    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 02-19-2016, 11:17 PM   #13006
building up my rb6 I got the aluminum steering plate and aluminum crank arms. I noticed the holes that you use to connect the aluminum steering plate to the crank arms has a bigger diameter than the plastic steering plate and the screws are swimming around in those holes. Was the aluminum steering plate supposed to come with some kind of shoulder bolts or something? just does not look right to me.
psycho02 is offline   Reply With Quote
Old 02-20-2016, 02:38 AM   #13007
oPAULo's Avatar
Kit comes with 2 steel bushings that should be in your plastic steering plate. You'll need those. Grease them up.
oPAULo is offline   Reply With Quote
Old 02-20-2016, 03:14 AM   #13008
Hi I'm planning to get the rb6, will there be a new car from Kyushu anytime soon? Thanks.
N15M0 is offline   Reply With Quote
Old 02-20-2016, 11:50 AM   #13009
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Look for LA256.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-20-2016, 05:32 PM   #13010
good to know thanks guys.
Old 02-20-2016, 08:32 PM   #13011
RokleM's Avatar
Trader Rating: 33 (100%+)
UM753-1 - Anyone have an alternative part number or other manufacture that has the plastic shock nuts? I see no need to pay $10 for the three nuts.
- Eric G. -
Tekno EB48.4, NB48.4, ET48.3, NT48.3, EB410
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 02-20-2016, 09:38 PM   #13012
orangutanracer's Avatar
JConcepts 3mm Plastic Nut Set (28)
[JCO2157]
http://www.amainhobbies.com/rc-cars-...FUwvgQodnjkMog
orangutanracer is offline   Reply With Quote
Old 02-20-2016, 10:36 PM   #13013
likea45's Avatar
So I recently purchased a scale and tossed my 17.5 RB6 on it to check her weight. Car has been performing very well but the number shocked me. With running gear, battery, body and wheels on she was 1611g. I'm already running 3-gear and the only aluminum on the car are the exotek front C hubs and the Kyo rear hubs that are only 1g heavier than the plastic. I've heard optimal stock weight for the RB6 to be 1520~1550. I'm at a loss as to what else I can drop to lighten her up. Running inline Orion shorty all the way back, Orion r10 in front of battery and receiver/trans on the battery in front of waterfall with the Trinity 24k.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 02-21-2016, 02:22 AM   #13014
Originally Posted by likea45 View Post
So I recently purchased a scale and tossed my 17.5 RB6 on it to check her weight. Car has been performing very well but the number shocked me. With running gear, battery, body and wheels on she was 1611g. I'm already running 3-gear and the only aluminum on the car are the exotek front C hubs and the Kyo rear hubs that are only 1g heavier than the plastic. I've heard optimal stock weight for the RB6 to be 1520~1550. I'm at a los ass to what else I can drop to lighten her up. Running inline Orion shorty all the way back, Orion r10 in front of battery and receiver/trans on the battery in front of waterfall with the Trinity 24k.
I had mine down to 1500g with alloy front camber block, alloy rear bulkhead, alloy rear hubs and a brass RF suspension hanger (which made a big difference in medium bite dirt)
The weight saving was, in no particular order:
Low profile servo
Ti screw kit
Ti turnbuckles
Ti ball studs
Carbon composite arms, c hubs and spindles
Light weight chassis (also played around with a milled standard chassis 8g lighter than the lw version, but somewhat extreme) - both had the sides milled to mount the shortie sideways.
MIP pucks (saved about 30g of rotating mass so a good starting point)
Exotek slipper eliminator - saved a fair bit too.
It all adds up, so take what you will from it. On reflection, the titanium bits were the highest $ per gram, so if I did it again I'd probably do those bits last and only if really needed.
RichD is offline   Reply With Quote
Old 02-21-2016, 09:23 AM   #13015
RokleM's Avatar
[JCO2157]
I think those are flat and don't have the curve to allow for some shock movement?
- Eric G. -
Old 02-21-2016, 10:01 AM   #13016
oPAULo's Avatar
No curve needed. I run these with a flat washer. Plenty of play.
http://www.amainhobbies.com/rc-cars-trucks/kyosho-3x4.3mm-aluminum-locknut-red-5-kyo1-n3043na-r/p169852
Old 02-21-2016, 11:22 AM   #13017
oPAULo's Avatar
Would you reuse carbide diff balls and thrust bearing or is the crunchy all in the rings?
I reused them once and it felt ok but I don't think it lasted as long. Are carbide worth the money or would it be wiser to just get regular and replace them every rebuild?
Old 02-21-2016, 10:31 PM   #13018
likea45's Avatar
Low profile servo
Ti screw kit
Ti turnbuckles
Ti ball studs
I'm considering the light chassis, a new low profile servo and a fantom slim shorty battery. Any part numbers for the carbon arms, hubs and spindles you mentioned?
Old 02-21-2016, 10:47 PM   #13019
I'm considering the light chassis, a new low profile servo and a fandom slim shorty battery. Any part numbers for the carbon arms, hubs and spindles you mentioned?
Front Hubs KYOUMW713
Rear arms (3 hole) KYOUMW711B
Front arms KYOUM710
Front knuckles (sorry wrong terminology) MYOUMW712
I sold my car a few weeks ago (kinda regretting it) but still have the lw chassis for sale (not a mark on it, apart from the milled sides) - not sure if the postage would make it a non starter for you? Anyway, pm if you're interested. If you search my previous posts it should come up.
Old 02-21-2016, 11:08 PM   #13020
likea45's Avatar
Front arms KYOUM710
Thanks for the part numbers. PMd you about the chassis.
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 11-22-2017 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
