    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 11-15-2015, 01:05 AM   #12736
Suspended
Originally Posted by gokarter64 View Post
A common mistake on pucks is greasing them. I run them dry and they last me a really long time. Another question though is what are your track conditions? Loose dirt canchew them up pretty good too.
My track is kind of a clay dirt mix, med to high bite. Definitely can get dusty ,I've been wiping the grease and dirt off the pucks and greasing between runs...
Unfortunately the stock diff is HEAVY compared to the mip diff
Is this why almost everyone is running mod? Lol
chriso138 is offline   Reply With Quote
Old 11-15-2015, 01:08 AM   #12737
Suspended
Originally Posted by RobsRacin View Post
C in C in will get you 3 degrees
Thank you
Old 11-15-2015, 01:09 AM   #12738
likea45's Avatar
MIP recommends greasing the pucks when running their Dif as I do. I know with the stock dif the pucks are a tight fit and as a result wear quicker.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 11-15-2015, 02:03 AM   #12739
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
Originally Posted by robbie_gtc View Post
Hey guys, just picked up an rb6 that I am going to be trying out. Currently have 2 b5m t5m and sc5m that I run 3 gear on. I love the way 3 gear changed the handling of the kit.
Question.. looking at the 3 gear for thr rb6. What have you noticed in changes in the way the car handles vs 4 gear?
I will be running the car in stock and mod indoors.
First how is the grip on the track you run at? If the grip is high enough to support a 3gear setup (carpet or slicks on wet clay or the like) then it'll work the best. Better corner speed and flatter braking are the two big pluses of the setup, though it will come at a cost of a little less forward bite. So if the grip isn't high enough to support a 3gear setup, it could be almost undrivable.
For stock I'd run at least the adjustable alum rear arm mounts and the alum front arm mount.
For mod I'd probably run the front brass arm mount and the RF brass mount to keep the weight up a little for stability. It's what I went to and seemed to help with a 7.5 strapped in. You could probably get away with the brass mounts in stock if you're really wanted to, but I felt it might make the car too heavy for 17.5.
I'd also consider a sideways battery mod to the chassis as well, but seem to work real well together, though I admit I never ran the 3gear setup with an inline battery.
Hope that helps.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 11-15-2015, 07:48 PM   #12740
Teufel racing,
Its a medium grip track... thing is I have never had rear grip issues with me AE cars with the 3 gear...
So I finished puttig some electronics I have a s spares while my esc and rec'r get here in the rb6 and threw in the 3 gear....
After that I placed my stock b5m next to the rb6 and took a picture... the motor is actually farther towards the rear with the 3 gear then the b5m. Battery(sideways) is actaully almost identical. And of course the rb6 has the more forward servo.. so the rb6 theoretically should have more rear grip with the 3 gear then the b5m has.. will be heading to the track later this week and will test it out.
KW Raceway https://m.facebook.com/kwraceway
Mugen Seiki/Yokomo Usa/Protek/Amain/R1 Wurks/Flashpoint/KW Raceway
robbie_gtc is offline   Reply With Quote
Old 11-16-2015, 03:44 AM   #12741
Has anyone tried bolt on weight under the rear aluminum hubs where the set screw threads are? I run on medium bite clay battery sideways all the way back gold rear 32.5 pink front 32.5 1.6 2 hole and need a little more rear side bite. i already have 28 grams bolted to rear bulkhead.
BiLL77 is offline   Reply With Quote
Old 11-16-2015, 06:05 PM   #12742
I don't know anyone who has, I don't think there's a lot of threads to work with on the hubs, so it's tough to say for sure if it's possible or not for that to work.
I run pink front and gold rear springs most of the time, but I run 1.6x2 pistons front and 1.7x2 pistons rear, with 35 oil front and 30 rear. I'm guessing your setup won't let the car roll as much or as fast as it needs to to get the side bite it needs. I'd try the 1.7x2 back there and run either 30 for oil or maybe 27.5 if it's cold. If that doesn't help, I'd play with the roll center some and adjust the rear camber link shims to get a little more roll in the chassis.
J.Mikoliczyk
RB6 - MBX7R Eco
Old 11-16-2015, 06:17 PM   #12743
Teufel racing,
Got ya,
I haven't played with the 3gear setup on a med. grip track all that much as my local track has been high grip for just about all of summer and only now just lost some of the grip that slicks don't work like they had been and most went back to treads for the dryer track. If your AE car worked with a 3gear on med. grip, then I'd say the RB6 should be able to work in the same setup for the same grip, just might need a little,more work to get it to work than the AE car did. Some of the locals that do run the AE car with a 3gear setup in theirs have said that their cars didn't feel right with the local track changing from what it had been. I swapped out my 3gear tranny on the fly back to the 4gear setup when it looked like treads were the way to go and the car did seem to respond to the changes better than it was with the 3gear, for me at least.
J.Mikoliczyk
RB6 - MBX7R Eco
Old 11-16-2015, 09:31 PM   #12744
cnelson3's Avatar
Trader Rating: 65 (100%+)
I have actually. 5 grams. it does help with rear grip but i didn't like how the car was severely numb. it takes away a lot of the agility of the car. I had better results going with the 3 line axles and putting the 2mm spacer outside of the hub. The increased distance from the hub pin and the outer edge of the hex really helped to create grip. You might need to change your pivots because this will make the car wider.
Kyosho America
Peak Racing
Trackside Hobbies & Raceway - Milwaukee, WI
cnelson3 is offline   Reply With Quote
Old 11-16-2015, 09:36 PM   #12745
You want everything outside the inner hinge pins as light as possible. Never add weight there. That is called unsprung weight. Bad things man. If you want to add weight, try an under the lipo brass weight or brass battery holders by Revolution. Rude Bits has lots of weights too. Kyosho sells a weight that bolts to the rear of the car. Avoid it. It acts as a pendulum and causes the rear to swing out. You want the weight in front of the rear axles. I personally added about 35 grams of weight recently and was amazed by how much more control I had.
scoobyrs25 is offline   Reply With Quote
Old 11-17-2015, 03:34 AM   #12746
Awesome thanks for the advice guy's, i'll try each one at a time and find out what feels the best.
Old 11-17-2015, 05:20 AM   #12747
eper's Avatar
Trader Rating: 14 (100%+)
hey nitroargi i finally have time to post what i found with the steering rack brace. for one i found that the directions from the buggy to the sc are different as the buugy calls for 1mm spacer under the bearings and the sc calls for it on top. any how i remo ed them from the buggy and put the 2 thin shims that came with the brace under the bearings and the brace ot the top by itself.no binding issues and car felt better. notsure if its because of the brace or because i lowered the rack 1mm. anyway i like it abd it seems fine.any questions hit me up
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 11-17-2015, 05:22 AM   #12748
eper's Avatar
bill77 the weight out by the wheels like that only really helps on very bumpy tracks otherwise id stay away from it. try running c in in the front and and b in in the rear it adds .5 degrees of toe and produces more forward bite
new milford ct,
Old 11-17-2015, 07:31 AM   #12749
RokleM's Avatar
Trader Rating: 33 (100%+)
Good setup for someone ordering the 2015 kit with an indoor clay/dirt slick track? What else should I order?
- Eric G. -
Tekno EB48.3, NB48.3, ET48.3, NT48.3, Kyosho RB6, RT6
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 11-17-2015, 08:50 AM   #12750
symmetricon's Avatar
Trader Rating: 27 (100%+)
Zack Roger's setup is a very good starting point..
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
