    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-21-2015, 03:05 PM   #12856
RokleM's Avatar
Trader Rating: 33 (100%+)
Originally Posted by RokleM View Post
It is not as wide as some of the larger wings. I will take a picture tonight.
Actually after looking at it, it appears to be nearly the same size as the stock RB6 wing. Granted, there are quite a few over-sized wings you can also buy. The two small drilled holes also line up with the exotek wing mount.
- Eric G. -
Tekno EB48.3, NB48.3, ET48.3, NT48.3, Kyosho RB6, RT6
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 12-21-2015, 03:54 PM   #12857
Nice, thanks for the pic. I will definitely be buying one of those tonight. It's my first 2wd buggy, so I'll definitely be on the lid a little bit.
Any tire suggestions for an outdoor loamy clay track?
DSK901 is offline   Reply With Quote
Old 12-21-2015, 03:56 PM   #12858
RokleM's Avatar
Depends how loose it is, but Pro-line blockades or hole shots are a good start for outdoors if the surface is loose/loamy.
- Eric G. -
Old 12-21-2015, 04:32 PM   #12859
oPAULo's Avatar
I like it! What's the width? 6 inches? 6 1/2?
oPAULo is offline   Reply With Quote
Old 12-21-2015, 04:40 PM   #12860
RokleM's Avatar
6.5 wide, 2.75 deep, 1.25 tall roughly
- Eric G. -
Old 12-21-2015, 05:21 PM   #12861
oPAULo's Avatar
Thanks man!! Going to have to order one up.
Old 12-21-2015, 09:35 PM   #12862
likea45's Avatar
Sworks wing? If so I'm running the same. Clip it down how you like it, mount it up and forget about dealing with your wing ever again.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 12-22-2015, 05:57 AM   #12863
Regional Moderator
RobsRacin's Avatar
Ive recently started running the xray wings on my RB6, I cant seem to break these things!! They appear to be a bit bigger than the stock kyosho wings or the losi wings I was running but I like them
RobsRacin is offline   Reply With Quote
Old 12-22-2015, 06:21 AM   #12864
RokleM's Avatar
So still being new at the RB6, I'm fighting the rear traction in 17.5 stock. Is one of the reasons for the sideways battery mod more rear weight for traction?
- Eric G. -
Old 12-22-2015, 06:25 AM   #12865
Regional Moderator
RobsRacin's Avatar
Yes, that is one of the reasons, but I also feel it makes the car more stable. Do you have the aluminum rear hangers? What settings? I had 15 grams attached to the rear bulkhead under the wing mounts with my stock car as it felt a little loose.
Also what rear springs and also shock setup?
Old 12-22-2015, 06:51 AM   #12866
RokleM's Avatar
Yeah, not sure I want to hack up the plastic yet.
Still working on the setup. Kyosho is a great manufacture, but have to say their setup sheets leave something to be desired and are a bit difficult to read. I'm trying to interpret the pill setup and make sure I've got it correct.
1.6x2 450 pink front
1.6x2 450 gold rear, second hole from inside top, inside arm
metal suspension holders, metal 0 degree hubs
battery placement is as far back as it goes on the chassis
A front/rear pills
forward/outside hub location
- Eric G. -
Old 12-22-2015, 07:35 AM   #12867
Regional Moderator
RobsRacin's Avatar
A front/rear pills
If you want I can make a set up sheet for mine, but it include the sideways battery. Although I did not change anything else when I switched to the sideways battery, atleast setup wise on the car.
As for shock setup I know im at:
2x1.6 with 32.5 TLR oil with a pink spring up front
2x1.7 with 27.5 TLR oil with gold spring in the rear.
The back seems a little soft so im going to try 30 weight in the rear on my next outing.
As for the aluminum hangers im running C-in C-in and have left it there.
I will try and find my setup sheet from before I made the sideways battery tonight. What surface do you run on? I have both hard packed soil as well as med bite clay
Old 12-22-2015, 08:34 AM   #12868
oPAULo's Avatar
Is your battery all the way back under the waterfall almost against the motor?
Old 12-22-2015, 12:48 PM   #12869
RokleM's Avatar
A/A C-in/C-in appear to both be 3. Surface is actually where Tebo was a couple of weeks back, Speed RC. It's indoors, moist, hard packed.
Battery is right at the edge of the waterfall, the last spot it can be before cutting
- Eric G. -
Old 12-22-2015, 12:58 PM   #12870
Motorman007's Avatar
Trader Rating: 76 (100%+)
why C-in/C-in? 3.0 deg of toe
Sorry still learning the Buggy pills.
and A/A is 3.0 deg of toe.
and B-out/B-out is 3.0 deg of toe
and C-out / C-out is 3.0 deg of toe
and B-in / B-in is 3 deg of toe
and D-in / D-in is 3 deg of toe
Why so many 3.0 deg settings?
Thank you M
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
