    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0į/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 10-09-2012, 04:00 PM   #1291
fastestwon's Avatar
Trader Rating: 15 (94%+)
Default my setup for tight clay track
sorry guys but my printer died so i cant print a blank setup page and scan and post as a PDF . but i will give info without illustration.
following worked on this track
http://www.youtube.com/watch?v=c90cbWQpPoI
race results
FRONT
ball stud outer holes on bulkhead 1 mm shim
ball stud outer holes on C hub 1 mm shim
camber -2
caster 4
1 mm bump steer
kick up 25 with .05 shim
zero tow
shocks on arm outer holes with short eyelet flush with threads
shocks on tower inner holes
shock springs std
6 hole pistons with 25wt losi oil with quarter rebound
ride height 23 mm
ackerman 0.5 shims
REAR
zero tow hubs std
ball stud outer hole on hubs 2 mm shim
bulkhead brace ball stud center holes no shims
squat + .5
-2 camber
arms shimmed short
shocks outer holes on arms
shocks inner holes on tower ( placement on tower after clearance 2 3mm shims )
shock springs std
eyelet med flush with threads
6 holes pistons with losi 25 wt oil with sixteenth inch rebound
ride height 22 mm
battery short placement mid shimmed toward front
tires
front hot bodies full shots pink compound std foam
rear JC concepts bar codes green compound std foam
ready race weight 1587.57
fastestwon is offline   Reply With Quote
Old 10-09-2012, 07:13 PM   #1292
Trader Rating: 27 (100%+)
So are the balls in the diff the $33 Kyosho ones?
Kyosho, Lunsford Racing, Express Motorsports, Dibrino Designs.
C_Money is offline   Reply With Quote
Old 10-09-2012, 07:25 PM   #1293
gelshocker's Avatar
I'm only halfway thru the build, and not counting my mistakes, the build is not as straightforward and smooth as the RB5 IMHO. Mistakes in the manual donít help: Step 12, the orientation of the ball cups showned on the steering tie rod and front upper rod are reversed. And surely having 3L at both ends of the steering tie rod, with the distance between them at 21mm, the ball ends are now fully screwed in with no room to maneuver, and when you attach to the car, you still have huge toe-in. I am guessing this is a misprint, you need a 3L with LL, or both LL even.
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 10-09-2012, 07:28 PM   #1294
carcrusher46's Avatar
Trader Rating: 17 (100%+)
My steering links have 3L ball cups on them, and there is plenty of room to dial in the length.
Matt Stoltz
Thank you to my sponsors:
Team Associated - Reedy - JConcepts - Life Fast RC Paintworks
carcrusher46 is offline   Reply With Quote
Old 10-09-2012, 07:53 PM   #1295
gelshocker's Avatar
Hmm.. the distance between the inside threads of the turnbuckles is like 20mm, so screwing them in to 21mm showing, how can you have plenty of room to maneuver?
The recommend 20.5mm for the camber links to way too much as well. It just looked wrong before attaching and at 23mm I'm still plenty negative camber.
I never had this problem with the rb5 but I went straight with Lunsford.
Maybe I need to lie down a while..
Kyosho RT5 | RB6
Old 10-09-2012, 09:22 PM   #1296
Teufel Racing's Avatar
Got to see one run today,
I'm impressed. Looked real good in the hands of an average racer. Still don't know if the price tag is worth it, but it's a very nice ride. Super quiet too.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is online now   Reply With Quote
Old 10-09-2012, 09:27 PM   #1297
silvalis's Avatar
Trader Rating: 29 (100%+)
Mine's fine using the 3L. 21mm gave me 1 deg toe out. You do realise that when the end of the thread meets the the end of the ballcup it's not fully screwed in and you can go in further? There's nothing wrong with screwing it further in.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 10-09-2012, 09:33 PM   #1298
silvalis's Avatar
Originally Posted by Teufel Racing View Post
Super quiet too.
One of the most attractive advantages of K imo. I had a drive of an SVR and winced when it went past flat out on the straight.
Of course it could be bad, it's nice to be able to hear it a bit.
Old 10-09-2012, 09:47 PM   #1299
joecool's Avatar
Trader Rating: 19 (100%+)
They look like steel to me. I have no way to tell the difference though. I immediately used fresh ceramics by Team Associated
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 10-09-2012, 09:53 PM   #1300
silvalis's Avatar
Tungsten Carbide, #97030
Ceramics listed as optional WBD10
Old 10-09-2012, 09:55 PM   #1301
lbckevin's Avatar
Trader Rating: 91 (99%+)
Originally Posted by Cpt.America View Post
Yep.. the blue colored shock kits and pieces are all cheaper because that color was being discontinued. Functionally, they are the same.
Brandon...
What is the setup you are going to use...? I run your setup on my rb5 and love it....Its for West Coast and OCRC .
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 10-09-2012, 10:02 PM   #1302
Trader Rating: 137 (100%+)
Originally Posted by lbckevin View Post
Brandon...
I'll be very happy to start going back to west coast, didnt much care of OC/RC's new layout. Plan on racing tomorrow night.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-09-2012, 10:05 PM   #1303
A new B4.1 with all the bells and whistles are just as expensive, so is a 22 with all of the updates you have to do to make it ok. One big difference, you wont have to rebuild the whole car as often as you will either of the 2 mentioned above.
Old 10-09-2012, 10:06 PM   #1304
The kit comes with Tungsten Carbide diff balls. Do we really need to go over this again?
Old 10-09-2012, 10:25 PM   #1305
Sorry forgot which ones were the expensive ones
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22955 Today 12:08 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
