    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 03-29-2016, 05:22 PM   #13111
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Do the other guys run the same exact tires? What kind of surface? Indoor/outdoor? Clay?based on the tires, sounds like outdoor?
Where is the battery?
Do you have the adjustable alum rear suspension mounts? Toe In? Anti Squat?
What are your camber links setup like?
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 03-29-2016, 05:57 PM   #13112
Yes everyone at the track runs the same tires. Surface is clay/dirt outdoor, bumpy, very dusty in the corners off the main line. Track sometimes turns to blue groove, but not often. We wet the track but drys out pretty good after 3-4 heats. Gets pretty rough on big event days.
Battery is mounted in the rear. 4500 Team Orion shorty pack mounted width wise.
Rear toe in is 3 degrees, Front is 0.
Camber set at -1 Front and Rear
Yes I have the adjustable alum rear suspension mounts.
Rear toe in is: In-C AND In-C (3.0 Degree)
Front camber links:
- Outside has 1mm shim
- Inside is mounted in middle position of 3 with 2mm shim
Rear camber links:
- Outside rear hole with 2mm shim
- Inside link mounted on outside hole with 2mm shim
- Hub spacing is spaced towards the rear ( 3mm shim in front of hub )
Front Shocks
- Outside on tower, inside on lower arm
- Pink springs
- Long ball end type on shock
Rear shocks
- Upper tower 2nd hole from outside (#3 hole)
- Lower arm #2 or middle position
- Gold springs
i am very confused and don't have a clue how to measure anti-squat, or how to use the alum rear suspension holder "chart".
RiPPeN78 is offline   Reply With Quote
Old 03-29-2016, 06:31 PM   #13113
oPAULo's Avatar
Originally Posted by RiPPeN78 View Post
Front Shocks
- Pink springs
This is way off Pillars setup. Inner hole on the arm with long ball end is giving you a ton of droop plus he's recommended much heavier front oil.
You might be too hooked up in the front end making the rear loose.
oPAULo is online now   Reply With Quote
Old 03-29-2016, 06:31 PM   #13114
GIHOSU's Avatar
Front camber links:
Rear camber links:
Front Shocks
- Pink springs
Rear shocks
- Gold springs
You could try in order of importance…
Front camber links 1mm in and 2 out, rear camber links 0mm inside and 2 out
Go shorter on the front shock end and move it out.
Softer springs out back will help grip, go white at least.
Switch to short wheelbase with the big shim out back.
You have the rear good with C in and the brass holder helps.
1 degree alloy rear hubs can help too.
For anti-squat try .5mm shims top and bottom on the rear holder.
The rest sounds good
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 17.5 Turf ~ RB6 17.5 ~ RB6 ~ RZ6 Turf ~ RT6 Turf ~ SC6 17.5 ~ SC6 ~ SC6 Turf ~ ST-RR Evo.2E
TEKNO - SCT-410 ~ SCT-410.3
GIHOSU is offline   Reply With Quote
Old 03-29-2016, 07:02 PM   #13115
Could you please explain some more on adjusting the anti-squat? How does adding or removing shims over/under the rear holder adjust anti-squat?
I am assuming i am looking for a lot of anti-squat?
Old 03-30-2016, 11:29 AM   #13116
13Maschine's Avatar
@rippen: more anti squat in the rear will make the rear end stiffer. I believe your major complaint with the current setup was too much off power steering, causing the car to become almost uncontrollable right?
Old 03-30-2016, 11:32 AM   #13117
13Maschine's Avatar
I'd suggest grabbing the HUDY tuning book, although it's written for Xray cars, it's probably the best reference for tuning tips and adjustments. Here's a great diagram explaining anti squat though, should help understand what the shims do to adjust anti squat.
http://www.pro-touring.com/attachmen...5&d=1322684983
Old 03-30-2016, 03:42 PM   #13118
Try the following for the loose track:
Front:
2x1.6s, 32.5wt, white spring
Middle on tower, outside on arm
Rear:
2x1.7s, 27.5wt, white spring
second from the inside on tower, inside on arm
B in/A pivot
1mm antisquat shim under rear block
hubs middle, arms back
Kyosho / Team Orion / AKA / JTP / Sharkbait Designworks / RC Tracks of Las Vegas
Chris Jarosz is offline   Reply With Quote
Old 04-01-2016, 09:28 AM   #13119
Trader Rating: 20 (100%+)
I was wondering if you guys can help me price my RB6 for sale. I have had it for sale on here but no substantial bites.
It's a clean car (chassis and plastics are in great shape) with aluminum: steering parts, suspension hangers, and rear hubs. It's in mid-motor setup, but I have rear-motor parts and transmission too.
I'm selling it with the following electronics with minimal time on them: Team Orion R10.1 Pro and Lightweight 17.5t motor, XP DS1015 Servo, Shorty lipo - I paid $550 for just the electronics.
It seems that there are a few RB6's for sale that haven't been selling, which is weird. I'm just looking for a guide on what a fair price would be.
Thanks!
Kyosho
MP9 TKI4 & MP9E TKI4
BoomRC.net, AKA, ACE Servos, Ko Propo, JTPrc.com, Allebasi
jonasm48 is offline   Reply With Quote
Old 04-01-2016, 10:33 AM   #13120
I'm torn I want a Kyosho 1/10, I love the ZX6, RB6, and the SC6. Or do I get all 3 over time?
The RB6 seems to be the most popular.
There is 1/8 e buggy, and 4WD SCT, and 2WD SCT at one of my local tracks, and several nitro classes.
But no 1/10 2WD buggy, or 1/10 4WD buggy
There is another track near me for 1/10 TC onroad.
RB6 is cheaper then the SC6 and it has more upgrades, aluminum shock caps, etc etc.
I've already got a Tekno EB48.3.
tps3443 is offline   Reply With Quote
Old 04-02-2016, 02:55 PM   #13121
Hey guys, Tower hobbies list a Kyosho RB6 for $399 and a Kyosho RB6 Competition for $449
Can you tell me the difference?
Also, I plan to run 2WD MOD buggy, there's a indoor carpet track 1.5 hours away. I was very happy to find this in mooresville NC
They support 2wd MOD buggy, 2wd stock blinky buggy, 2wd SCT MOD/ stock, 4X4 SCT mod, and 4WD MOD buggy, and 1/8 e buggy!
The place looks amazing!
*** I am thinking a Trinity D4 Certified, or 24K, 7.5T enough? Or hotter like a 3.5T? Or is a 10.5 or 13.5 enough?
I love me some diff bustin, wheelie ripping power! Because I can set a mild power curve, and limiter, for a nice smooth setup.
Thanks everyone!
Old 04-02-2016, 04:00 PM   #13122
Oh no... The RB6's heart has stopped beating on here. CPR! defibulator quick! Buzz! Bzzzz! We've lost the Kyosho RB6 everyone.
Time of death 04/02/16
6:59PM.
Old 04-02-2016, 04:19 PM   #13123
oPAULo's Avatar
6:59PM.
Nawwww.
We're all just busy racing!
Old 04-02-2016, 10:38 PM   #13124
likea45's Avatar
6:59PM.
Allegedly there's a new car, so everyone's waiting to see what's coming out. I'll believe it when I see it.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 04-03-2016, 04:11 AM   #13125
ralphee's Avatar
There is a new car, but they went with the RZ6 first according to comments ive read from Kyosho sources.
Really want the RZ6, looks the bizz, but i dont yet own an RB6, so its a bit of a stinger!
lee
ralphee is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22939 Today 01:36 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Tom87
