    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 11-07-2015, 12:19 PM   #12721
MayorRC's Avatar
If I remember right all I needed was a .1mm shim below the crank arms and the brace fit perfect, no play. Are your steering posts (silver) worn quite a bit by chance?
MayorRC is offline   Reply With Quote
Old 11-07-2015, 01:40 PM   #12722
No they are fairly new
nitroargi is offline   Reply With Quote
Old 11-07-2015, 08:04 PM   #12723
Trader Rating: 32 (100%+)
I wish they have new RB7 come out very soon. I pre-order 22 3.0 but i want this brand. I have xb4 '15 and love it so far.
raved007 is offline   Reply With Quote
Old 11-07-2015, 10:04 PM   #12724
whitrzac's Avatar
Trader Rating: 95 (100%+)
Why would there be an rb7?
The Rb5 'generation' was ~5 years+. We're on year 3 for the rb6.
The "rb" before the RB5 was not much different than the early RB5s too.
whitrzac is offline   Reply With Quote
Old 11-07-2015, 11:53 PM   #12725
LiL CeeZ's Avatar
Trader Rating: 15 (100%+)
My RB6 has been doing me proud lately. I'm at 1551 grams and the car is really easy to drive, the driver though needs some work LOL. I've got the 3 gear and been running a D4-1S certified and it's pulling like a madman down the straights and plenty of power for the short run ways to the rhythm section we have that's double double double out of a tight turn. A guy I met at the track and now good friend has been kind enough to steer me in the right direction and I just stay on top of a few things and the car stays consistent now and the progression in my driving is improving after each outing. I'm loving this car.
Team Associated B6D
LiL CeeZ is offline   Reply With Quote
Old 11-08-2015, 02:56 PM   #12726
t8rtot's Avatar
Trader Rating: 14 (94%+)
Is the RB6 not competitive or do you just want a new car because other companies are rolling out new ones? The latter isn't a wrong answer necessarily but there is a difference.
Sfida
t8rtot is offline   Reply With Quote
Old 11-08-2015, 03:33 PM   #12727
madweazl's Avatar
I always want something new! Havent even run my RB6 yet and I'm looking at other vehicles. I'll update my 4wd first though.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 11-08-2015, 05:50 PM   #12728
miquelmah's Avatar
motor 145gr y lipo de 135gr ......
https://www.youtube.com/watch?v=wvEn9vckrk0
SWORKZ BE-1, LEOPARD, HOBBYWING, GENS ACE, SANWA VX, FUTABA 3PL, MBX5R/T, RB5SPSL, FG MONSTER, TC5R, 808E, HYPER8, TF5, ZX5, NANO-TECH, HYPERION, 620DMG, ECO6-10, TEAM-IHOBBIES
miquelmah is offline   Reply With Quote
Old 11-11-2015, 04:19 AM   #12729
eper's Avatar
Trader Rating: 14 (100%+)
did u ever figure out the rack issue i just ordered one of those braces so i should be able to help u out once i get the part and see whats going on
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 11-11-2015, 10:39 AM   #12730
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Hello guys,
I wanted to try the UMW724 steering brace in my car but it seems there is a binding problem after installation. Added the shims that came with the kit but the binding remains...any ideas?
Theres a 1.5mm shim that goes under the steering arms, but the problem with that brace is that it incorporates the shim on the brace and essentially puts it on top. The issue I had was that if you ran 25/0 caster you gave yourself bump out that you couldnt fix (by lowering the ackerman bars you are essentially raising the steering ballstud).
I shaved the brace flat, but in the end took it off. If you run a truck it's fine as the shim is on top of the steering rack, but on the buggy it's not correct.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 11-13-2015, 11:04 PM   #12731
Didn't have time to mess with the car so I left it as it it for now...if you come up with any ideas let me know!
Old 11-14-2015, 04:31 AM   #12732
eper's Avatar
ill be installing it tomorrow and ill post my findings as its a race day
new milford ct,
Old 11-14-2015, 08:07 AM   #12733
yodace's Avatar
R/C Tech Charter Subscriber
What company sells the 3 gear transmissions?
yodace is offline   Reply With Quote
Old 11-14-2015, 09:33 AM   #12734
Airlmeier4422's Avatar
Looking on gearing advice for my rb6. I have a 10.5 viper with 25 degrees of mechanical timing with no esc boost or timing. What would be the best pinion to be paired with 82 spur? Would it be a 26-27t pinion? Thanks.
Airlmeier4422 is offline   Reply With Quote
Old 11-14-2015, 12:40 PM   #12735
Hey guys, just picked up an rb6 that I am going to be trying out. Currently have 2 b5m t5m and sc5m that I run 3 gear on. I love the way 3 gear changed the handling of the kit.
Question.. looking at the 3 gear for thr rb6. What have you noticed in changes in the way the car handles vs 4 gear?
I will be running the car in stock and mod indoors.
KW Raceway https://m.facebook.com/kwraceway
Mugen Seiki/Yokomo Usa/Protek/Amain/R1 Wurks/Flashpoint/KW Raceway
robbie_gtc is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
