    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 12-01-2015, 03:43 AM   #12811
oPAULo's Avatar
What about where the transmission mounts to the bulkhead?
If you remove all the shims you'd have a gap in there.
oPAULo is offline   Reply With Quote
Old 12-01-2015, 05:58 AM   #12812
Originally Posted by K_King View Post
The wheelbase section is for both hubs and arms. Follow the lines to either or. It's a bit confusing. I shim my arms forward 2mm and run hubs in the middle.
Anti-Squat is done on the rear pivot because of the angle. The pin is higher on the F holder so you couldn't go lower there unless you made your own pills or holder.
Basically imagine the front pivot is locked and you are moving the rear up to level the pin out. The straighter the hingepin the less Anti Squat you have so you get more sidebite and an overall softer rear end.
I either run .5 on the bottom and .5 on the top or 0 on the bottom and 1mm on the top. I've tried 0 on the bottom and the rear gets really soft and doesn't work like I want it to.
Technically only the bottom shim affects anti squat. The one between the pivot and the rear bulkhead is a bit confusing. You don't really need one there and I was talking to another driver last night about the lack of info on it. I've always assumed that all of the shimming there had to equal 1mm to keep the tower in the same spot. However one could also assume that shim is just like the front pivot shim where it's used to change roll center as well. The thing that bugs me is that moving the entire tower up changes a lot of stuff like shock angle, droop, roll center and CG. I would assume having no shim would be the most aggressive since it's like lowering the ballstud but nobody has ever talked about it.
If you ever decide you don't want to run the shim between the bulkhead and the pivot, make sure you put some shims under the transmission mount (where it mounts to the bulkhead) or it will bind up. For example, if you run no shim on the bottom, and no shim on the top, then under the transmission mount you would add 1mm.
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Old 12-01-2015, 09:06 PM   #12813
For anyone using the JTP rear shock tower-
Jason Dias
Old 12-02-2015, 03:17 AM   #12814
eper's Avatar
Trader Rating: 14 (100%+)
i dont have any gap issues...um lol
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 12-02-2015, 03:28 AM   #12815
oPAULo's Avatar
Isn't that wrong on the anti-squat shims?? It's bass akwards.
Old 12-02-2015, 06:23 AM   #12816
yodace's Avatar
R/C Tech Charter Subscriber
What is needed to convert a rb6 to the 2015 rb6?
yodace is offline   Reply With Quote
Old 12-02-2015, 03:24 PM   #12817
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
What do you guys hear for a 13.5? 28/76?
K_King is offline   Reply With Quote
Old 12-03-2015, 12:48 AM   #12818
Are you referring to my post about running no shims?
If so take your pinion off and check if you transmission spins freely.
Jason Dias
Old 12-03-2015, 02:37 AM   #12819
We don't know what degree Jared is referring to in his image, he could be talking about the degree of change (delta) from what he has learned, but let me try and clear up any confusion.
From what I understand (based on my own measurements, so I could be wrong) no shims under the rear sus block equals 2* of anti-squat, which is the most anti-squat you can get without adding shims under the front sus mount.
As you add shims under the rear sus block, you're taking away anti-squat (leveling out the arms). Each shim (0.5mm) equals roughly 0.75*, so 1mm equals 1.5*.
That means thick (1mm) shim under the rear sus block would bring the total anti-squat to 0.5*, and the thin (0.5mm) shim would bring the total to 1.25* of anti-squat.
Jason Dias
Old 12-03-2015, 03:30 AM   #12820
eper's Avatar
my tranny is very free. i understand what u are saying 100% with shimming it to not twist or force anything in a certain direction. i measured the tranny rear mount height and my rear tower bulkhead height and this is what works in the back of my car. maybe it has to do with there allowable tolerances i dontknow
new milford ct,
Old 12-03-2015, 05:22 AM   #12821
Hmm, I am not sure how it would be free, unless it's not tightened all the way? I am a stock racer, so our definitions of "Free" could be a little different, for example with the pinion removed from the motor, no tires, a Schelle spur with slipper eliminator, and ceramic bearings, mine will spin for 46 seconds with a decent flick. It's so free it would actually rock back n forth with the wheels on if they're out of balance.
If I were to run 0 shims (which I did for a long period of time when the RB6 was first released) my transmission was completely bound up until I added shims between the transmission mount and the bulkhead, they're difficult to slide in place, but I highly recommend you add them, if anything for the peace of mind that it's all solid, and secure.
But if it works they way you got it, then no sense in changing anything
Jason Dias
Old 12-03-2015, 06:27 AM   #12822
Trader Rating: 75 (100%+)
Are you all referring to part #s UM508C & UM726
gixxer420 is offline   Reply With Quote
Old 12-03-2015, 07:47 AM   #12823
Currently I am running a thin shim under the rear suspension block and thin shim under the bulk head. In theory this should leave me at 1.25 degrees of anti squat. I am using Tebo's front and rear shock towers. would like to hear about running 0.5 degree and 2.0 degree anti squat and what that specifically does (handling wise).
Since I have a total of 1mm shim, I don't believe I need to add anything under the trans mount to the bulkhead. Is that correct??
Turbo
Turbo911 is offline   Reply With Quote
Old 12-03-2015, 08:25 AM   #12824
Motorman007's Avatar
Trader Rating: 78 (100%+)
Can't get a picture of where to do this sir. Can you point me in the right places So that I can understand thank you sir
I got it that little lip in the back that goes under the shock tower. Got it.
YOU WILL (ALWAYSWIN).....
Motorman007 is online now   Reply With Quote
Old 12-03-2015, 05:30 PM   #12825
eper's Avatar
46seconds holy crap mines not that fre but its as free as when its nt in trhe car and everything is tight sir
new milford ct,
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22953 Today 12:29 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
