    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 02-02-2016, 05:19 PM   #12991
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
I usually rebuild after a few months, depends on how often I'm at the track. My methodology is such that I check to see how much stiction is created by the shaft and seal set. I do this by removing the oil and just checking by hand how easily you can move the shaft. I also make sure that both sides are equal and also front to rear.
Stiction can make your shocks feel like you are running 40 wt when you only run 20wt.
Hope that helps!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 02-02-2016, 05:54 PM   #12992
oPAULo's Avatar
I'm going to have to put in some fresh seals so I can feel the difference. They've always felt silky smooth to me but I have have never felt brand new ones.
oPAULo is offline   Reply With Quote
Old 02-04-2016, 06:01 PM   #12993
oPAULo's Avatar
Where is the extra length of a 3 line axle? Inboard of the hex drive pin or outboard?
Old 02-05-2016, 03:16 AM   #12994
eper's Avatar
Trader Rating: 14 (100%+)
inboard by 4mm i believe they have a 4mm collar that is run on it in the buggies or u can run 2 2 mm collars to change wheel base and so on it could be 3mm but i think its 4
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 02-05-2016, 05:54 AM   #12995
oPAULo's Avatar
Ah haaa.
So to run standard rear width you have to send the drive shaft deeper into the outdrive and move the CVD indoard.
Does the position of the CVD effect performance ?
The Avid axles have the extra width outboard. If there is such a thing as wider hexes you could adjust rear width just by swapping hexes.
If you are, or know, a machinist, Durango 2mm CVD rebuild kit is a perfect replacement. Just got to turn the O.D. of the barrel.
Old 02-05-2016, 01:18 PM   #12996
eper's Avatar
it does change the plunge o the dog bone in the outdrive which effects traction
new milford ct,
Old 02-08-2016, 06:04 PM   #12997
cnelson3's Avatar
Trader Rating: 65 (100%+)
the 3 line axles are 2 mm longer. you can increase the length on either side of the hub with spacers. They are usually paired with the 62.5mm dog bones whereas the 2 line axles are usually paired with the 65.5 mm dog bones.
Kyosho America
Peak Racing
Trackside Hobbies & Raceway - Milwaukee, WI
cnelson3 is offline   Reply With Quote
Old 02-10-2016, 06:30 AM   #12998
I have made a 3 gear laydown box for the RB6. I didnt find a DIY/project part of the forum so i didnt know where to put it
This is for a custom motor plate, I have modified it to fit a Yokomo Plate aswell.
kleijon is offline   Reply With Quote
Old 02-13-2016, 12:05 PM   #12999
can someone help me out with the partnumbers for the aluminum mid motor rear suspension arm mounts. thanks in advance.
psycho02 is offline   Reply With Quote
Old 02-13-2016, 01:52 PM   #13000
orangutanracer's Avatar
Take a look at the first post in this thread.
Lots of good information and part numbers there.
orangutanracer is offline   Reply With Quote
Old 02-15-2016, 08:27 PM   #13001
does anybody know if the 2015 rb6 comes with a mid motor 3 gear transmission??? thanks
valdo0823 is offline   Reply With Quote
Old 02-15-2016, 08:51 PM   #13002
it does not. That is still a custom deal
scoobyrs25 is offline   Reply With Quote
Old 02-15-2016, 08:52 PM   #13003
gokarter64's Avatar
no they do not. kyosho does not make a 3 gear for the rb6, you have to make one yourself using a rear motor transmission case.
if you want to make one petit rc has a good tutorial on how to do it
http://site.petitrc.com/setup/kyosho...rtransmission/
Cars: TLR 22 3.0 Mod, Mugen MBX7 ECO, TLR 22 3.0 Stock, TLR 22-4, TLR 22T 2.0
Electronics: Airtonics, Orion, LRP, Xpert, Maclan
Goodies: Exotek, Avid, Raw Speed, Jconcepts, MIP . Paint By: Double Deuce Designs
gokarter64 is offline   Reply With Quote
Old 02-15-2016, 09:19 PM   #13004
thanks guys for the info, so whats the difference between the 2015 and the older model???
Old 02-16-2016, 03:33 AM   #13005
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
I think the only real difference is the new rear arms and different shock springs. Other than that its the same.
Team Kyosho (RB6, RT6, ZX6 & SC6)
Team Orion R10.1 Pro
Team Orion Touch Duo Charger
Team Orion Pro Carbon 100C Batteries
motorfinger is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
