    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 11-02-2015, 12:12 PM   #12676
symmetricon's Avatar
Trader Rating: 27 (100%+)
This is with a lightweight shorty pack....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 11-02-2015, 12:16 PM   #12677
oPAULo's Avatar
Have mine laid out the same way but this past weekend I moved the battery back under the waterfall almost against the motor. Made a world of difference for me. Local track gets really slick by the end of the day. Plus it's getting cold.
Would love to see some center of gravity measurements.
oPAULo is offline   Reply With Quote
Old 11-02-2015, 12:18 PM   #12678
oPAULo's Avatar
HOLY SMOKES!! That is freakin sweet!
Old 11-02-2015, 12:19 PM   #12679
Don't mind my rats nest or wires, this was when I first built the car battery inline with the same lightweight pack. ...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 11-02-2015, 12:21 PM   #12680
Regional Moderator
RobsRacin's Avatar
are those the G Force scales? I want to get a set
RobsRacin is offline   Reply With Quote
Old 11-02-2015, 12:24 PM   #12681
It's actually the skyrc scale, but they are exactly the same...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 11-02-2015, 12:38 PM   #12682
oPAULo's Avatar
That's pretty much my layout but I have the front battery strap the other way with a foam block.
What keeps the battery from moving side to side when you reverse the strap like that?
Seems like I've read 60/40 weight balance somewhere before.
I would think you could measure wheelbase and draw a line at 40% in front of the rear axles and the car should balance on that point.
Old 11-02-2015, 01:01 PM   #12683
The waterfall kept the battery from moving side to side.. since that photo I've changed the battery layout, I'll post a pick when I get my car converted back....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 11-02-2015, 03:43 PM   #12684
GIHOSU's Avatar
Yes you do, it rocks...
I would corner balance my cat if she would just stay
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 17.5 Turf ~ RB6 17.5 ~ RB6 ~ RZ6 Turf ~ RT6 Turf ~ SC6 17.5 ~ SC6 ~ SC6 Turf ~ ST-RR Evo.2E
TEKNO - SCT-410 ~ SCT-410.3
GIHOSU is offline   Reply With Quote
Old 11-03-2015, 04:39 PM   #12685
whitrzac's Avatar
Trader Rating: 94 (100%+)
Opinions on the avid triad slipper setup?
6.5, foam tire, carpet.
Traction is never an issue, not grenading the gearbox is.
whitrzac is offline   Reply With Quote
Old 11-03-2015, 05:22 PM   #12686
oPAULo's Avatar
I run it on 2 cars. Love it. Many runs between service. Holds the setting a long time. Doesn't fade in a 10 minute main.
Sometimes medium traction but usually low traction though so....ya.
I do honestly believe the MIP pucks make the drivetrain last longer though. Only wasted tranny gears one time and that was after the diff got crunchy and I re-used all the gears. Right at 100 runs. Now I replace all the gears with a diff rebuild and set it and forget it.
Old 11-03-2015, 08:09 PM   #12687
Light weight battery in line all the back against the motor...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 11-03-2015, 08:10 PM   #12688
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 11-03-2015, 08:42 PM   #12689
Haha, just noticed I'm not cross balanced... just put it back and didn't adjust shock preload lol.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 11-03-2015, 10:50 PM   #12690
cnelson3's Avatar
Trader Rating: 65 (100%+)
Does anyone know the antisquat degree if the rear toe block had no spacer below it and the front had .5mm shim?
cnelson3 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
