    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 11-24-2015, 08:48 AM   #12781
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by oPAULo View Post
All pretty close on backspace and width.
From what I have been told, the Associated big wheels are wider than the others which would make the tire flatter. I have not confirmed this nor have I tried them.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-24-2015, 01:09 PM   #12782
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Hey All, hope you are all having a nice thanksgiving holiday (I know it's early, but I'm ready for a long weekend already)
I've just upgrade my servo to the Futaba 9352HV which I am also running in my D413. It's a fricking monster servo. Unfortunately the ears are spaced a little "higher" than my savox so it doesn't reach the holes unless I use a spacer. I'm guessing some of you guys are also runnign this servo so I'm wonder what you are using for spacers? I think I saw some avid carbon fber crazyness....
Also, do you guys use the rubber mounts on the ears or do you just use the bare ears?
Pics are awesome too. Thanks in advance!
Dave
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 11-24-2015, 01:19 PM   #12783
oPAULo's Avatar
Dave
Bare ears with washers.
I'm guessing you'll have to grind some clearance in the underside of the front brace that goes above the servo. There is very little clearance for a standard size servo. I run the Losi aluminum servo arm with a locking nut and had to grind just a touch of clearance for it.
Be sure to check the manual for proper front to rear spacing. You measure the servo and shim it accordingly.
oPAULo is offline   Reply With Quote
Old 11-24-2015, 01:40 PM   #12784
13Maschine's Avatar
@oPaulo - What servo are you using? I'm also using the TLR servo horn with a locknut and didn't have to grind for clearance with my old servo. It should travel in the same area with the new servo given the front to rear alignment is the same.
Are you using spacers behind the servo ears in between the servo mounts and ears? if so how much?
Old 11-24-2015, 02:38 PM   #12785
13Maschine's Avatar
I ended up moving my battery pack back one space and also pushing my ESC and receiver back a little allowing me to mount the Futaba servo with no spacers.
The futaba 9252HV servo is about 3-4 grams heavier than my savox 1258. Just FYI, especially for those wanting more weight up front.
Old 11-24-2015, 02:49 PM   #12786
oPAULo's Avatar
Holy crap my stuff is filthy with the flash on!! That's what non stop racing does I guess.
You have to measure the servo to determine the spacer.
The Savox 1258 didn't need one.
Radiopost red needs 1mm
Reedy RS1206 gets 2mm
It's in the manual.
Oh I ground this spot at full left lock. The nut was touching it. The other spot was for the Yaiba steering rack. The arms are thicker and made clearance issues.
Still, I don't have any room to space a servo up off the chassis. The rod end would rub at center point.
Old 11-24-2015, 03:03 PM   #12787
oPAULo's Avatar
The aluminum front arm mount puts a stop to this.....
Highly recommended. Don't think your plastic one is tweaked? Check it. Check it good. Check it every time you catch a pipe.
Old 11-24-2015, 03:30 PM   #12788
oPAULo's Avatar
Been looking a lot lately at different platforms. 22 3.0 has really caught my eye. But then, I think of that dude at I met at Horizon race rocking an aluminum tub late 80's RC10 and turning fast laps. It was awesome to watch. He had mechanical trouble but it was fast.
Still loving the Kyosho.
Old 11-24-2015, 03:46 PM   #12789
13Maschine's Avatar
I recently picked up a super shorty from Pro Tek RC as well and it's very short in comparison to my 4400 and 4600. I figure I need to use short battery posts so I can lower the brace, has anyone else done similar things?
Super shorty brings the car under min weight very easily, I think I'm at 1480 now. I'll weight it again later and post.
Old 11-24-2015, 08:38 PM   #12790
Just put the exotek frt ti axles on my stock buggy. Ised a b5 frt crush washer and worked perfect to get the stock track width with the stock spacer on the rear.
KW Raceway https://m.facebook.com/kwraceway
Mugen Seiki/Yokomo Usa/Protek/Amain/R1 Wurks/Flashpoint/KW Raceway
robbie_gtc is offline   Reply With Quote
Old 11-26-2015, 07:12 AM   #12791
eper's Avatar
Trader Rating: 14 (100%+)
happy thanksgiving guys
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 11-26-2015, 12:47 PM   #12792
RokleM's Avatar
Trader Rating: 33 (100%+)
With the new stock 5x1.35 pistons, what oils would you guys/gals recommend?
- Eric G. -
Tekno EB48.3, NB48.3, ET48.3, NT48.3, Kyosho RB6, RT6
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 11-26-2015, 02:24 PM   #12793
eper's Avatar
anyone payed with spacing out the exes t make the car wider?
new milford ct,
Old 11-26-2015, 02:28 PM   #12794
rider313's Avatar
Trader Rating: 94 (100%+)
I started with 37f/32r and it didn't feel to bad. I quickly went to the more preferred piston set ups.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 11-26-2015, 11:32 PM   #12795
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
I have and prefer to try and keep the rear track width and rear pivot widths as separate as possible so I can tune each separately. Traxxas makes some .5mm Teflon shims that work pretty good for a more precise width adjustment. You do have to use the kit metal shims on the back side at the ball end of the axle stub so there's a little more surface area to keep the Teflon shims from slipping over the little lip the axle stub has.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22943 Today 07:07 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
tel
