That actually does make sense. I'm gonna try it again. I did all the shocks before as good as I could and put them on the car. They are smooth, but I suspect there a tab bit low on oil.
I don't really understand the whole 3 gear, 4 gear thing. But, I do realize there is (2) idler gears in the mid motor RB6 transmission, both are black . If we replace it for aluminum, Do we replace both of them?
Old 04-11-2016, 10:24 AM   #13167
Super Moderator
Kraig's Avatar
You don't want to run metal on metal so you would replace the plastic gear that touches the diff gear.
Old 04-11-2016, 11:23 AM   #13168
I finished my body trimming, and painting. Now if only my tires, motor, ESC will arrive .
Old 04-11-2016, 03:03 PM   #13169
Default 3 gear transmission
tnd just came out with a 3 gear laydown. Comes with motor plate and all the needed hardware for $89
vicp is offline   Reply With Quote
Old 04-11-2016, 04:16 PM   #13170
OK, I've been looking bargains on Rctech, to finish my Kyosho RB6. Plus, another RB6 15' kit is on the way.
How do you guys like the Trakpower 100C 2S saddle packs? They are a little heavier at around 275 grams. I got a pair on the way.
I ordered those.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22956 Today 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
