    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 10-09-2012, 11:44 AM   #1276
CanyonCarverR1's Avatar
Who makes the delrin sus. bushings?
CanyonCarverR1 is offline   Reply With Quote
Old 10-09-2012, 11:44 AM   #1277
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Kyosho standard part
http://www.amainhobbies.com/product_...Bushing-8-ZX-5
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-09-2012, 11:48 AM   #1278
Anybody have a problem with the rear camber link clearing the hub at full compression when using the outer hole?
Old 10-09-2012, 11:54 AM   #1279
Super Moderator
Yeah, that can happen. If you raise the camber link on BOTH ends by a mm, it won't change your roll center too much, and it should clear. Or you can shave the ballcup to clear. (i think)
- RCSpecialties -
Old 10-09-2012, 12:28 PM   #1280
Super Moderator
I take that advice back about shaving the ballcup... it says right here on page 5 of the manual:
"To avoid causing irreparable damage, do NOT attempt any modifications".
bummer
- RCSpecialties -
Old 10-09-2012, 12:32 PM   #1281
Are the shocks on the RB6 different from the ones on the RB5 besides the aluminum top cap?
arashi is offline   Reply With Quote
Old 10-09-2012, 12:41 PM   #1282
Suspended
Trader Rating: 7 (89%+)
Is tebo winning anything with this rb6 yet.
ohiofun13 is offline   Reply With Quote
Old 10-09-2012, 12:43 PM   #1283
fullsyzz's Avatar
Trader Rating: 103 (100%+)
He is winning my heart. Does that count?
fullsyzz is online now   Reply With Quote
Old 10-09-2012, 12:45 PM   #1284
Suspended
Lol
Old 10-09-2012, 12:45 PM   #1285
Originally Posted by Matt Trimmings View Post
Hey guys, had a quick question for you, i was looking through some of the rb6 stuff and it looks like the step 2.0 rear wing is really popular. Then i check the price out and its about $14 for one wing...im a AE guy and usually use the JC wings and get 2 for about $8-10. Are the kyosho wings molded out of a thicker lexan, like the LMR wings? Also, just curious, did any of you used to have a B4.1 that could compare the rb6 to? I just saw my first one run this past weekend and it looked awesome. Thanks!
There is a difference between the Kyosho and JC wings. I have found the Kyosho wings to be more brittle and prone to tearing than the JC. Having said that, I feel like the Kyosho wings function much better.
I ran the B4.1 WC car for about 3 months, switched back to the RB5, and now run the RB6. Hands down, the RB6 is the smoothest car I have owned, and I have had them all. I feel that the RB6 has more on/off power steering and corner speed than the B4.1; not by a huge margin, but definitely noticeable. I will also mention that the RB6 navigates corners with a great deal of fluency and composure, which just makes it easy to drive. As far as traction is concerned, I would say the B4 and the RB6 are on equal grounds, never had any complaints in this department with either car. The RB6 is a very balanced car, consequently, it jumps and handles the rough sections better than the B4.1. Another big factor when I choose a car is durability. I work so much that when I do have free time, I don't want to spend all of it doing maintenance on my rc cars. The B4.1 required so much attention to keep in a "race ready" state; my actual driving time was cut in half. There really is no comparison between Kyosho and Associated quality. If you are going to be at either the AZ states race or SIGP, send me a PM.
Entr0phy is offline   Reply With Quote
Old 10-09-2012, 12:57 PM   #1286
carcrusher46's Avatar
Trader Rating: 17 (100%+)
If I remember right, my WC big bores came with the x-ring seals, but the RB6 comes with standard silicone o-rings. Those and the caps are the only two differences I noticed in the shocks.
Matt Stoltz
Thank you to my sponsors:
Team Associated - Reedy - JConcepts - Life Fast RC Paintworks
carcrusher46 is offline   Reply With Quote
Old 10-09-2012, 12:58 PM   #1287
I prefer the standard o rings as have found the x rings bind. They were perfect in my 511.
Crap in std Kyosho shocks.
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 10-09-2012, 01:08 PM   #1288
Super Moderator
Iv used the Xrings and Orings in my big bores... Both are equally smooth, neither let any dirt in, and neither let any oil out... neither seem to stick.
- RCSpecialties -
Old 10-09-2012, 02:05 PM   #1289
Ok cool that's what I thought. I couldn't figure out why one set of big bore shocks cost more than the other besides the fact one was blue anodized and the other was gunmetal anodized on infernos only dot com.
Please add "www dot infernosonly dot com" to the front of each half link below to view. I guess I'm not allowed to post actual links cause I don't have enough post...
/Kyosho_Rear_Big_Bore_Velvet_Coat_Shocks_38mm_p/kyow5304v.htm
/Kyosho_Rear_Big_Bore_Velvet_Coat_Shocks_38mm_GM_p/kyow5304gm.htm
Am I missing something???
Old 10-09-2012, 03:14 PM   #1290
Super Moderator
Yep.. the blue colored shock kits and pieces are all cheaper because that color was being discontinued. Functionally, they are the same.
- RCSpecialties -
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
