    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 12-22-2015, 01:37 PM   #12871
cnelson3's Avatar
Trader Rating: 65 (100%+)
Originally Posted by Motorman007 View Post
why C-in/C-in? 3.0 deg of toe
Sorry still learning the Buggy pills.
and A/A is 3.0 deg of toe.
and B-out/B-out is 3.0 deg of toe
and C-out / C-out is 3.0 deg of toe
and B-in / B-in is 3 deg of toe
and D-in / D-in is 3 deg of toe
Why so many 3.0 deg settings?
Thank you M
The pills change the pivot width at either the front or the rear of the rear arm blocks. Using the same pill letter for the front and back will change the track width but this also has an affect on the roll center. Using different pill letters will change the sweep of the arms and also the toe on the rear tires.
Kyosho America
Peak Racing
Trackside Hobbies & Raceway - Milwaukee, WI
cnelson3 is offline   Reply With Quote
Old 12-22-2015, 01:43 PM   #12872
Motorman007's Avatar
Trader Rating: 78 (100%+)
I have C out and C out now.
Should I go to C in and C in?
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 12-22-2015, 01:55 PM   #12873
cnelson3's Avatar
For an indoor track, I'm currently running b in /b in. What are you looking to gain
Kyosho America
Peak Racing
Old 12-22-2015, 02:37 PM   #12874
Good question? Sir.
What should I start off with?
C in or b in
3.5
C in front and B in worked great Tues.. Thanks for your help
Old 12-22-2015, 08:47 PM   #12875
Trader Rating: 67 (100%+)
Okay, since Avid has ceased production on the shock/turnbuckle tool, what is everyone using to adjust the turnbuckles and removing the shock cartridge?
"Wow he's really fast isn't he????.....Yeah but he's Stupid"
lyork is offline   Reply With Quote
Old 12-22-2015, 09:15 PM   #12876
small mini monkey wrench
iMarky is offline   Reply With Quote
Old 12-23-2015, 05:18 AM   #12877
I need to replace the pin in the axles with something stronger anyone have a idea what I can use?
Do kyosho make these stronger or any other company?
or just some old AE pins are my best bet?
Kyosho Ultima RB6 & RB6.6 Car Thread-associated_universal_axle_spring_roll_pin.jpg
Old 12-23-2015, 05:35 AM   #12878
oPAULo's Avatar
For real?? I can't imagine breaking or even wearing out hex pins.
I wouldn't use spring pins. They'd be a pain to get in and out.
Maybe cut the end off a high speed steel drill bit of the proper size but that's basically what the stock pin is. Or a carbide drill bit.
Stock pins are very hard. You may have other problems.
oPAULo is offline   Reply With Quote
Old 12-23-2015, 05:43 AM   #12879
Yeah i got it 2nd hand it had some ##$$$# pins sir. And one broke. So they are not the stock ones. If can get the stock ones I would?
And this is a great idea sir. I will do just that. Brill bit.
Thanx
Old 12-23-2015, 08:08 AM   #12880
whitrzac's Avatar
Trader Rating: 95 (100%+)
I've used cut up body clips without issue. I can't remember breaking a pin in the axle.
The axle usually snaps first.
whitrzac is offline   Reply With Quote
Old 12-23-2015, 12:18 PM   #12881
tsair's Avatar
My LHS is selling the RB6 for $300, which seems like an amazing deal. Someone convince me why I should buy this car instead of a 22 3.0, which is about the same price, I need an excuse!
tsair is offline   Reply With Quote
Old 12-23-2015, 12:57 PM   #12882
oPAULo's Avatar
I've seen a lot of new 3.0's at the track and haven't seen any miracles.
Mid pack drivers are still mid pack.
Fast guys are still fast.
A couple fast guys seem to have gotten a touch slower and say they're still figuring out the new platform.
I've looked real close at B5M's and 3.0's and I'm sticking with the RB6 a while longer.
I've also been following the 3.0 thread. Some are still running KYO springs and they still compare the shocks to the RB6 shocks.
Old 12-23-2015, 01:09 PM   #12883
Trader Rating: 24 (100%+)
When are the new chassis and side pods supposed to be out? Wonder if they're on the boat and just not available yet...
fenton06 is offline   Reply With Quote
Old 12-23-2015, 04:10 PM   #12884
nitro2be's Avatar
Simple question, adding shims under rear hanger/bumper will decrease anti squat? No shims anywhere just bumper =2 degree. Right?
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 12-23-2015, 06:02 PM   #12885
oPAULo's Avatar
Ok. You asked for it...
#1.
The manual calls for 1mm worth of shim either on top of or below the rear hinge pin holder, OR, 0.5mm in each spot.
This keeps the distance from the chassis to the transmission mount at the stack up dimension it was designed to have.
My measurements are as follow.
No shim under the rear hinge pin mount = 2.225 degrees
0.5mm under = 1.484 degrees
1mm under = 0.742 degrees
Here's my math.
Any input is welcome.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
