    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-10-2015, 03:30 PM   #12841
oPAULo's Avatar
My sideways battery mod. If you just cut the plastic and don't touch the aluminum chassis it will space a shorty off the chassis 3mm. I wanted to try this first because shaving the angles off the chassis plus removing the side plate screw is going to allow for a LOT more flex. I wanted to try one thing at a time. The extra weight over the rear helped on our local hard slick dusty track. I drilled the chassis to put the battery brace in position for an inline battery all the way back almost against the motor in case I wanted to switch back real quick. I spaced the battery clamp and waterfall up off the chassis 3mm to use the stock hold down. More testing is required.
oPAULo is offline   Reply With Quote
Old 12-20-2015, 04:14 AM   #12842
eper's Avatar
Trader Rating: 14 (100%+)
well since its been so dead on here im guessing someone found the magic setup and we cant make this dam car any better. no ones trying anything new or has any ideas? my cars good but coukd be bettter
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 12-20-2015, 08:27 AM   #12843
Well, I just bought an RB6 on the FS forum yesterday so I don't even have my hands on it yet. I also just got an SC6 and am getting back into this hobby after a 10+ year hiatus. I am so pumped. My RB6 is a roller as of now, as I am trying to purchase an ESC and motor here in the forums as well. What turn motor would you all suggest that I put in this thing. I will be mainly backyard racing, on manicured tracks, one is rather small and the other is 1/8 scale sized. And I have never owned a 2wd buggy before either, although at about 8 or 9yrs old my dad's neighbor had a "nice/aka faster than anything I had ever driven" radio shack 2wd buggy that jump started my passion for this hobby. I am really looking forward to getting this thing running for some January racing for my birthday. Any newbie advice is welcomed, and I have yet to have time to read thru this 850+ page although I have gotten started. Thanks in advance.
DSK901 is offline   Reply With Quote
Old 12-21-2015, 03:21 AM   #12844
eper's Avatar
well i hope u have fun with it id probably say just start with a 10.5 motor as most back yard tracks are blown out or atleast lomey and u will be looking for traction. you may want to run rear motor setup as well. i never seen your tracks bt those are my thoughts. also get the rear aluminum rear suspension hangers and fill the empty ball stud holes in with set screws.around front and rear camber link position. just helps strengthen the plastic
new milford ct,
Old 12-21-2015, 06:04 AM   #12845
Motorman007's Avatar
Trader Rating: 76 (100%+)
What wing is that sir? And does it hold up well?
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 12-21-2015, 06:19 AM   #12846
oPAULo's Avatar
Pro Line Trifecta.
It holds up like no other wing. SUPER beefy.
Yes, it is thicker and it's hard to get the pins in the stock mount with the stock wing washers but it fits on there just fine.
The extra thickness also make it heavier. That's a small price to pay for a wing that can take a beating.
I'll weigh it tonight and see how much heavier.
Old 12-21-2015, 06:55 AM   #12847
RokleM's Avatar
Trader Rating: 33 (100%+)
Pro Line Trifecta.
The pro-line is definitely beefy if you're looking for a traditional wing. It will last quiet a bit longer than most of the other brands I've tested. As well I had a spare sworkz in my box I tested last night, which also fits if you're wanting a black wing. Bonus, it's plastic, not lexan.
http://www.amainhobbies.com/rc-cars-...800abk/p267310
- Eric G. -
Tekno EB48.3, NB48.3, ET48.3, NT48.3, Kyosho RB6, RT6
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 12-21-2015, 06:59 AM   #12848
so you like the sworkz PLASTIC WING?
Old 12-21-2015, 07:03 AM   #12849
oPAULo's Avatar
Wow I like that too! How wide is it?
My son goes through wings like oreo cookies....
Old 12-21-2015, 07:10 AM   #12850
RokleM's Avatar
To be determined. It's been many years since I raced 2wd indoors or 1/10th, so just getting back into it. I raced the RB6 the first time yesterday, so tons of changes and testing. Rear end is very loose in acceleration, so need to lock that down. I tested three wings and didn't notice a ton of difference between them. The sworkz being plastic is thick, flexible, but does weight a bit more than any lexan wing. It has the bonus of super flex so technically it might last a lot longer than lexan, but time will tell. Hope to do more testing in the coming weeks with various setups including stock, pro-line, etc.
- Eric G. -
Old 12-21-2015, 07:10 AM   #12851
Yeah, thanks for that plastic wing info. I think I'll go ahead and order one when I order my receiver today. Might as well because lord knows 10 years off the track and I'm gonna burn through some wings fast lol.
Old 12-21-2015, 07:11 AM   #12852
RokleM's Avatar
It is not as wide as some of the larger wings. I will take a picture tonight.
- Eric G. -
Old 12-21-2015, 08:52 AM   #12853
Tpg racer's Avatar
Just recently got the Kyosho SC6 and raced it yesterday at my local track.
Now thinking about running 2wd 17.5 stock class as well. Anybody here could point out what the differences are between 2015 RB6 and the older version?
Tpg racer is offline   Reply With Quote
Old 12-21-2015, 09:18 AM   #12854
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
The updated car comes with the newest rear wing, updated rear arms and gold rear springs.
Dayton
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
Old 12-21-2015, 09:22 AM   #12855
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Not much, I think the chassis has additional holes, different springs.. I think that's it.. Lol.. After the worlds in 2013,we all thought Kyosho would have a le wc edition, but never happened.. Not really much to ad except, rear hubs and aluminum steering rack and maybe the brass pieces for tuning.. I think that's all tebo ran as far as hop ups.. Amain gives a description of the new features
hairymuffin is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
