    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 01-14-2016, 08:30 PM   #12961
Wondering if an updated kit is coming soon..... Amain has had no RB6 kits in stock for a bit, HRP hasn't had one for weeks and Tower only has about 4.
could we be seeing a new kit with the 3 gear and sideways chassis soon??
KW Raceway https://m.facebook.com/kwraceway
Mugen Seiki/Yokomo Usa/Protek/Amain/R1 Wurks/Flashpoint/KW Raceway
robbie_gtc is offline   Reply With Quote
Old 01-14-2016, 08:31 PM   #12962
Trader Rating: 42 (98%+)
RZ6 chassis?!?!?!?!?!?!?!?
cobra408 is offline   Reply With Quote
Old 01-18-2016, 05:12 AM   #12963
oPAULo's Avatar
Anyone know of a cvd rebuild kit?
oPAULo is offline   Reply With Quote
Old 01-18-2016, 01:20 PM   #12964
Did anyone tried the Sworkz low rider on the RB6 ?
nikorentin is offline   Reply With Quote
Old 01-18-2016, 03:00 PM   #12965
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I don't believe so. I have just purchased complete pieces or the drive shaft. Very rarely have I had to replace anything else.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-18-2016, 03:45 PM   #12966
oPAULo's Avatar
I couldn't find anything.
Trying to save some money. The pucks setup lasts forever but can't get MIP axles anymore. Avid axles are half the price of KYO but don't come with the CVD parts. With just a little machine work I'm going to put Avid axles in MIP pucks drive shafts but need stock size CVD parts.
I just can't see spending 60 bucks on stock outdrives and drive shafts and axles when I got the whole car for 100.
MIP kinda messed up by inventing the pucks system because if you take care of them properly they really do last forever. My son beats the time out of his buggy. 3 dollars worth of pucks every now and then and it's good as new. Outdrives are still perfect. I have a whole new pucks setup for mine but zero spare axles so I'm saving the axles in case he breaks another one and trying to set mine up as cheaply as possible yet still have off the shelf stuff that doesn't require machine work.
I'm going to have to bite the bullet on something soon though. My stock shafts and outdrives are just about gone.
Old 01-18-2016, 07:07 PM   #12967
A couple of things;
First did I miss something with setups? It seems like there was a huge push for as narrow as possible for the rear hinge pins and buy the 3 line axles space them out. Blah blah blah, now tebos most current set up has the car set up to its widest potential front and back?
Second has anyone ran the JTP towers? Do they really make a differenc?
CaseyD is offline   Reply With Quote
Old 01-18-2016, 07:33 PM   #12968
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
If it's the stock kit CVD parts you need, just buy new axle stubs, they come with the CVD parts and should only run you 20 bucks for a pair of the or less
If running the stock diff and bones, grease them some and it should help them last longer. Also you can repin the bones with some Traxxas 2.5x12mm pins and they do seem to last longer than the stock pins.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 01-19-2016, 02:55 AM   #12969
eper's Avatar
Trader Rating: 14 (100%+)
check out the rb6 and zx6 group on fb theres a guy running that tranny on his 6
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 01-19-2016, 11:59 AM   #12970
Trader Rating: 21 (100%+)
I'm looking at getting a Rb6, but the one I'm looking at is setup as a MM. What parts are needed to convert back to RM? MM doesn't work at our low bite outdoor track. Thanks gents.
joel45acp is offline   Reply With Quote
Old 01-19-2016, 03:09 PM   #12971
GIHOSU's Avatar
You may want to give it a try, I acquired a couple of RB6s and we have been making them work on low traction dirt tracks. My MMs always make up time in tight sections.
To switch you need a diff case, bulkhead, shock tower, and hinge pin brace. Maybe 1 or 2 other minor things. Almost anyone here including me could sell you the parts.
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 17.5 Turf ~ RB6 17.5 ~ RB6 ~ RZ6 Turf ~ RT6 Turf ~ SC6 17.5 ~ SC6 ~ SC6 Turf ~ ST-RR Evo.2E
TEKNO - SCT-410 ~ SCT-410.3
GIHOSU is offline   Reply With Quote
Old 01-20-2016, 11:21 AM   #12972
Just got me this beauty. Might try MM at our track but I'm sure it'll get switched to RM very soon.
Old 01-20-2016, 12:52 PM   #12973
Any ETA on the new chassis?
Old 01-22-2016, 09:43 AM   #12974
Any of you gents running MM on loose 8th scale, semi smooth outdoor tracks? Need some pointers on base setup for such a track. Thanks in advance
Old 01-22-2016, 02:22 PM   #12975
cnelson3's Avatar
Trader Rating: 65 (100%+)
Tanner Day ran an outdoor event sometime last year (2015) and I heard his rear motor setup was really good. I think arms were spaced to D out/ D out. Maybe petit rc has it.
cnelson3 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Yesterday 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
