    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-22-2016, 08:42 PM   #12976
oPAULo's Avatar
Avid long axles work great in MIP pucks drive shafts with just a little modding. I like the clamping hexes better than the MIP keyed hexes too.
First you have to open the bore of the MIP shaft by .005" on diameter. That's about the thickness of paper out of the wall of the bore. It doesn't take much. I used a square end carbide burr in a dremel. Do it quickly and smoothly to maintain roundness. It's really easy.
Then you just drill the cross holes in the driveshaft to 2mm accept the stock Kyosho CVD pin.
You could also use Kyosho 3 line axles or stock axles but the Avid axles are half the price. Right now I'm trying to find CVD hardware so I don't have to buy Kyosho axles just to get the hardware. Durango uses a 2mm pin but don't know about the size of the barrel. I'll have a set tomorrow and report back.
oPAULo is offline   Reply With Quote
Old 01-22-2016, 11:23 PM   #12977
cnelson3's Avatar
Trader Rating: 65 (100%+)
for those of you looking for a good setup for indoor med to high traction, i highly recommend the Chris Jarosz set up on KyoshoAmerica.com. So far, this is the best setup i've had on the car for indoors. It really lets you drive hard and the car is easy to drive consistently. The only change I have from his is the aluminum front toe block instead of the brass. Its awesome.
Kyosho America
Peak Racing
Trackside Hobbies & Raceway - Milwaukee, WI
cnelson3 is offline   Reply With Quote
Old 01-23-2016, 10:26 AM   #12978
oPAULo's Avatar
Avid axles in MIP driveshafts let me run D-in D-in. I wasn't able to with MIP axles as the driveshaft would bottom in the outdrive. The spacing of the CVD is deeper in the hub like a stock axle.
Old 01-23-2016, 11:23 AM   #12979
oops
scoobyrs25 is offline   Reply With Quote
Old 01-23-2016, 11:29 AM   #12980
oPAULo's Avatar
That's not where it goes??
Old 01-23-2016, 11:36 AM   #12981
cnelson3's Avatar
Originally Posted by scoobyrs25 View Post
Anybody notice Tebo is running the brass front arm mount UNDER the chassis at the Reedy Race right now?
His bumper seems to be different but the hinge pin blocks are normally run under the chassis.
I'm more curious as to why he's back to the standard chassis.
Kyosho America
Peak Racing
Old 01-23-2016, 11:44 AM   #12982
oPAULo's Avatar
Has there ever been evidence of a new chassis or is he just calling a drilled up and ground on old chassis the "new chassis"? LOL!
Old 01-23-2016, 12:55 PM   #12983
cnelson3's Avatar
yeah. If you look at pictures on Tebo's facebook page, you can see it. it's wider and appears a little longer but i can't say that for certain. It's the only part i'm really looking forward to. Well, that and a Kyosho 3 gear trans. My car is really competitive. I like the way it feels with gold front springs and gold rear springs and the new hole on the arms keep the back end planted. Not only that but if you don't like the gull wing arms, the straight arms are good too.
Kyosho America
Peak Racing
Old 01-26-2016, 06:18 PM   #12984
chiger's Avatar
Trader Rating: 111 (100%+)
So a few pages back you guys were talking about anti squat and what adding and removing each shim equals.... Are you saying that the spacer between the hanger and bulk head is only used for a spacer for the bulkhead and tower?
Ex.....no shim under hanger I would need to have a 1 mil spacer between hanger and bulkhead
Ex 2.... .5 shim under hanger I would need to have ,5 spacer between hanger and bulkhead
Ex 3... 1 mil under hanger I would need to have no spacer between hanger and bulkhead
Am I on the right path or no? Manual is unclear as I come from an associated background where their stuff is very easy to understand
Chuck Kinzer
Team Associated - Futaba - Trinity
chiger is offline   Reply With Quote
Old 01-26-2016, 07:01 PM   #12985
oPAULo's Avatar
That's exactly right.
Also got to run the bumper no matter how you shim it.
Old 01-27-2016, 06:18 PM   #12986
chiger's Avatar
Thank you
Chuck Kinzer
Old 02-01-2016, 05:41 PM   #12987
oPAULo's Avatar
Any reason to change shock seals other than they're leaking? Been running 2 buggies for about 6 months every weekend. Countless oil changes and still never had one leak. My spare seals are going to dry rot in the toolbox!
Old 02-01-2016, 09:59 PM   #12988
I have an Optima Mid with the original seals in the gold shocks, no leaks
Old 02-02-2016, 07:20 AM   #12989
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
They do swell over time, probably can't tell looking at them, and when they do they tend to grip the shaft more than normal.
When I go to a big race I usually start with a fresh set.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-02-2016, 07:49 AM   #12990
oPAULo's Avatar
Ahhh haaa....interesting.
That would explain why they never leak.
Picked up both buggies used so it's hard telling how old the seals are.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
