    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 04-05-2016, 11:01 AM   #13141
Should I go ahead and buy the differential kit before I build tomorrow?
Diff kit, aluminum diff cover, and diff oil? If so, what weight?
tps3443 is offline   Reply With Quote
Old 04-05-2016, 12:52 PM   #13142
dmcguire's Avatar
Trader Rating: 21 (100%+)
Get a bottle of 5K and 7K
Start with 5k
dmcguire is offline   Reply With Quote
Old 04-05-2016, 07:11 PM   #13143
I was planning to reuse my Hitec 7955TG servo in the RB6. I've always ran it at 7.4v at 375oz of torque. That just seems a bit high to me, and I would love to trade half the servo torque for more servo speed.
Old 04-06-2016, 11:28 AM   #13144
Default She finally arrived!
It's building time. Kyosho is some serious high quality, it's just amazing they are built in Japan!
Old 04-06-2016, 01:42 PM   #13145
Building stopped as fast as it started..
Very disappointing, part UM718 assembly shafts with a nut on the end, were not included. I cannot find them in any bag.
They are the main support shafts, that the steering rack, and bearings bolt to.
Old 04-06-2016, 02:50 PM   #13146
oPAULo's Avatar
I've been in the manufacturing and machine trade industry for 22 years and I can assure you that Japan knows about quality and precision manufacturing.
Putting all the parts in the box is another story.
That sucks.
Stick with it. They really are good cars.
oPAULo is offline   Reply With Quote
Old 04-06-2016, 03:33 PM   #13147
That sucks.
Lol. Everything is good! One of my kids "toddlers" grabbed a bag out of the RB6 box . I found the parts!
Build is super smooth, Kyosho instructions... Well, there Kyosho instructions lol that's another story!
Best quality I've seen in RC kits! Ever! Kyosho is amazing, they are worth the extra bit of $
All Delrin CNC conical shock parts, hard plastics! Everything fits like a glove.
I can't believe it. Great kit.
Old 04-06-2016, 04:33 PM   #13148
Did you guys shim the front A-arms? Mine are snug without shims, and fall freely. No binding at all. Just curious because it has shims attached. But, I guess there for the knuckles/ hubs
Old 04-06-2016, 05:15 PM   #13149
oPAULo's Avatar
No shims between the front arms and arm mounts but the hub carriers need shims.
Speaking of arm mounts, Yaiba stuff looks awesome but don't get the steering arms or the front arm mount. Stick with Kyosho or Exotek or Jconcepts aluminum parts.
Old 04-06-2016, 07:45 PM   #13150
boner's Avatar
there is no nuts on um718.
you just put a screw on top of the shaft to secured steering rack. please check your manual, page 12.
boner is offline   Reply With Quote
Old 04-06-2016, 10:09 PM   #13151
GIHOSU's Avatar
For suspension parts I have stayed with Kyosho with a few of Schelle steering racks thrown in and everything has been dependable. Be sure to shim your rear arms if you go to metal hinge pin holders.
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 17.5 Turf ~ RB6 17.5 ~ RB6 ~ RZ6 Turf ~ RT6 Turf ~ SC6 17.5 ~ SC6 ~ SC6 Turf ~ ST-RR Evo.2E
TEKNO - SCT-410 ~ SCT-410.3
GIHOSU is offline   Reply With Quote
Old 04-07-2016, 08:28 AM   #13152
The nut is not removable on the UM718 it's just so it can be keyed in to the bulk head. I just had both UM718's missing all together. But I found them.
So far so good. I am fairly slow at building kits, but I try to make sure everything is perfect. I'm about to start back at it today , and finish it up.
Old 04-07-2016, 01:44 PM   #13153
I hope this not a issue, but I finished building the ball diff. It is very smooth! I used all of my white gear grease assembly on the diff. so, I had to use the black graphite grease in the gear box. Is that OK? Everything turns super smooth. Diff is great.
Assembly is correct, but I used black cvd grease on the idler gears etc.etc.
Old 04-07-2016, 07:17 PM   #13154
Default RZ6 Conversion
The wait is almost over.
http://www.kyoshoamerica.com/ULTIMA-...T_p_24348.html
This conversion replicates the car used by Jared Tebo at the World Championship held in Japan. It features a very efficient shaft drive, which is ideally suited to stock class racing and favors medium to high bite tracks. This is a conversion that is intended for current RB6 owners only.
Expected availability: End of April
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Old 04-07-2016, 08:21 PM   #13155
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I wonder if those are legit 2.2 sized chainlinks and typos on that car or if they are mounted using the conversion kit.
Anyway, here is the setup that I used at the 2016 Spring Classic - Bluegroove Hobbies & RC Raceway in West Des Moines Iowa. Maybe something on it will work for you, not sure.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22956 Today 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
