    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 11-17-2015, 10:42 AM   #12751
RokleM's Avatar
Trader Rating: 33 (100%+)
Originally Posted by symmetricon View Post
Zack Roger's setup is a very good starting point..
This one?
http://site.petitrc.com/setup/kyosho...nmans20140821/
I see a number of people talking about aftermarket steering racks. Any other changes recommended out of the box to start on the 2015?
- Eric G. -
Tekno EB48.4, NB48.4, ET48.3, NT48.3, EB410
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 11-17-2015, 12:26 PM   #12752
Regional Moderator
RobsRacin's Avatar
I bought the aluminium steering rack, V2 0* hubs, as well as aluminium RF and RR suspension holders so I could adjust toe and track width. Other than that I put 2x1.6 with 35 in the front and 2x1.7's in the rear with 30 and the car is very good on medium bite clay as well as high bite topsoil.
RobsRacin is offline   Reply With Quote
Old 11-17-2015, 03:16 PM   #12753
Thanks, i have alot of things to try this weekend.
BiLL77 is offline   Reply With Quote
Old 11-18-2015, 04:50 PM   #12754
Trader Rating: 75 (100%+)
Have a bunch of the 2 hole rear arms. Instead of buying the new 3 hole does anyone have a pic of a 3 hole mod arm? Just want to make sure I'm drilling in correct spot.
Also when I bought my car used it came with lots of spares. It has a gear diff right now. It also came with the MIP 17.5 setup. What's the diff between it and a mod? Can I use the 17.5 with my 7.5 motor or is it 17.5 only?
gixxer420 is offline   Reply With Quote
Old 11-18-2015, 05:36 PM   #12755
oPAULo's Avatar
Measure the distance between the 2 holes you have and go that same distance center of the arm.
The 17.5 setup is all aluminum. Your slipper setting will be critical to make it last. I set mine the way Tebo does on youtube. 1-2 inches of front end lift when you grab the throttle. I might back off from that with all aluminum drivetrain and keep a close eye on it.
oPAULo is offline   Reply With Quote
Old 11-18-2015, 05:54 PM   #12756
Preciate the help.
So the 3rd hole will be drilled closer to the out drive instead of the wheelside?
I can use the 17.5 with my 7.5 as long as I keep and eye on it since it's all aluminum. I may just take the MIP out drives out and put standard in then I would really have to worry since I would be pretty much stock besides the MIP diff
Old 11-18-2015, 10:31 PM   #12757
Originally Posted by eper View Post
hey nitroargi i finally have time to post what i found with the steering rack brace. for one i found that the directions from the buggy to the sc are different as the buugy calls for 1mm spacer under the bearings and the sc calls for it on top. any how i remo ed them from the buggy and put the 2 thin shims that came with the brace under the bearings and the brace ot the top by itself.no binding issues and car felt better. notsure if its because of the brace or because i lowered the rack 1mm. anyway i like it abd it seems fine.any questions hit me up
Thanks for lookinf that up...what was the effect of the rack? Did it make the steering more responsive?
nitroargi is offline   Reply With Quote
Old 11-18-2015, 11:15 PM   #12758
oPAULo's Avatar
Preciate the help.
Yes the 3rd hole is inboard tward the ourdrive.
And maybe......
My MIP ball diff didn't jive with the stock ball diff. Might have to replace the whole unit.
Old 11-19-2015, 06:22 AM   #12759
And maybe......
This 2wd stuff is all new to me.
Old 11-19-2015, 06:51 AM   #12760
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by RokleM View Post
This one?
That's it...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 11-20-2015, 05:10 AM   #12761
eper's Avatar
Trader Rating: 14 (100%+)
like i said i was running my rack on top of those 1mm shims so after getting rid of those the car seems to be less agressive when u are turning with the nose compressed. it helped my bump steer that stablizer didnt really do much except make the steering more consistant and the car seems to track more straight
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 11-21-2015, 10:26 PM   #12762
Motorman007's Avatar
Trader Rating: 78 (100%+)
How who makes this top battery brace and post?
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 11-21-2015, 10:36 PM   #12763
oPAULo's Avatar
Saw that one but didn't like 4 screws and 2 different tools. It's just screwed to the waterfall tabs and a backwards battery brace. Get a sheet of whatever and cut one out.
Old 11-21-2015, 11:00 PM   #12764
PhilDz's Avatar
Trader Rating: 20 (100%+)
http://www.amainhobbies.com/rc-cars-...r10005/p469218
http://www.amainhobbies.com/rc-cars-...w520gm/p222069
Phil Samonte *Team Balut*
PhilDz is offline   Reply With Quote
Old 11-21-2015, 11:09 PM   #12765
Thanks all
Just trying to find a easy way to make the side way work and I see I need to get some side foam for each side of the pack to fill up the extra space.
What is the easies way to have a top battery brace? I just got it Friday.
And yes the 4 screws is a pain I see now.
Again thank you
And I love the shock package on this kit.
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Yesterday 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
