    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 01-11-2016, 02:06 PM   #12946
So I had my first race two weekends ago and I'm just now getting back on here. I placed 3rd with my SC6 and 33 of 38 in 2wd buggy with my RB6. My car seemed a bit slower than the rest and I'm running an old Orion VST 9.5t bought on this forum. Are most of you guys running 8.5t? And also without getting into much detail what can I do to keep the rear ended planted if turning off power at the end of the main straight. I never spun all the way out but boy she was loose when I had to get off the throttle. All I did was turn my drag brake to 0% as I was afraid that was causing my issues but it didn't change a thing. It was my first off road race ever so I sure as hell cant write off my lack of driving skills. Any basic tuning I can try to keep her planted off throttle? Or any driving advice even?
DSK901 is offline   Reply With Quote
Old 01-11-2016, 06:58 PM   #12947
oPAULo's Avatar
Where is your battery?
My son and I are both pretty new drivers and getting weight to the back really helped us. His car still has the speed control on a shelf in front of the waterfall and I think it handles great! I moved my battery under the waterfall then tried sideways battery all the way back. As my driving gets better I'm slowly moving weight forward for more steering.
oPAULo is offline   Reply With Quote
Old 01-12-2016, 09:58 AM   #12948
I am running a shorty, standard configuration, with the factory battery mounts moved as far back as possible and no foam just a perfect fitting battery. I have my receiver mounted on the shelf/rear battery holder. I have my esc on the chassis in front of the battery and behind the servo. I feel like I can handle the steering, and overall the buggy feels and handles great, just having that issue with top speed straightaway to sweeper corner braking/turning. Also would adjusting my differential help with this problem?
Old 01-12-2016, 09:58 PM   #12949
Let me apologize in advance but I've been on a bit of hiatus. I've seen the new chassis in pics and you can see the extra holes and the new side rails to allow the sideways battery configuration. What I can't tell is if Kyosho is making that area of the chassis flat or is Kyosho just giving foam with the chassis for the battery to sit on? From the underneath pics you can still see there is a heavy edge on the chassis.
CaseyD is offline   Reply With Quote
Old 01-13-2016, 04:11 AM   #12950
eper's Avatar
Trader Rating: 14 (100%+)
have you played with your break settings in your esc and or radio. what brands are you running?
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 01-13-2016, 06:52 AM   #12951
There is no kit option for sideways battery. Even with the newest lightweight chassis (what I have), you still have to grind the chassis down and cut the plastic side rails. If you don't grind the chassis, you will have your battery up a little higher with no support underneath and you'll have to use spacers to raise up your battery strap a bit.
Callaway is offline   Reply With Quote
Old 01-13-2016, 08:45 PM   #12952
GIHOSU's Avatar
Try taking away some ackermann, place spacers under your steering rack ballstuds. Go .5 or 1mm and see if it works for you.
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 17.5 Turf ~ RB6 17.5 ~ RB6 ~ RZ6 Turf ~ RT6 Turf ~ SC6 17.5 ~ SC6 ~ SC6 Turf ~ ST-RR Evo.2E
TEKNO - SCT-410 ~ SCT-410.3
GIHOSU is offline   Reply With Quote
Old 01-13-2016, 08:50 PM   #12953
GIHOSU's Avatar
Loosening the diff a tiny bit can free up the buggy and give a little more turn in.
Old 01-14-2016, 08:24 AM   #12954
skrichter's Avatar
Send a message via AIM to skrichter
Why does this car seem to work better with only 25deg of kick/caster? TLR/AE, all run 30deg total kick/caster.
Curious what other's have found.
Interesting ride height....
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 01-14-2016, 09:30 AM   #12955
oPAULo's Avatar
Also a "New Flat Chassis". Hmmmm...
Old 01-14-2016, 11:34 AM   #12956
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I personally like 29 degrees or when I get it wrong, 21.
It is all about driving style, but you already know that.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-14-2016, 11:37 AM   #12957
Super Moderator
Kraig's Avatar
Could this be a three gear transmission with the motor rotation reversed in the speed control? I am used to seeing the spur gear on the other side.
Old 01-14-2016, 12:17 PM   #12958
dmcguire's Avatar
Trader Rating: 22 (100%+)
I think the flat chassis is most likely the sideways shorty chassis.
dmcguire is offline   Reply With Quote
Old 01-14-2016, 03:36 PM   #12959
oPAULo's Avatar
Well then it should say "hacked up and ground on old chassis" and not new flat chassis....
Old 01-14-2016, 07:58 PM   #12960
Super Moderator
Kraig's Avatar
It is a new chassis but not yet available to the public.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Today 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
